Old Nov 11, 2012, 05:42 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by Irg View Post
smart.
I usually suffer with papertowel hardened finger tips until I can find the gf's nailpolish remover.
Golden West "Super Solvent" is your friend....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 11, 2012, 05:44 PM
SteveT.'s Avatar
San Jose, CA
Just our of curiosity......have most of you guys installed a screw through the landing gear into the wheel pants on this plane as called for in the instruction manual? It seems to me, that as thin as this gear is, it would be very prone to breaking there....
SteveT
Old Nov 11, 2012, 05:52 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
SteveT
I haven't installed the screw.
zmonster97 is offline Find More Posts by zmonster97
Old Nov 11, 2012, 06:11 PM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I can understand its to keep the pant from spinning but I didn't install the screw either.
Bigster is offline Find More Posts by Bigster
Old Nov 11, 2012, 06:25 PM
SteveT.'s Avatar
San Jose, CA
Hotay..... I didn't either...the landing gear just looks way too thing there for my liking...
Thanks Guys...
SteveT
Old Nov 11, 2012, 10:31 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
didn't use the screw, seems to me it's better that the wheel pants can move a bit rather that rip a part on a not so perfect landing
3drcparts is offline Find More Posts by 3drcparts
Old Nov 11, 2012, 10:34 PM
SteveT.'s Avatar
San Jose, CA
My opinion also.....
And the landing gear fairings seem to be a bit strange to fit...(just my opinion), but really long and have to be trimmed (or am I doing something wrong???)
SteveT
Old Nov 11, 2012, 10:47 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I don't like to say anything bad about 3dhs, but, in my humble opinion, now owning 9 of their planes, the fairing where/are an after though or late into production enhansment and do not fit like they should, I taped mine and they look like........well you know, but they do do the job
Old Nov 11, 2012, 11:00 PM
SteveT.'s Avatar
San Jose, CA
Yeah... I may end up using them as a basic template and make my own, as they really do not fit well...
SteveT
Old Nov 12, 2012, 08:05 PM
SteveT.'s Avatar
San Jose, CA
So....as i said in a previous post, I wasn't very happy with the way the fairings fit, (sorry 3DHS), I decided to make my own. These are made from 3/64th inch balsa and 1/64" plywood on one side, so are a couple of grams heavier, but I am sure the weight won't make a difference. The tops where they meet the fuselage and wing are beveled into two different directions...one to meet with the fuselage, and one to meet with the wing. the bottom ends are also beveled to meet the wheel pants. Here is a photo or the uncovered fairing, and a .pdf file that you can print off to make your own if you like. If you make sure that your printer is set to print at exact size, they will be at the correct size to just trace them off, or print on full size stick on label material and then you can just stick it on the wood and cut them out. You will need to flip the .pdf file to make the other side if you use sticky back material. Sorry, I had already glued one on before I thought of doing the ,pdf file for you guys....
I used Pace, "Zappa-dappa-goo" to glue them on, which is my favorite adhesive for gluing things like this on.
EDIT....my final method of attachment was to just use clear packing tape.
SteveT
Old Nov 12, 2012, 08:30 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
thanks Steve, I saved the file and will make some as time permits
Old Nov 12, 2012, 08:37 PM
SteveT.'s Avatar
San Jose, CA
As soon as the glue dries, and I can get some pics taken, I will post them..
StevdeT
Old Nov 12, 2012, 09:50 PM
Reef_rc is offline
Find More Posts by Reef_rc
Reef_rc's Avatar
Joined May 2011
I did manage to get 1 brief flight in before dark today @ - 5:30 . Brief flight but was fun nonetheless. Take what I can get i guess.
The template will be helpful. Knowing me, it's not a matter if I will break the landing gear; but rather it's when I break the landing gear, the new template will be helpful. The fairing with likely be taken out when the landing gear goes. For the weight and size of this plane, the CF landing gear seems like a weak link to me.
Can't wait to have a few spare landing gears handy once parts are made available. If you guys found a viable alternatives, would love to hear it.
2nd - anyone using Xoar Props 15x6 PJN electric prop on hacker A30-12XL? What are you using as far as bushing the ensure the prop is center since the standard hole is wider than the prop adapter?
Reef_rc is offline Find More Posts by Reef_rc
Old Nov 12, 2012, 10:23 PM
SteveT.'s Avatar
San Jose, CA
As I have a lathe, I can make prop bushings for you for a nominal cost...
SteveT
Old Nov 12, 2012, 11:23 PM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
Steve, thanks for the photo and template but now I'm really confused. Based on the picture it looks like you have the long side of the fairing going along the landing gear and the short side next to the wing. In looking at the pics of the prototype planes and manual with the white fairings that looks like how they go. But the production black fairing is much longer on the long side compared to the landing gear and is tapered at the end. Based on that it would require trimming about 2" off the fairing to get the long side to fit the gear. Most of the build pictures of the production kit have the long side of the fairing along the wing, which is how I mounted mine, assuming it was a part that didn't need trimming. The short side doesn't reach the wheel pant but appears to extend below the top of the wheel pant when looking from the side. I contoured mine to the wing similar to you but did it along the long side. I suppose it will work either way but I am wondering what the "correct" way is to mount the black fairing so as not to confuse folks.
Rick
gremlin is offline Find More Posts by gremlin
Discussion Unofficial 3DHS-Bipe thread. Buzzkill2 3D Flying 139 Jul 07, 2011 01:13 AM
Question 3DHS Bipe? PinkYakRC 3D Flying 127 Jul 03, 2011 11:11 AM
Question Crashed my 3DHS Edge 55 need new planes any advice? bhoges17 3D Flying 11 Jan 26, 2010 01:19 PM
Any news of new GWS P-40??? CryHavoc Parkflyers 5 Sep 05, 2004 11:41 AM
