Latest blog entry: Hobby King "SIX" hexa
Here it is
Disclaimer: Read the post first! OK.......... 1. Went to the neighborhood lake cuz there is a resue boat there..........full size boat..........needed that "comfort" for the first time ![]() 2. The lake is a bit small for the big ones.....had to make some slow turns. 3. I am an idiot ![]() 4. Never brought it in for a temp check........or any check for that matter after 1 minute and I know better........got all excited and caught up in it..........we've all pretty much been there ![]() 5. Never got it past about 2/3-3/4 throttle cuz of the lifting........ ![]() 6. ESC thermaled due to not much water flow for some reason.........dont know if i picked something up running so close to the weeds......or if there is too much resistance in the long series of lines.............not sure, have to figure that one out........there wasnt much water in the tubes when it came in. 7. ESC is still working after cool down 30 minutes later........no burned smell, no popped caps.............melted the shrink right off of it though ![]() 8. Motor was 137* without much cooling i guess............ 9. ESC caps were over 200* 10. Gonna have to lower the strut i imagine to get the rear up................this was all just done under "what i thought" would be good type of guidlines. 11. The 2028 is a HOG. 12. It should hit 50+ when i get it all sorted 13. I am an idiot ![]() Help me figure out how to get the ride right.......gotta play with it.........Thanks ![]()
My thoughts... you're no more an idiot than I am scorp. (and that's really meant in a good way)
You just got too wrapped up in the run and forgot to check the time. That was 3 plus minutes before it thermaled out.If the back of the boat had been hopping instead of the sponsons I'd say yyou had too much negative in it. Since it was the other way around, you don't need to lower your strut. Raise it some more instead and give it a touch of negative to push the rear up and front down. Either that or you're worse tail heavy then the miller was in the early runs. Might be a good idea to pull the Swordfish off auto timing and choose low (wild guess here since I don't have a clue of what the 2028 calls for). Possibly a smaller prop than I originally thought too. What did you have on it for the run? I proved that a 460 could melt a Neu on 8s Sunday.(although my SF is fine I think since it wasn't really even hot)
And ill also do like Rusty say,double water pickups!!!,..enough is never enough. And remember im going with what i have learned with my 25" shovel,supposely its all basic hydro stuff, don`t know if it applies to your big hydro but worth a try......good luck and get it back in the water....Al |
hey scorp nice vid.
I think that thing is gonna move some once you got it dialled. I think you could go a little lower on the strut or try a higher lift prop to get the ass out of the water and abit of negative angle and see how that goes. Good luck iv no doubt you'll get there Nice job putting it together now the fettling begins ![]()
| Thread Tools | |
| Discussion Hydro build plans | Justinl7294 | Racing Boats - Electric | 17 | Jan 24, 2011 11:26 AM |
| Discussion My first Hydro build! | scorpion1 | Racing Boats - Electric | 253 | Nov 18, 2010 01:56 PM |
| Discussion String's Pursuit vs Scorps Villain........ | scorpion1 | Racing Boats - Electric | 12 | Nov 15, 2010 08:32 AM |
| Data 4 point hydro 3 point hydro | mxz70017 | Racing Boats - Electric | 45 | Oct 08, 2010 02:46 PM |
| Discussion 50% Bigger Hydro-foamie | bigjohn | Foamies (Scratchbuilt) | 3 | Sep 10, 2010 04:55 AM |
