Old Sep 16, 2012, 06:31 AM
gremlin is offline
Find More Posts by gremlin
What?!? I didn't do that!
gremlin's Avatar
United States, NY, Orchard Park
Joined Dec 2002
Originally Posted by TG43 View Post
Also might want to check where the slot is for the elevator control horn. Mine didn't have a slot on the right side like pics show so I put servo on the left side, but around the servo bay doesn't seem quite as strong so I don't know if that's the best idea. Servo seems fine when deflecting the elevator though (servo doesn't move).
Per the instruction, the elevator servo goes on the left side so you should be all set.
My build is going okay so far but I'll have to check the anti-rotation pin to see if it works okay. I did have to work on the elevator joiner slot a touch to make sure both halves lined up properly.
gremlin is offline Find More Posts by gremlin
Old Sep 16, 2012, 08:02 AM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
I also got excited about the magnets and connected the top wing with the tube. When I pulled them apart it left a magnet behind. Serves me right for rushing it and not hitting stuff with CA like I normally do.
Bigster is offline Find More Posts by Bigster
Old Sep 16, 2012, 09:00 AM
Ablec6 is offline
Find More Posts by Ablec6
United States, GA, Atlanta
Joined Mar 2011
Glad it's not just me. Thanks TG43. How did you repair the wing you "really screwed up?". The sleeve came apart completely in mine also.
The magnets in my wing also came off. I put some thin CA on all the magnets including on the fuselage just in case.
What a beautiful plane!!
Ablec6 is offline Find More Posts by Ablec6
Old Sep 16, 2012, 10:52 AM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Wow you're right. I must have been tired, I thought the pic showed servo going in the right side, lol.
Bummer man. Well, I ended up using just a little welders on the pin then put the wings on to keep the pin centered. Then thin CA after the welders dried. At first I just tried welders but apparently no air could get in there to dry the glue (it sat over night and still wasn't dry). So just to be clear, I didn't use the sleeve...I just permanently glued the anti rotation pin on one of the wing halves
I agree, plane looks incredible.
TG43 is offline Find More Posts by TG43
Old Sep 16, 2012, 02:13 PM
Fredriksson is online now
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
I am getting my Byper assembled. I have the landing gear on and the rudder installed. I am preparing to install the pull-pull rudder system. This is my first pull-pull system. Any tips or tricks? My concerns are crimping the wire holder so that it does not pull loose (what tool to do the crimping?) and getting the cables the right length to be able to adjust properly. And, how do you know when the cables are tight enough?
Thanks in advance for the input.
Freddy
Fredriksson is online now Find More Posts by Fredriksson
Old Sep 16, 2012, 02:18 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
My favorite crimping tool is this Klein crimper... No slippage after using this one....
And cables "snug" but not banjo string tight....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 16, 2012, 02:20 PM
M.Putnam is offline
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Freddy,
Don't sweat the crimp. I have used wire crimpers in the past, but good old pliers work fine. After the crimp, give it a small drop of thin CA. It won't budge.
Matt
M.Putnam is offline Find More Posts by M.Putnam
Old Sep 16, 2012, 03:37 PM
Just having fun
Joined Feb 2008
Thank you Steve T and Matt. I am ready to go for it.
Freddy
Old Sep 16, 2012, 04:58 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
You can spray misting water on CA to dry it. Raid the wife's tackle box for a spray tube as she will.most likely have an empty one.
stgdz is offline Find More Posts by stgdz
Old Sep 16, 2012, 06:42 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Flew mine 6 flights today with 4 being pony rides.....everyone that asked to fly it loved it. Mine handles really well...still dialing it in though...I was flying on wamsy's 4s packs....now I'm home and will solder some connectors on my packs. Will fly it this week at lunch!
Bivens is offline Find More Posts by Bivens
Old Sep 16, 2012, 08:09 PM
Ablec6 is offline
Joined Mar 2011
Any tips on mounting the LG flarings? Manual says clear tape, CA or welders glue. Pics would be helpful.
Otherwise, ready for maiden!! What a great looking piece and excellent quality as expected from 3DHS (although a bit pricey at $300.) Why does it have to rain next 2 days???!!? Arrghh!
Old Sep 16, 2012, 08:10 PM
Dennis C is offline
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Thanks in advance for, the input.
Freddy
Go to your local fishing tackle shop and get a crimper, generally around $10.00
I have never had good luck with the plyers, many have, but these work great and you are going to be building a lot models with pull pull. Haveing the right tool will make life easy.
Dennis
Dennis C is offline Find More Posts by Dennis C
Old Sep 16, 2012, 08:22 PM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Got a few flights on mine today. It was fun so I'm happy. Does awsome KE spins. Roll rate might give my friends little Slick a run for it's money, lol. It took a ton of mix for ke, but that's fine. Still tweaking a lot. My friend said he thought it was going to be a lot smaller. Looks awsome in the air.
Old Sep 16, 2012, 08:59 PM
SteveT.'s Avatar
San Jose, CA
I like "Zap a Dap a Goo" for things like this...
SteveT
Old Sep 16, 2012, 09:01 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Looks good!
Discussion Unofficial 3DHS-Bipe thread. Buzzkill2 3D Flying 139 Jul 07, 2011 12:13 AM
Question 3DHS Bipe? PinkYakRC 3D Flying 127 Jul 03, 2011 10:11 AM
Question Crashed my 3DHS Edge 55 need new planes any advice? bhoges17 3D Flying 11 Jan 26, 2010 12:19 PM
Any news of new GWS P-40??? CryHavoc Parkflyers 5 Sep 05, 2004 10:41 AM
