Espritmodel.com Heli Air
Old Feb 01, 2013, 04:07 PM
Joined Jan 2005
3 blade
Elsewhere on this forum there was a suggestion to use the bf109 3-blade from Parkzone. I found them, PKZ4901, but could not find the JR 2.75" 3-blade spinner also referred to, nothing in Dubro, Dave Brown,EFLite either. I have not picked my plane up,so have no measurements on the diameter of stock spinner.
Please post if any news.
sdossett is offline Find More Posts by sdossett
Old Feb 01, 2013, 04:08 PM
Eat, Fly, Dream, Repeat...
IfIHadWings's Avatar
United States, GA, Jefferson
Joined Jun 2012
My BNF is still in the box, but you guys are inspiring me to do my first weathering and paint change project seeing all the paint mods here!
I know someone previously mentioned the FlyRC review of this plane (March 2013), but there is another article in of the same mag...Simple Weathering Techniques and they demonstrate it on the Eflite Hurri 25e. Some subtle but very effective changes.
IfIHadWings is offline Find More Posts by IfIHadWings
Old Feb 01, 2013, 04:31 PM
Mesa, AZ
Joined Mar 2011
Originally Posted by voxel View Post
Yeah, my manual stated 3.50" to 3.75" (wrong, wrong, wrong) but I saw the addendum on the Eflite website the day I bought the plane. I used 3" CG and still the plane felt tail heavy. Can't imagine the crashes the original one caused.
From post 3248:
Here are some dates from this thread:
Feb. 2, 2012 … Hurricane became available in the US.
Feb 19, 2012 … First mention by user of incorrect CG in manual, should be 2.75”
April 9, 2012 … HH admitted on this thread that manual’s CG was incorrect and should be 2.75”.
June 2012 … Date of printed correction memo sheet.
Later still … Memo apparently included with all shipped Hurricanes.
Today … Manual’s CG still is not corrected.
This CG problem has been mentioned on this thread for almost a year. The best place for Hurricane CG info ... this thread!
RT
Retiredtech is offline Find More Posts by Retiredtech
Old Feb 01, 2013, 05:02 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by Plane Chaos View Post
... there should have been an adendum notice to this effect in your box (...main manual is incorrect)
... officially acknowledged by HH some time ago.
FWIW~ I did not have an addendum in my box; but had read the thread...
Originally Posted by Babadush View Post
Some of you might already do this. When I'm using different batteries in this plane(i use 3200 and 5000 3s) I get the cg right and then mark the inside of the battery bay. I do this for different batteries and I mark a spot for "wind" and move the battery notch a half inch forward. That way once it's marked I never have to balance again unless I buy different batteries.
Did you have to make any modifications to fit the 5000mAh battery?
bsbauman is offline Find More Posts by bsbauman
Latest blog entry: Burned Retina Shorts
Old Feb 01, 2013, 05:43 PM
Inverted-I-Fly's Avatar
United States, CA, Petaluma
Joined Mar 2011
Maiden today was a success, she flys great, but even on my 3S packs the esc was getting hot, what are people doing to increase airflow
Inverted-I-Fly is offline Find More Posts by Inverted-I-Fly
Old Feb 01, 2013, 05:47 PM
Joined Dec 2009
It may have been a previous post of mine you encountered:-
In which case I think there was a typo in there
....pack was labelled "JP" (i.e.J Perkins) ... not "JR).
... will correct that post.
Link here:-
http://www.jperkinsdistribution.co.u...tname=Spinners
Although the prop and spinner fitted together nicely, (and I now do have a spare PZ bf109 prop) .... I havn't actually tried it yet !! ... cautious of some comments from other folk in here, that the 109 prop might over-amp the stock power train I currently have; keep to meaning to put my meter on it.
Meanwhile, I'm still flying with the stock prop.
Plane Chaos is offline Find More Posts by Plane Chaos
Old Feb 01, 2013, 07:20 PM
Joined Jan 2005
Spinner
Thanks Chaos. I'll follow that URL!
Old Feb 01, 2013, 08:01 PM
Buzzcut2239's Avatar
United States, NJ, Gloucester Township
Joined Jan 2012
Cooling ESC
I hollowed out the scoop and made it functional. Where the scoop goes over the wings and body I cut that out also to let the air in. I then cut relief holes in the bottom of the tail section. I havn't maidened the plane yet due to poor weather but these mods should help.
Buzzcut2239 is offline Find More Posts by Buzzcut2239
Old Feb 01, 2013, 08:23 PM
Joined Mar 2011
I saw that going through the attachments, looks good, but my wing is already in place, I also think there needs to be a vent hole, anyway I move my esc back into the bay and cut a vent in the underside, at least now it is not sitting on top of the batteries sandwiched in foam and should get some air flow will test tomorrow
Old Feb 01, 2013, 08:42 PM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
I did the scoop mod also and made some exit holes out the back. maidened and crashed (camo works really good especially at dusk ) but the esc wasn't hot
Diesel6401 is online now Find More Posts by Diesel6401
Old Feb 01, 2013, 08:52 PM
Joined Mar 2011
that sucks, ya I can see this disappearing quickly at dusk
Old Feb 01, 2013, 08:59 PM
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
Nope. It's a Venom 5000mah I got from a hobby shop a while back. It slid right in. It's great for longer flight times. I get 12 min scale flying.
Babadush is offline Find More Posts by Babadush
Old Feb 01, 2013, 10:32 PM
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
I saw this on sale today for a steal in a BNF. Only issue is I don't have any 3200 batteries but tons of 2200 ones. Can I run 2 2200/11.1 in parallel in this plane? I would preference not to have to buy more batteries right now.
jrtubb is offline Find More Posts by jrtubb
Old Feb 01, 2013, 10:44 PM
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
If they fit, you can. I am going to be doing exactly same thing and having 4400mah will just give you a bit longer flight times. There is really no reason why you would need to buy the extra lipos
Koo is offline Find More Posts by Koo
Old Feb 01, 2013, 10:46 PM
RCAirTrainingCommand
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Fall issue of Park Pilot has a review of the Hurricane that mentions the CG addendum along with the updated measurements.
ryramZ is offline Find More Posts by ryramZ
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 3501 May 16, 2013 07:04 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 3 Dec 19, 2010 08:39 AM
