Old Jan 27, 2011, 10:03 PM
Fallengod is offline
Find More Posts by Fallengod
Ottawa, Canada
Joined Jul 2004
Wifi Boosted AR.Drone
I posted a while about finding a RF test point on the AR drone and since then i been waiting for all my stuff to arrive.
Put a good evening of work into my AR drone and here are my results
The before and after:
10dbi received Gain!
Fallengod is offline Find More Posts by Fallengod
Old Feb 05, 2011, 12:04 AM
HoverGracefully is offline
Find More Posts by HoverGracefully
Joined Dec 2010
How is your mod going! What is the brand name of the WiFi extender/booster! Do you have any pictures of the ardrone in flight?
HoverGracefully is offline Find More Posts by HoverGracefully
Old Feb 05, 2011, 09:10 AM
spudandretti is offline
Find More Posts by spudandretti
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
I would say this one from the pic. http://compare.ebay.com/like/3803068...=263602_304662
spudandretti is offline Find More Posts by spudandretti
Old Feb 08, 2011, 01:01 AM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
Fallengod Check your solder connections.....Any pointed peaks will act like an antenna............keep the wires as short as possible because a long antenna wire will also act like a delay line..........
skizziks is offline Find More Posts by skizziks
Old Feb 10, 2011, 07:09 AM
fastuning is offline
Find More Posts by fastuning
Joined May 2010
Post a Tutorial PLEASE!
fastuning is offline Find More Posts by fastuning
Old Feb 10, 2011, 11:24 AM
GGoodrum is online now
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
+1 for a tutorial/more details.
-- Gary
GGoodrum is online now Find More Posts by GGoodrum
Old Feb 10, 2011, 10:33 PM
Kevo500 is offline
Find More Posts by Kevo500
Kevo500's Avatar
Suffolk County NY , USA
Joined Mar 2009
I agree with pointed peaks being bad and can all interference into the line . Also , unless there is a wire under that peak , it means your iron was not hot enough to allow the solder to flow properly.
But this would be the first time that I have ever heard of a "delay line".
Are you implying that a longer wire somehow changes the speed of light ??
I can see it causing a higher swr. But 'delay' .. its just not clicking for me.
Can you elaborate ??
Kevo500 is offline Find More Posts by Kevo500
Old Feb 12, 2011, 11:52 AM
skizziks is offline
Joined May 2006
Kev500 RF has certain characteristics when it travels through wires....RF aslo travels at one speed when it travels through wires which means there will be latency if the signal travels through a longer wire....Delay lines are used in high tech RF designs like 3G amplifiers, multi loop linear amplifiers, Feed Forward amplifiers, and multi carrier rack mount amplifiers....Simple delay lines are just a coiled RF line used to keep a multi block RF design in phaze because the signal is split and processed and when you re-group or combine the signal all of the re-grouped signals must be in phaze so that is where a delay line is used....There are also other Things to remember like RF deflection where is a group of signals off multiple antennas will need to have the same length signal wires going to a combiner or RX....If the signals do not meet at the combiner at the same time the slower signal or signals will be deflected.....RF deflection also happens when a signal wire is bent at too much of an angle....The signal will not pass through the angle ...It will just deflect .....Think of the signal wire as a water hose with a kink that stops the water.....It took me over 15 years to learn about RF and I was the assistant of many RF design engineers over the years and helped them with their design of many RF devices.....I have installed many high end WI-FI networks where the signal would have to span over 10 miles with the aid of amplifiers and fancy antennas....
Discussion Who’ s the Russian model in AR.DRONE vid? Naev Electric Heli Talk 8 Oct 12, 2010 03:32 PM
Sold Parrot AR. DRONE with Extra Batt. and Outdoor shell PRICE DROP rdr4evr69 Aircraft - Electric - Helis (FS/W) 10 Oct 01, 2010 03:11 PM
Sold Parrot AR Drone Roger_IIT Aircraft - Electric - Helis (FS/W) 3 Sep 27, 2010 05:21 AM
Discussion AR.Drone to carry camera gunnar-rc Aerial Photography 2 Sep 07, 2010 10:52 AM
Discussion Unboxing and First Impressions With the Parrot AR.Drone nikotttin Multirotor Talk 0 Aug 31, 2010 05:50 AM
