Old Jan 31, 2013, 08:03 PM
Coot83 is offline
Find More Posts by Coot83
You haz hurricane?
Coot83's Avatar
United States, VA, Alexandria
Joined Jun 2012
I thought on 4s people were getting around 70 amps...I will def make some breather holes for this bird.
Coot
Coot83 is offline Find More Posts by Coot83
Old Jan 31, 2013, 08:13 PM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Hey guys, I'm not sure if I am even suppose to post this. But I came across a couple of PNP e-flite Hurricanes on ebay for 149.99 with free shipping. Not as good a price as some of you got but still a great deal. If anybody still wants one, this would be a good chance to pick one up.
GhostStone is offline Find More Posts by GhostStone
Old Jan 31, 2013, 08:26 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
My money says they are from people who picked them up for $110 and trying to turn a buck.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 31, 2013, 08:27 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
I would bet that too, either way it is better than the regular deal that was available last month.
Coot
Old Jan 31, 2013, 08:29 PM
Retiredtech is offline
Find More Posts by Retiredtech
Joined Mar 2011
[Removed by User
Retiredtech is offline Find More Posts by Retiredtech
Old Jan 31, 2013, 08:31 PM
Charley38 is offline
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Takeoff?
Nice photos, thanks. Is #1 of a takeoff?
CR
Charley38 is offline Find More Posts by Charley38
Old Jan 31, 2013, 08:32 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by Inverted-I-Fly View Post
just watt tested the stock set-up on 4s, 87amps at 1247 watts, I guess I need to find a 3s that will fit
Or just change the prop and retain your 4s...
Sammy70 is offline Find More Posts by Sammy70
Old Jan 31, 2013, 08:33 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
OK, two 1800mah in parallel I get 59.85 amps and 685 watts
3drcparts is offline Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
what prop are others running on 4s
Old Jan 31, 2013, 08:37 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
11x7 APCe
Old Jan 31, 2013, 08:44 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
That's what I run. The power is more than adequate, with better flight times than with 3s, even with a 2800mah. For performance more like the stock setup on 4s, an 11x6 would work. I'm going to test an 11x8.5, and see if can get a tad more power with (hopefully) not too much more current draw.
copperbricks is offline Find More Posts by copperbricks
Old Jan 31, 2013, 08:55 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
How does batteries in parallel make a difference in amp draw vs one solid battery? I got no problem making my prop smaller too, is .5 that much of a difference in amps?
Coot
Old Jan 31, 2013, 09:20 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
Im going to make sure that my ESC is configured right, is stock settings for an 80 amp ESC set up for 3s? I ask because I notice in the manual it states that the timing is 15 degrees which I think is 6 poles by their manual which I assume is related to the cell count? Any help on this is appreciated.
Coot
Old Jan 31, 2013, 09:31 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Coot
Motor timing is also related to wind type (y or d)... D winds normally enjoy lower timing, y winds normally higher timing. 7.5 is normally a safe starting point if wind type is not known. The wrong timing per wind will result in more heat/amp w/o gain in performance.
Diesel6401 is offline Find More Posts by Diesel6401
Old Jan 31, 2013, 09:40 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
Since15 degrees is stock settings, should I assyme that means neutral for wind then? Im just afraid that the esc wont be calibrated for 4s.
Coot
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4122 Apr 10, 2016 04:31 PM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 04:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
