Old Feb 02, 2013, 06:32 PM
Loukhan is offline
Find More Posts by Loukhan
Loukhan's Avatar
United States, CA, Oceanside
Joined Apr 2012
Maidened mine today- SMASHING GOOD! 2 clicks R ail, 1 click U ele- that was it. I had taken 1 1/2 wks to set up (little bit of time over a few nights-adding lights, venting via radiator, and a bit of detailing).
2 nose-plant landings till I felt her out, then the best 2 wheel landings I've ever made. Keep some power in when using flaps. She rolls out a long ways-used 100' of runway on landing and 40'&20' on takeoff. Just a beautiful plane. Funny how you can find something that fits just right. Now I gotta drop some $ on more batts or convert to 4s 2200's.
*1)-ESC was much warmer than any I've had so I'm gonna drop in a castle 75 lite ice.
*2)-definitely locktite landing gear, mine came loose but no damage.
Loukhan is offline Find More Posts by Loukhan
Old Feb 02, 2013, 06:47 PM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
Caution do not use Locktite on plastic! Will eventually eat away at plastic.
Tim
w4yn is offline Find More Posts by w4yn
Old Feb 02, 2013, 06:51 PM
Plane Chaos is offline
Find More Posts by Plane Chaos
Joined Dec 2009
Tim
+1 on this sound advice
Plane Chaos is offline Find More Posts by Plane Chaos
Old Feb 02, 2013, 06:57 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
Originally Posted by Inverted-I-Fly View Post
I saw that going through the attachments, looks good, but my wing is already in place, I also think there needs to be a vent hole,
anyway I move my esc back into the bay and cut a vent in the underside, at least now it is not sitting on top of the batteries sandwiched in foam and should get some air flow will test tomorrow
much better, barely warm on 3 cells, but got hot on a 4s, going to just fly it on 3s for now, nice relaxing plane to fly, slows to a crawl with full flaps and has a great presence in the air, flys great in the wind
3drcparts is offline Find More Posts by 3drcparts
Old Feb 02, 2013, 07:04 PM
Edge767 is offline
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
I use the Spektrum telemetry module on my Hurricane and the ESC never gets above 135 degrees Fahrenheit at any time. That's not too hot. I'm flying 3300 30C 3S batteries in mine.
Edge767 is offline Find More Posts by Edge767
Old Feb 02, 2013, 07:11 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
too hot for me, when esc's go they go from hot to thermal melt down in 3-5 seconds, telemetry is not going to warn you.
castle ice 100a in my 74
Old Feb 02, 2013, 07:21 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
Wow, quite a meltdown. My esc sort of "cooked" the batteries, they all came down hot on one side, and after a while, even just taking off at full throttle caused the batteries to sag below 9.9v. The first time I thought I had forgotten to charge the battery. Toasted 3 out of my 4 batteries, which forced me to go to 4s.
copperbricks is offline Find More Posts by copperbricks
Old Feb 02, 2013, 08:06 PM
mondo1948 is offline
Find More Posts by mondo1948
mondo1948
mondo1948's Avatar
Rocky Hill, Connecticut
Joined Dec 2007
Hi,
When you say your ESC "cooked" the batteries, are you talking about the Hawker Hurrican'es E-Flite 60 amp Pro ESC and the stock 3-cell 3200mah battery? I'd just like some clarification. I also wondered why you went to 4-cell battery and what ESC you're using with it?
Mondo
mondo1948 is offline Find More Posts by mondo1948
Old Feb 02, 2013, 08:13 PM
redbarn is offline
Find More Posts by redbarn
United States, OR, Irrigon
Joined Sep 2011
Maidened mine today and it flies very nice and stable. Good speed and thrust. I am using an FMS 11x9x3 prop from their 1400mm cessna 182 I think. I don't know if the pitch is really 9 but that is what it says on it. Du bro spinner with a washer and a regular nut in front of the prop. I did not need the big heavy prop nut for nose weight. Battery slid all the way in for CG at about 2-3/4" It pulls around 45 amps and 450 watts at 11 volts. Nice flying plane.
redbarn is offline Find More Posts by redbarn
Old Feb 02, 2013, 08:18 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Well, there goes my spare Cessna prop
Aphro is offline Find More Posts by Aphro
Old Feb 02, 2013, 08:20 PM
redbarn is offline
Joined Sep 2011
Ha! You won't really miss it on that thing.
Old Feb 02, 2013, 08:30 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Did you use the same Dubro spinner mentioned earlier in the thread?
Old Feb 02, 2013, 08:40 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Very nice redbarn! This thing is screaming for a 3 blader. First order of business for mine but I figured i would need to go 4S to spin it.
What is the diameter of the spinner?
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Feb 02, 2013, 08:51 PM
Loukhan is offline
Loukhan's Avatar
Joined Apr 2012
w4yn/chaos-loctite on landing gear strut retainer screw, not on mounts. The screw backed off the flat spot on the LG strut. (I should have been clearer)
RE:
ESC-I don't know what the temp was but hot enough that I didn't want to hold my finger on it very long but wouldn't cause any pain, just not pleasant.
landing length- I like to land as scale as I possibly can, (letting the tail drop on its own).
Old Feb 02, 2013, 09:29 PM
Loukhan is offline
Loukhan's Avatar
Joined Apr 2012
This could get ugly!
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4128 Jun 25, 2016 08:09 AM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 04:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
