Sep 16, 2012, 01:47 AM
San Jose, CA
Originally Posted by TG43
I had trouble with that as well. The pin went in one wing fine but would not go in the other wing. The sleeve didn't have glue in it either, it just seemed too small. I tried drilling and out and really screwed it up, the sleeve came loose inside the wing. I ended up removing the sleeve and welders-gluing the pin in one of the wings. All I can suggest is don't force it or pin will get stuck. Maybe try sanding your anti rotation pin.
Also might want to check where the slot is for the elevator control horn. Mine didn't have a slot on the right side like pics show so I put servo on the left side, but around the servo bay doesn't seem quite as strong so I don't know if that's the best idea. Servo seems fine when deflecting the elevator though (servo doesn't move).
Couple of my magnets in the wings came out, a little thin ca from the back side took care of them.
When you have a problem like that.....never use a power drill....always use the drill bit in your fingers.....too much chance of spinning the piece loose, like what happened to you. If you have a "pin vise" that is the best thing to use....if not, then as noted, just your fingers....
SteveT
Latest blog entry: My hangar...
