Old Jan 30, 2013, 07:57 AM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
EFLG200
EFL297519
mike2663 is online now Find More Posts by mike2663
Old Jan 30, 2013, 08:27 AM
Coot83 is offline
Find More Posts by Coot83
You haz hurricane?
Coot83's Avatar
United States, VA, Alexandria
Joined Jun 2012
I am in the process now of converting mine to the sea hurricane...might need some more paint. With all my buddies flying this, gotta have a little identification.
Coot
Coot83 is offline Find More Posts by Coot83
Old Jan 30, 2013, 09:47 AM
Loukhan is offline
Find More Posts by Loukhan
Loukhan's Avatar
United States, CA, Oceanside
Joined Apr 2012
Welcome Bradley, Thanks Chaos-great info.
Interested in answer to question posted- what to do to convert to 4s and (someone else's ?)-what 3 blade prop to use?
Loukhan is offline Find More Posts by Loukhan
Old Jan 30, 2013, 10:47 AM
Babadush is offline
Find More Posts by Babadush
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
Isn't it amazing how much this thread jumped once the price was reasonable?
Babadush is offline Find More Posts by Babadush
Old Jan 30, 2013, 10:53 AM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
$129 for BNF is more than reasonable! Didn't know the BNF included flap servos. The lipo + charger are useless to me though.
Comparing it side by side with my Parkzone T28 - it's not much better (maybe 2-3 inches on the wings). Somehow I was expecting this to be a monster...
Overall the foam and build quality is a large notch higher than the T28. Justifies the bigger price but marketing never communicated that.
voxel is offline Find More Posts by voxel
Old Jan 30, 2013, 11:22 AM
mondo1948 is offline
Find More Posts by mondo1948
mondo1948
mondo1948's Avatar
Rocky Hill, Connecticut
Joined Dec 2007
Hi,
Don't forget it also comes with the Spekktrum AR600 receiver installed. Great deal.
If you don't need the battery, just sell it on this forum....you'll get at least $20.00 for it.
Mondo
mondo1948 is offline Find More Posts by mondo1948
Old Jan 30, 2013, 11:43 AM
BrownEyedFool is offline
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
I'm not in a hurry on this bird, but do want to be prepared.
Am I right that you only need the pre-bent struts if you are adding the retracts?
Considering this is now discontinued and out of stock, should I be concerned about availability of the pre-bent struts moving forward? If there's going to be an issue on them I'll end up moving my purchase of retracts for it up and get a set or two of the struts. Parts availability moving forward may be an issue.
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Jan 30, 2013, 11:49 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
You do not need the pre-bent struts if you don't mind using a Dremel cut off wheel. It is real easy: slide on the wheels to the stock retract strut and bolt in place in the retracted position, center the wheel in the well and mark the end of the strut with a Sharpie, take the gear out and cut at the mark.
It also helps to put a little flat spot on the strut where the wheel collar set screw is. This permits the wheel from rotating on the strut. I have done many retracts this way, and it works great. Just make sure to get everything straight, or a little toe in. Measure twice . . .
tclaridge is offline Find More Posts by tclaridge
Old Jan 30, 2013, 11:51 AM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
I spoke to HH earlier this week regarding the Scimitar parts and how vertical fins are already out of stock. They said more parts are expected in Feb; I would imagine the Hurricane also has more parts coming, I hope.
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Jan 30, 2013, 11:54 AM
USA, GA, Atlanta
Joined Nov 2008
With the amount of these that got sold in the Atlanta Area, I am considering a paint job as well... but for now I just want to fly it!
@Moonbeam~ What other sources do you use for researching, aside from Google Images?
Old Jan 30, 2013, 02:59 PM
USA, GA, Atlanta
Joined Nov 2008
You all wonder why HH was letting these go at rock bottom prices?
To make room for new toys: http://www.rcgroups.com/forums/showthread.php?t=1821114
Old Jan 30, 2013, 03:04 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
The secret to getting good results in Google is what you type in the search. I have around 80 paint schemes for the Hurricane saved to my PC with back history for about 50% of them. It's actually one of my favorite things about these RC warbirds, finding paint schemes and history behind some of them. Makes you appreciate the model a little more.
Here's a link to one on Ebay that ain't too bad. Shipped to me it would be $215.
http://www.ebay.com/itm/E-Flite-Hawk...74760236?#shId
Moonbeam is offline Find More Posts by Moonbeam
Old Jan 30, 2013, 03:15 PM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
Are you sure you're looking at the right plane? This thing is bigger than the P-47 which is bigger than the T-28, and it flys MUCH better than both combined! It doesn't get knocked around like the T-28, and is much smoother flying than the P-47. Could be because...... wait for it..... it's bigger?
Old Jan 30, 2013, 03:18 PM
Coot83 is offline
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
I was shocked when I went on eflite this morning and noticed the new aircraft that had cranked out as well...$1000 glider...granted it is as long as my truck probably.
Anyway I am going to add weathering to it probably tomorrow after I do some experimentation with some paints...Hope these pics can do this bird some justice, beware, the photo quality is not that great.
Coot
Old Jan 30, 2013, 03:23 PM
Babadush is offline
Babadush's Avatar
Joined Aug 2012
Coot
That turned out awesome.
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4104 Oct 11, 2015 02:51 PM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 05:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 11:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 11:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 12:17 PM
