Old Aug 17, 2012, 10:28 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Originally Posted by sukhoi26mx View Post
Both, but we added wing bolts on the bottoms just to "be sure"...
Scott
thanks scott, is there anyway you can post the linkage setup for the top and bottom wings? I saw the video of the magnets but is it just a standard linkage setup and we don't disconnect it during transportation?
stgdz is offline Find More Posts by stgdz
Old Aug 17, 2012, 10:34 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by Inverted-I-Fly View Post
I get the feeling we are getting closer seeing how Scott is popping in here (great article in the last AMA magazine by the way and I'm just about through your book, great read)
PS orange flys better in the slick
I have a red 59" Slick (no orange when I bought it were available), but have a 71" orange Slick, and an 89" orange..
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Aug 17, 2012, 10:37 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I "think" the wings are going to come off as pairs (right pair, left pair), so aileron linkages will stay hooked up.
SteveT.
Old Aug 17, 2012, 10:54 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
check out about 4:22 on this video
2012 Wram Show Behind the Scenes (15 min 1 sec)
I'm actually a bit worried the magnets are going to be so strong that when you pull off the top wing, your going to rip the aileron linkage out
3drcparts is offline Find More Posts by 3drcparts
Old Aug 17, 2012, 10:57 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Wow, considering that was dated March 14th, 6 months looks to be about right
Old Aug 18, 2012, 07:45 AM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
The wings stay together as pairs, so you don't have to fuss the aileron linkages, or the interplane struts except during the initial assembly of the model. Just unscrew the wing bolt, unplug the servo extensions and remove the wings with each side being a set.
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Aug 18, 2012, 08:51 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Scott
do the two wing then kinda collapse and fold flat? Are wing bags included like usual?
Old Aug 18, 2012, 09:00 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Scott
Scott,
If both top and bottom panels are removed but remain connected by the interplane strut, aren't the wings and strut prone to damage as there is nothing holding the inner ends of the wings apart so the strut to wing connection could see large bending moments?
Or are the interplane strut to wing connectors 'hinged' to allow the assembly to fold flat?
Oops.. i see inverted asked much the same question already
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 18, 2012, 09:58 AM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
I understand your concerns, which we shared.
For the solution. Simply slide the wings onto the two wing tubes for transport. Once removed from the fuse, set the wings on a flat surface resting on the LE. With both wings off, slide them onto the wing tubes and you've got a very rigid and secure setup for transport. See the photos...
Oh, and no wing bags. No real reasonable way to do that.
Scott
Old Aug 18, 2012, 10:54 AM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Any idea on price scott?
Old Aug 18, 2012, 03:29 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Scott, if you have a chance can you measure the height of the plane with the wings on, table to highest point. I want to see if this will fit in my truck with the wings on and my bakflip cover closed
Old Aug 18, 2012, 03:31 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Above my pay grade... I have never made those decisions, thankfully.
Scott
Old Aug 18, 2012, 03:39 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Both fin and top of rudder at 13" +/- 1/8".
Scott
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Looks like its no taller than the slick as the canopy is taller than the top wing.
I would hazard a guess that ifvtge slick is a tight fit after the canopy this one may not work.
Scott
figured but it was worth a shot
Old Aug 18, 2012, 03:47 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Scott
thanks for the quick response, it will fit perfectly, so wings will stay on.
going to the wings over wind country tomorrow, wish you were flying, but I do get to see Tim Weber which should be good
Discussion Unofficial 3DHS-Bipe thread. Buzzkill2 3D Flying 139 Jul 07, 2011 12:13 AM
Question 3DHS Bipe? PinkYakRC 3D Flying 127 Jul 03, 2011 10:11 AM
Question Crashed my 3DHS Edge 55 need new planes any advice? bhoges17 3D Flying 11 Jan 26, 2010 12:19 PM
Any news of new GWS P-40??? CryHavoc Parkflyers 5 Sep 05, 2004 10:41 AM
