Old Jan 28, 2011, 06:43 PM
FltLtBiggles is offline
Find More Posts by FltLtBiggles
Parkflyer Extraordinaire
FltLtBiggles's Avatar
United Kingdom, England, Norwich
Joined Feb 2009
Problem Binding DX6i to Hobbyking AR6100 Clone
Hi all,
Ive done a quick forum search and have tried everything that people have suggested. Now im wondering if Hobbyking has updated the latest batch of these clones! The replica AR6100 i recieved doesnt apear to have a LED at all so im not getting any lights blinking or solid.
Just wondering if anyone else has noticed the change and if so have they managed to get it to work as im stuck?
FltLtBiggles is offline Find More Posts by FltLtBiggles
Site Sponsor
Latest blog entry: My first blog post
Old Jan 28, 2011, 06:50 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The most common reason for problems of this sort is plugs in wrong slots or backwards. Note that the HK 6100 clone (the Black) has reverse setup with respect to the 6110 clone (RA61e). To determine the correct orientation just look up the relevant Spektrum receiver manual.
Try the throttle (or battery) plug both ways round and the bind plug in both end slots on the receiver, and try another bind plug in case yours is defective. If you do all those things (with no servos plugged in to avoid confusing things) and you don't get a light at all, there's something wrong with either the receiver or the power source.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 29, 2011, 04:37 AM
Joined Feb 2009
Thanks Daedalus66,
Im going to give your suggestions a try now, I hope i dont have to send this all the way back to HK
Site Sponsor
Old Jan 29, 2011, 04:53 AM
Joined Feb 2009
I still cant get this to show me any LED, can someone please point out where it is. Ive tried various combos again. Ive managed to get the servos, to twitch on connecting the battery so i know there is something going on, it just wont effing bind.
Site Sponsor
Old Jan 29, 2011, 07:10 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Referring to the third picture, the light is a bit up and to the left of the middle. But this is really irrelevant -- if there's a light it's bright and impossible to miss (unless you are looking at the blank side of the board!). (EDIT: See next post for photo.)
Still looking at that same picture, the bind plug goes onto the pins at the bottom of the picture (as you have it in picture 2). The power source (battery or ESC) goes onto any other set of pins with the black/brown wire up (towards us) and the white/orange/other color wire down (towards the blank side of the board). THIS IS WRONG IN PICTURE 2.
Just do that -- no servos, no transmitter turned on -- and you should get a bright rapidly flashing light indicating that the receiver is in bind mode. If you don't get the light:
  • There's no power, or
  • The bind plug is faulty (the two outside pins are not connected), or
  • The receiver is defective, or
  • You didn't follow instructions
By the way, one of those receivers arrived from HK just two days ago and the light is there just like on previous ones. There has to be a light.
Old Jan 29, 2011, 07:24 AM
Aero Antics is offline
Find More Posts by Aero Antics
You're serious, aren't you?
Aero Antics's Avatar
Southern IN
Joined Dec 2008
I had the same problem. In your picture you posted the negative (black) wire is on the bottom...it needs to be on the top. Flip the plug 180 degrees.
Gave me a bit of confusion too.
Aero Antics is offline Find More Posts by Aero Antics
Old Jan 29, 2011, 07:53 AM
Joined Feb 2009
http://www.youtube.com/watch?v=qr6hDEXwkQ0
Heres a vid of me trying to bind it with a makeshift bindplug made from wire and wrapped around the correct pins.
Halfway through the vid i switch the esc plug around and restart to see if it was that causing the problem.
Site Sponsor
Discussion OrangeRx from HobbyKing (AR6100 clone)- $14.95 localbuyer Hot Online Deals 375 Jul 31, 2011 04:14 PM
Help! dxi/ar6100 binding problem superguy6486 Electric Plane Talk 12 Aug 29, 2009 04:37 PM
Help! DX6i / AR6100 binding problems dvincent Radios 4 Oct 31, 2008 09:42 PM
Discussion 6100 binding problem with DX6i rickquirino Radios 2 Aug 01, 2008 03:33 PM
Discussion Spektrum DX6i Binding Problem berniek Radios 2 May 14, 2008 07:48 AM
