Old Jan 30, 2011, 06:50 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
6.35mm.................prop suggestions as far as size??
scorpion1 is offline Find More Posts by scorpion1
Old Jan 30, 2011, 07:31 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
With that monster motor you plan to drop in there a 70 mm would not be out of the question. My question is, have you figured out where to load up 9s 2p on the battery packs yet?
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jan 30, 2011, 08:06 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I can easily fit six 5000 3s batts in the cockpit..............that would be 9s2p!
Here's a pic of a 5800 3s in there, with about 8" of room still in front of it.
and a pic of the Canopy on my 31" x 9" wide Villain
Old Jan 30, 2011, 08:56 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Lots more room in yours for putting the "heavy stuff" forward. That just might work out well for you scorp.
Looks like the Villian got tipsy and tried to wear a lampshade for a hat.
Old Jan 30, 2011, 10:04 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Yep............ The prop is now down from a 78mm to a 66mm............
May work............
Old Jan 31, 2011, 12:34 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
The 1/4 cable is actually a 6.3mm. The only problem is the 8mm shaft:
http://www.hydromarine.de/hm_20056.htm
Look at the drawing, it could be milled down to 5mm, just check your length.
CornelP is offline Find More Posts by CornelP
Old Feb 01, 2011, 11:46 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Modded the gas tank area, and it now fits four 3s 5000's perfectly by removing just a couple pieces of ply. The other two batts will go up in front of it in the nose of the cockpit.
Also added some epoxy to the stringers(which were already well attatched) and a few other areas that needed more or didnt have any at all.
Threw on some stripes to liven up all the red...............
Motor has been ordered and should be here Friday, got the material to make my own cooling jacket already.
Old Feb 02, 2011, 05:38 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
About time you went to work on this thing.
Old Feb 02, 2011, 08:01 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Been busy with alot of other stuff...............
I have my cart full at OSE with lots of goodies, just making sure i didnt miss anything while ordering, gonna check out today.
Any more prop thoughts anyone?
I put an x457/3 in the cart, and now they are sold out. Maybe need to get a 455 for maiden run, which is a couple weeks off..........then try the 66mm stocker..........
Old Feb 02, 2011, 11:07 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Correct me if I'm wrong...........
Been reading up about the "Zenoah" type engines, and have found that the 23-26cc engines are running around 10,000 rpms max........and putting out around 1.75-2.5 hp. SO.........with the big 2028 motor putting out in the 5-8 hp range based on my research, I think a big 78mm "gas" prop would be a bit too much...........my "honed down" to 66m prop may fit the bill as the motor obviously has twice the power, but will also be turning it at twice the rpms.
Thoughts?
Old Feb 02, 2011, 11:30 AM
CornelP is offline
CornelP's Avatar
Bucharest, RO
Joined May 2009
Just be brave and give it a try, you can only fry the ESC once...
Old Feb 02, 2011, 12:49 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Some of the hotter gas motors are running closer to around 17000.
As a thought you could try 8s 2p opposed to the 9s 2p and spin a honker prop (with still more rpms than a gasser). Got 4 good 4s packs laying around to try?
Old Feb 02, 2011, 03:28 PM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Im watching,..im watching,,,,love when Scorpions is pulling out something different!!!.....,..Albert
karfrik is offline Find More Posts by karfrik
Old Feb 02, 2011, 04:03 PM
Rusty Old Fart is offline
Find More Posts by Rusty Old Fart
Zombie Apocalypse
Rusty Old Fart's Avatar
Newcastle, Australia
Joined Nov 2010
I suppose finding or deciding on a starting config is a problem. What to do. Do you have one of those watts up meter's that baz owns and uses.
I can see lots a testing with this monster. Scorp your setting the benchmark for anyone else who builds a monster like this
Rusty Old Fart is offline Find More Posts by Rusty Old Fart
Old Feb 02, 2011, 04:31 PM
karfrik is offline
karfrik's Avatar
Joined Apr 2009
Yes hi is!!!!.....why dont you post this thread in OSE also?.I bet you guys there are going to drop their jaws at this!!!.........Al
Data 4 point hydro 3 point hydro mxz70017 Racing Boats - Electric 48 Oct 26, 2015 02:17 AM
Discussion Hydro build plans Justinl7294 Racing Boats - Electric 17 Jan 24, 2011 11:26 AM
Discussion My first Hydro build! scorpion1 Racing Boats - Electric 253 Nov 18, 2010 01:56 PM
Discussion String's Pursuit vs Scorps Villain........ scorpion1 Racing Boats - Electric 12 Nov 15, 2010 08:32 AM
Discussion 50% Bigger Hydro-foamie bigjohn Foamies (Scratchbuilt) 3 Sep 10, 2010 04:55 AM
