Old Feb 14, 2011, 09:05 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Originally Posted by scorpion1 View Post
Kinda fibbed...............i had to use one zip tie also................
Now you getting too high tech.
Be careful on those adult beverages of your choice. Drink way too many of them and you're liable to start looking like me.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Feb 14, 2011, 09:10 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
What the hell!!!......beer,soda its the same thing/size!!!.....you better build a good solid mount `cause this monster can rip your inside hull in one pull!!!!...you can later on try Peter Zicha.....hes very affordable,specially if it is for a one bracket mount only.,,,,,
You can probably ride on top of this monster whenever its done..........
Did someone mentioned the possible availability of a 2028??!!.....lol...if so let me know!!!!,....Albert
They are available at offshore electrics right now!
scorpion1 is offline Find More Posts by scorpion1
Old Feb 14, 2011, 09:27 PM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
i was kidding!!!.....You know im still deciding what to use in my aeromarine
37" hydro.Im still in between the leopard 4082 that you suggested me or a castle 1717 as suggested by you and others later on in OSE.
Anyways,.....lets keep this thread pure and going!!!..........Al
karfrik is offline Find More Posts by karfrik
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Scorp you made your own water jacket do they make a jacket for this motor ?
mavdriver is offline Find More Posts by mavdriver
Old Feb 14, 2011, 10:49 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Not yet.............i'm working on the gasket groove right now and found that gaskets from a Feigao 580L stretch to fit..............this is gonna work out well!!
Old Feb 15, 2011, 12:22 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Water jacket done.......!!
Grooved the ends of my "PVC coupler" jacket, added some grease and slid it on..............the O-rings are from a Feigao 580L jacket..............had to stretch them just a bit but they are just fine................pressure tested well!
Old Feb 15, 2011, 04:41 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
HRC will be making one but it probably won't be available before mid March.
Old Feb 15, 2011, 07:41 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I will probably get one from HRC when they come out though due to the nice fit and finish.................this should be fine until then i hope.
Old Feb 15, 2011, 10:22 AM
STRINGFLY is offline
Find More Posts by STRINGFLY
STRINGFLY's Avatar
Little Rock Regional, Arkansas, United States
Joined Sep 2002
Better do a WATER test before installing in boat.....
Stringfly <>++++
STRINGFLY is offline Find More Posts by STRINGFLY
Old Feb 15, 2011, 02:29 PM
taffy047 is offline
Find More Posts by taffy047
bristol
Joined Nov 2008
http://www.youtube.com/user/taffy047.../0/qde3vGKi7n8
not sure if its 50inches got to be close this is a vid i took at uk nations got a feeling 8s or maybe 10s not sure
taffy047 is offline Find More Posts by taffy047
Old Feb 15, 2011, 08:03 PM
mavdriver's Avatar
Joined May 2002
Taffy what motor and ESC was he runnining ? it was hook up nice .
Old Feb 16, 2011, 02:09 AM
taffy047 is offline
bristol
Joined Nov 2008
he is one of thoese sercet guys that does not like tell , but ill give it a try and find out ! most likey a plettenberg but ill find out
Old Feb 16, 2011, 09:10 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Nice vid taffy....................still trying to figure out where the yellow boat went..........???
Rpm's sound pretty low to me............anyone else? He's also slowing quite a bit in the corners..........can hydro's not take open throttle corners within reason?
Old Feb 16, 2011, 10:09 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Hey Scorp. Got your micrometer handy? I've still been working on getting a mount into production for this monster. Here's a little copy n paste from the most recent email.
Bill,
There are two (known to me) variations on a 30mm hole spacing: 4 and 6 holes, I make both. Castle probably uses 4 as that is the standard for cars and trucks. Leopard is 6. Neu (1527) is a odd ball with 25 and 30mm 4 hole patterns and oval cooling holes. This is new in the last year.
Iíve heard that Leopard makes the Castle motors but that has not been confirmed, looking at the link you sent the motor does look like a Leopard, but longer than the 5692 by about 30mm, a coke can measures about 122mm.
To make a mount for that I would need to know:
1. Hole spacing: 30mm
2. Hole pattern 4 or 6
3. Diameter of the can to the 1/10 of a mm.
4. Position and size of any cooling holes in the front end bell
5. on tilting bottom mounts the distance from the front of the motor to the just in from of any screws hold the rear end bell.
Jim
Old Feb 16, 2011, 05:25 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Dont have a micrometer...............and getting measurments within 1/10 of a mm is almost impossible with my wooden ruler from second grade. He may have to get a motor to do it...........or when i get the second one in i could possibly send it to him.............kinda stickin' my neck out though sending a $300 item around the country.
Speaking of mounts..........made the motor mount............now need to make the brackets to bolt to the stringers.............had to run to the hardware store to buy a 90* dremel drill attatchement to drill the holes for the brackets............
Man.............everything takes like four times longer than i would have thought, didnt feel like i got anything done today which is my day off. Mounted the servo's too, but there had to be dremel modding etc.............
Data 4 point hydro 3 point hydro mxz70017 Racing Boats - Electric 48 Oct 26, 2015 02:17 AM
Discussion Hydro build plans Justinl7294 Racing Boats - Electric 17 Jan 24, 2011 11:26 AM
Discussion My first Hydro build! scorpion1 Racing Boats - Electric 253 Nov 18, 2010 01:56 PM
Discussion String's Pursuit vs Scorps Villain........ scorpion1 Racing Boats - Electric 12 Nov 15, 2010 08:32 AM
Discussion 50% Bigger Hydro-foamie bigjohn Foamies (Scratchbuilt) 3 Sep 10, 2010 04:55 AM
