Old Feb 12, 2013, 06:46 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by Diesel6401 View Post
Apc 12x8 or 12x10. I'm running a 12x10 but mine is loaded pretty heavy with r retracts lighting mods and repair weight. I fly around at mostly 1/2 to 3/4 throttle and she moves nicely. I've done cooling mods though including a new one yesterday that works BEAUTIFULLY by making the exhaust stacks functional for esc cooling and tested it today and she's awesome. I also made the the scoop at the bottom functional.
I had to drill the opening out of the apc to get it to fit. No big deal.
Have you tried both sizes?
Do you use the 3200mAh
I do have the Gens Ace 3200 & 3300-mAh 3S.
Thanks.,
Spyro
Spyro37 is offline Find More Posts by Spyro37
Old Feb 12, 2013, 07:06 PM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Originally Posted by tclaridge View Post
With the price reduction on the Hurricane, I thought I would collect my setup for folks just starting out. I have attached a document of all the settings, dual rates, and tips that helped me. Many of them come from this thread.
Here's the post with the PDF file. Hope this helps.
GhostStone is offline Find More Posts by GhostStone
Old Feb 12, 2013, 07:08 PM
Soli Deo Gloria
GhostStone's Avatar
Joined Jan 2012
Sorry let me try again.
It's post 3527 and it is on page 236. Sorry for the confusion.
Old Feb 12, 2013, 08:27 PM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Thanks.,
Spyro
I'm using 12x10 my buddy is using 12x7. I bought the 12x8 and used in a different plane and snapped it on a tip-landing in 20mph on a crosswind landing. I have no doubt it will be good. I'm using 3300 and 3200. I have eflite, zippy & turnigy. The packs you have should be just fine. Gens ace are excellent packs.
Diesel6401 is online now Find More Posts by Diesel6401
Old Feb 12, 2013, 08:41 PM
Helldiver is offline
Find More Posts by Helldiver
my Head is Spinning!!!
Helldiver's Avatar
Joined Aug 2012
thanks for this!
I hope no more nose overs this weekend!
Helldiver is offline Find More Posts by Helldiver
Old Feb 12, 2013, 09:11 PM
Loukhan is offline
Find More Posts by Loukhan
Loukhan's Avatar
United States, CA, Oceanside
Joined Apr 2012
Coot- thanks for the clarity.
Spyro-happy to hear about your maiden!
Tom- I'm not a speeder. I like it scale. I do not want to do 100mph (too old, too bad of eyes). Plus, I find my flying improves w/practice at slower speeds. As my flight instructor told me-if you can fly slow you can fly anything.
Diesel- thanks for the information.
Loukhan is offline Find More Posts by Loukhan
Old Feb 13, 2013, 12:01 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Hey Diesel!!
Since the weather sucks giant monkey butts for the next few days, I'll have time to do the exhaust stacks. Can you tell me, or point me to the post on how you mod the stacks for air flow? Thinking of doing the scoop too. One idea for those thinking about which plane to paint theirs as, choose a Tropic version. They had an intake right under the nose that would be an awesome mod for cooling!
Moonbeam is offline Find More Posts by Moonbeam
Old Feb 13, 2013, 06:57 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Originally Posted by Moonbeam View Post
Hey Diesel!!
I should have taking pics as I went along, but I'll describe best I can.
*I took a old unused soldering iron and put an x-acto blade tip on it and heated the iron up.
*while the iron was heating I removed the stacks
*I used the iron to notch into the front of the stack up to where it starts to curve
* pulled the esc out of its stock location
*I cut a 1/4 x 1/4 square into the plane under the stacks about 3/4 of the way back of the stack area .
*I then made a angled cut forward of that so air flows smoothly into the hole
*I drilled a hole into the rear of the last stack
*reinstalled the esc and verified I could see it through the holes I cut.
*hot glued the stack back on
I really wish I would have taken pics, but it was a spurt of the moment.
Old Feb 13, 2013, 08:42 AM
Loukhan is offline
Loukhan's Avatar
Joined Apr 2012
That sand scoop would do the trick I think. Looks like it would be fairly easy to stretch the intake.
Old Feb 14, 2013, 12:09 AM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Anyone using a 2p3s2650mAh setup?
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Dayum Fine Custom Pilot
Old Feb 14, 2013, 04:19 PM
Plane Chaos is offline
Find More Posts by Plane Chaos
Joined Dec 2009
Do you mean two separate 3s 2650 mAh packs in parallel ?
... or a 'single' 2p3s pack?
Plane Chaos is offline Find More Posts by Plane Chaos
Old Feb 14, 2013, 04:46 PM
USA, GA, Atlanta
Joined Nov 2008
I fudged that
Yes two seperate 3s 2650 packs in parallel
Old Feb 14, 2013, 05:09 PM
Joined Dec 2009
I fudged that
... there was some discussion back around page 240 (e.g. post #3593, by "sdossett").
.... I don't recall reading outcomes, but it ought to be do-able; just make sure you maintain C-of-G in the 'squares"..
Old Feb 15, 2013, 04:37 AM
sdossett is offline
Find More Posts by sdossett
United States, IL, Urbana
Joined Jan 2005
Multple 3S batteries
First one goes in well into slot. Second one needs more work to attach.
I just bought a couple more 4000mah 3S batteries.
Once the winds here die down a bit and I can get in some flight time, I may experiment with the 1800-2200mah packs I have. For now I'm playing it straight.
sdossett is offline Find More Posts by sdossett
Old Feb 15, 2013, 02:54 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
Flew three packs through it yesterday. The more I fly it, the more I love this plane. The only down side is that I used to think that my P-47 and Corsair were fast until I flew this one. Now, after flying the Hurricane, the P-47 and Corsair (F4U1A) are nice and still great flying planes, but the Hurricane just rips through the air with such command and steadiness.
I made 13 landings, and all except the first were greasers (the first was good enough, but was a little bumpier than I'd like). I think I finally have the throttle timing down with the descent. It also helps to have the plane trimmed for landing using programming on the DX8 so that you can literally land the plane using throttle and rudder/aileron with just a touch of elevator at the very end. Quite satisfying. Like ryramZ said in his video with the Hurricane, it does prefer a good approach, and if you do it right, you're rewarded with some of the most spectacular and beautiful landings.
Here's a picture of it on the table at the field yesterday with my Jug and F4U1A.
Edge767 is offline Find More Posts by Edge767
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4129 Jul 01, 2016 12:17 AM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 04:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
