Old Aug 16, 2003, 03:58 PM
derailed is offline
Find More Posts by derailed
rc transports rule!
new brunswick canada
Joined Jul 2002
NNOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!
derailed is offline Find More Posts by derailed
Old Aug 16, 2003, 04:25 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
It's all fixed. Can't tell it was bellied in. Was very stable. I think it was a little nose heavy also. Retried the toss glider, and rebalanced for a more forward CG. I think I was off a little.
Very durable, for the construction.
Try...try... try...
Steve
St. Martin is offline Find More Posts by St. Martin
Old Aug 16, 2003, 04:26 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
I mean a more rearward CG DOH!
Old Aug 16, 2003, 05:19 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
what did you end up with for an AUW? also did you try the nose on scale and run it up just to see where you are on static?
dave morris is offline Find More Posts by dave morris
Old Aug 16, 2003, 06:00 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
The AUW on my scale is 21oz. My fish scale says 19oz. The scale is not accurate. Very old wore out. The thrust when holding it is very good. definetly more than half the AUW. I played with the toss glider some more and it did the same thing at the same CG. At a hard toss it was fine. Slower throw and it slowed and headed to the ground.
I removed some nose wt till glider flew level then fell more horizontally rocking it's wings at the stall. I had a Byrons F-16 yrs ago, it flew the same way.
Checking the new CG I find I was 1/4" to far forward.
I should of tested the glider more.
I found a high grass field. Going by myself to do some low power test glides w/8 cells instead of 10.
Old Aug 16, 2003, 06:07 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Steve,
You'll get it. F-16's always fly good. I had the Byrons too. What a kick in the pants it was to fly when the engine was running right.
Tall grass is a good idea, but I bet you get a flight in or two once you see it's on the step!!
Best of luck second time out!!!!!!!!!!!!!!!!!
Steve
U812 is offline Find More Posts by U812
Old Aug 16, 2003, 06:44 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Thanx Steve,
I went dead stick one time with the Byrons(new OPS .65)
from 200'. The jet fell flat all the way to the ground flattening the gear in the grass. Changed the plug, flew again. Ahhh the good ole days...
Old Dec 03, 2003, 07:24 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Now itsa pusha!
I was going to repower with a /2 mega in the Wattage fan, w/KY rotor. Decided to try it as a pusher first.
I finally have a new pc, so I can finally use my new, one yr old cam. Will try for flight shots on maiden.
Steve
Old Dec 03, 2003, 07:26 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Mega /5 on 8-He1100, using 7-5E APC Or 10-He using APC 6-5.5
Old Dec 03, 2003, 07:28 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
AUW 21oz approx 1:1 thrust?
Old Dec 03, 2003, 08:45 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Loks awesome! Let her rip
Haldor is offline Find More Posts by Haldor
Old Dec 03, 2003, 08:47 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Yea, as soon as the temps get a little better.
Thanks Haldor
Steve
Old Dec 03, 2003, 06:00 PM
inedesca is offline
Find More Posts by inedesca
mexico city, mexico
Joined Aug 2000
You should paint the prop in mat black so it is less visible.
I do not know why but iti is so. White on the countrary.
I wonder why but it is my experience.
inedesca is offline Find More Posts by inedesca
Old Dec 03, 2003, 06:03 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Good point indesca. The reason is black is an absence of color.
White is the mixture of all basic colors.
Steve
Old Dec 03, 2003, 06:17 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Playing with the new cam... Batt. area
EWO's F-16 revisted Nethole Foamies (Kits) 5 Mar 24, 2005 02:43 PM
F/s F-16 Flying Styro Kit theroo Aircraft - Electric - Airplanes (FS/W) 0 Nov 13, 2004 10:24 AM
Rog F/s F-16 pacro Electric Ducted Fan Jet Talk 3 Oct 07, 2004 04:10 PM
razor 300/30amp esc F/S f-16-- battery recommendations? gruntdog Electric Ducted Fan Jet Talk 4 Nov 11, 2003 06:02 PM
Hobby Lobby's F-16 kepople Electric Ducted Fan Jet Talk 4 Jun 09, 2002 07:29 PM
