Old Nov 12, 2012, 10:29 PM
Quiet E. Flyer is offline
Find More Posts by Quiet E. Flyer
"Thumbs"
Quiet E. Flyer's Avatar
Gilbert, Arizona
Joined Jan 2007
Loving my Byper. Some setting sun pictures from this evening.....
Quiet E. Flyer is offline Find More Posts by Quiet E. Flyer
Old Nov 12, 2012, 10:36 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by gremlin View Post
Steve, thanks for the photo and template but now I'm really confused. Based on the picture it looks like you have the long side of the fairing going along the landing gear and the short side next to the wing. In looking at the pics of the prototype planes and manual with the white fairings that looks like how they go. But the production black fairing is much longer on the long side compared to the landing gear and is tapered at the end. Based on that it would require trimming about 2" off the fairing to get the long side to fit the gear. Most of the build pictures of the production kit have the long side of the fairing along the wing, which is how I mounted mine, assuming it was a part that didn't need trimming. The short side doesn't reach the wheel pant but appears to extend below the top of the wheel pant when looking from the side. I contoured mine to the wing similar to you but did it along the long side. I suppose it will work either way but I am wondering what the "correct" way is to mount the black fairing so as not to confuse folks.
Rick
Well..... I guess I was confused too.....But I could have sworn a photo I looked at showed the fairing go all the way to the wheel pants....So....back to the drawing board, or just leave them the way I have them....Personally, I like them going all the way to the wheel pants, but if they are designed to work the other way.....ooooops!!
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 12, 2012, 10:37 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Originally Posted by Reef_rc View Post
2nd - anyone using Xoar Props 15x6 PJN electric prop on hacker A30-12XL? What are you using as far as bushing the ensure the prop is center since the standard hole is wider than the prop adapter?
Yep, lots of guys use the 15x6 on 51" Slicks with the a30-12xl.
Use this for a bushing:
http://www.e-fliterc.com/Products/De...rodID=EFLM1960
cut a few 1/2" sections of it and shove 'em in the prop.
ryan_m is offline Find More Posts by ryan_m
Old Nov 12, 2012, 10:47 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
SteveT
I think either way works and I like the idea of the fairing going all the way to the wheel pant. I think I'll make a new set over the winter that is a combination of both.
gremlin is offline Find More Posts by gremlin
Old Nov 12, 2012, 10:48 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Awesome!
Buzzed is offline Find More Posts by Buzzed
Old Nov 12, 2012, 11:01 PM
"Thumbs"
Gilbert, Arizona
Joined Jan 2007
Originally Posted by Buzzed View Post
Awesome!
Thank you.... your pictures were my inspiration for the sunset shots!!
Great time of the year to be in Arizona indeed!
Old Nov 13, 2012, 01:51 AM
SteveT.'s Avatar
San Jose, CA
Well....now I am "bumfuzzled"... I took my fairings off, and checked how the fairings that came with the kit fit, and basically they don't...If you try to fasten them to the back edge of the landing gear, the don't even come close to fitting to the fuselage, as they angle away from it. If you fasten them onto the flat of the gear, then the curve at the fuselage gets in the way, and holds it away from the fuselage...(and of course this makes the gear very thick, and to me, very odd looking.)...And...the fairings shown in the manual are not like the ones supplied, but more like what I made....
Granted, none if this is insurmountable, but this is one time where I think a little clarification in the manual would be nice, rather that just saying...
"Using clear tape, CA glue, or Welder's Glue, install the balsa wood landing gear fairings to landing gear legs as shown. NOTE: the fairings do affect the flight characteristics and you should install them."
SteveT
Old Nov 13, 2012, 06:43 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Nice pict's
And you have your pants on.
jsmith285 is offline Find More Posts by jsmith285
Old Nov 13, 2012, 07:54 AM
Reef_rc is offline
Find More Posts by Reef_rc
Reef_rc's Avatar
Joined May 2011
thx ryan. Will give that a shot.
Reef_rc is offline Find More Posts by Reef_rc
Old Nov 13, 2012, 07:56 AM
Reef_rc is offline
Reef_rc's Avatar
Joined May 2011
I may take you up on it if the other options doesn't work out. thx
As I have a lathe, I can make prop bushings for you for a nominal cost...
SteveT
Old Nov 13, 2012, 09:18 AM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
Steve, like you, I felt the fairing didn't fit well as is. I contoured the long end to the shape of the bottom of the wing. This way I was able to attach the front and the back of the fairing to the fuselage with Welders for a secure mount and to make sure it was parallel to the fuse line. It also did not interfere with the hatch or removal of the wing. I butted the leading edge of the fairing up to the landing gear and attached the two spreading Welders similar to a foamy hinge. I'm sure there are better ways to mount these, just showing the option I went with. I still like the idea of having the fairing go all the way to the wheel pant so I'll either add and extension or make a new one.
Excuse the lousy pics but they are better than a couple thousand words. The view of the fairing is not to scale but you get the idea of how I shaped it
Old Nov 13, 2012, 06:06 PM
SteveT.'s Avatar
San Jose, CA
Yup....agreed.....and here are is a template for those wishing to do the same thing... LOL!! Great minds think alike....
And...from a source I can't disclose....another photo.. the original ones.....Seems very similar to the ones I posted yesterday!!!
SteveT
Old Nov 13, 2012, 07:12 PM
SteveT.'s Avatar
San Jose, CA
Well...after seeing the red ones in the photo, I decided mine were pretty darn close to those, and I also think mine are a bit stronger, so, went with them. I just used tape for the time being, but as soon as I can get some black trim sheet, or find the faux carbon fiber trim sheet I have somewhere I will replace it...
SteveT
Old Nov 13, 2012, 07:57 PM
gremlin is offline
gremlin's Avatar
Joined Dec 2002
Looks good, I like the idea of faux carbon fiber trim. Thanks Steve.
Old Nov 13, 2012, 08:11 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
hanger 9 makes and ultracote that looks like carbon fibre
this would look cool
3drcparts is offline Find More Posts by 3drcparts
Discussion Unofficial 3DHS-Bipe thread. Buzzkill2 3D Flying 139 Jul 07, 2011 12:13 AM
Question 3DHS Bipe? PinkYakRC 3D Flying 127 Jul 03, 2011 10:11 AM
Question Crashed my 3DHS Edge 55 need new planes any advice? bhoges17 3D Flying 11 Jan 26, 2010 12:19 PM
Any news of new GWS P-40??? CryHavoc Parkflyers 5 Sep 05, 2004 10:41 AM
