Old Jan 14, 2013, 07:09 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Don't worry though...on low rates or if you just take it easy on the sticks...this Bype tracks VERY well!! It's only scary tumbly on high rates
Bivens is offline Find More Posts by Bivens
Old Jan 14, 2013, 07:40 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
No schnitt!!! But my problem was I thought I "was" on low rate!!... To nail the tail down when taxiing back from our runway to the start-up area, I always hold full up elevator on high rates, then switch to low. I forgot to switch to low, even though I thought I had...and, as noted, even though I could have sworn, I had set my aileron rates, I had not.......scared me but good!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Old Jan 16, 2013, 10:45 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Bype in the classifieds
hone1er is offline Find More Posts by hone1er
Old Jan 18, 2013, 04:24 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
You sure like to sell your 3DHS plane Joe!!....
SteveT.
Old Jan 25, 2013, 08:32 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Ok....got the battery box redesigned, and laser cut, and it works fine. I haven't actually installed it permanently, but I did insert it in, and it fits, and will now work as designed.
As noted, I ave not screwed/glued it in yet, so the photos from the inside show it just sitting there, and are as you can see not straight. Quite truthfully, I don't know if there is a real need to glue it in, as I designed it with plenty of screw holes in it, so it can just be screwed to the existing battery tray.
And, yes, if folks are interested, I can have a batch made up. The second set I have is for "Inverted-I-fly"...
SteveT.
Latest blog entry: My hangar...
Old Jan 25, 2013, 08:42 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Steve that looks great, really nicely done. PM coming your way so I can pay you for the one you made for me
3drcparts is offline Find More Posts by 3drcparts
Old Jan 25, 2013, 08:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Thanks my friend....I think it will make a good plane even better!!
SteveT.
Old Jan 25, 2013, 10:40 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
That's great, Steve! Nicely done. I'm in.
Bigster is offline Find More Posts by Bigster
Old Jan 25, 2013, 10:47 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Ok.... To get any kind of a break on them, I need to order six of them, so, with Priority shipping to you guys, I need to get $20.00 for them...That sound ok?
SteveT.
Old Jan 25, 2013, 11:57 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
Looks good Steve. Do you have the inside dimensions? Not sure how my Gens Ace 4S 2500s compare in size to the Thunder Power packs.
gremlin is offline Find More Posts by gremlin
Old Jan 26, 2013, 12:11 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I built this around Thunder Power 4S 45C 2700mAH packs...however, I also made the box portion a about an 1/8" higher than the TP pack, and also about 3/16" wider...and, due to the angle I put in the top, you can just out a little bit of foam at the front and due to the angle there will be more clearance. Give me a few minutes to get on my desktop computer and I will give you comparison specs....
SteveT.
Old Jan 26, 2013, 12:30 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
The TP packs are....29mm high x 39mm wide x 127 long, or 1.185" high X 1.568" wide X 5,130" long, and the Gens Ace packs are...24.35mm high X 42.84mm wide X 137.77mm long, it would be snug, but it should fit. And since I have to have a new batch made, I can widen them, just a bit, so, no problems at all.
But man...they made those packs wide for a 2500mAH pack!!!
Ok...redesigned the unit to be 1/16" wider.. so inside width now 44.45mm, and this is as wide as I can go, and still be able to insert the box through the front of the plane, which is the only way to install it.
So,,,if you guys want them let me know....sounds like two so far. Four more to go....
SteveT
Old Jan 26, 2013, 07:26 AM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
Thanks for the update Steve. Yep, those Gens Ace are wide and thin, more so than most other packs for the size but they work great. Sounds like with the width adjustment the box will work fine so put me down for one.
Old Jan 27, 2013, 06:34 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Ok....got my battery box installed, and it works perfectly. And as positioned, the CG is at 5.125" as suggested in the manual. I just drilled straight through the laser cut holes in the bottom of the battery box, into the battery tray and used three servo mounting screws to hold it in place...
And as I have big hands, I think I am going to use a couple of the things shown in the third photo to hold the battery in...(this one is my wife's, so, don't "flame" me for the color... )
SteveT.
Old Jan 27, 2013, 09:17 PM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
SteveT.
Ahaha I've noticed that i do tend to sell them quick. Too bad the only offer i had was $150 RTF
I'll just keep it for now so i might be needing one of those trays!
Discussion Unofficial 3DHS-Bipe thread. Buzzkill2 3D Flying 139 Jul 07, 2011 12:13 AM
Question 3DHS Bipe? PinkYakRC 3D Flying 127 Jul 03, 2011 10:11 AM
Question Crashed my 3DHS Edge 55 need new planes any advice? bhoges17 3D Flying 11 Jan 26, 2010 12:19 PM
Any news of new GWS P-40??? CryHavoc Parkflyers 5 Sep 05, 2004 10:41 AM
