Espritmodel.com Heli Air
Old Oct 15, 2012, 02:19 PM
Joined Dec 2009
Originally Posted by GP73 View Post
Right, just drill the hole bigger for the pre-bent struts, correct?
I missinterptreted: I thought you were swapping a trunion from a dead 15-25 unit, into a diss-used 10-15 body.
If you are going to drill out a 10-15 unit, you will need to drill both the plastic trunion AND the metal axle piece; but I caution you that both need to be true interference fit with the 15-25 strut wire, any oversize will manifest as lateral 'wobble' in the strut.
Do not attempt to drill the platsic trunion and metal axle 'one within the other', else the frictional heat arsing when drilling through the metal, will melt the plastic trunion.
I believe the 15-25 strut gauge is 3.5 mm.
Plane Chaos is offline Find More Posts by Plane Chaos
Old Oct 15, 2012, 04:16 PM
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
nevermind
Babadush is offline Find More Posts by Babadush
Old Oct 15, 2012, 04:48 PM
Joined Dec 2009
Originally Posted by Babadush View Post
I was messing with ecalc and decided to put in the Hurri's data with motor. Is this accurate with a 3s battery? 11min full power and 18min mixed flight time? That seems like an unusual amount to me. I asked my buddy but he flies on 4s so he couldn't comment. I posted a screen shot. Is the information I entered correct?
Hi Bddsh,
You might try re-entering data and re-hitting the "calculate" button again.
.... the performance prediction fields only then update themselves.
I suspect your screen capture image was pre-update.
I would anticipate predicted mixed-flight times of only half that on a 3300 mAh pack ... still well plenty though.
Old Oct 15, 2012, 05:16 PM
Babadush's Avatar
Joined Aug 2012
Originally Posted by Plane Chaos View Post
Hi Bddsh,
I accidentally entered .26 ohms instead of .026 it made a huge difference haha. I was baffled.
Old Oct 16, 2012, 04:29 AM
So where does this bit go???
Redzed9's Avatar
United Kingdom, England, Essex
Joined May 2011
I'm in
Well, at this price I've crumbled and ordered from Austria..
No idea how I'm going to explain this one to the Boss??
Is this the best thread for "cheaper" retracts and detailing information? I've searched the attachments and seen some info. I just wondered if there was a build and modification thread somewhere I can't find?? I think an open canopy with some extra detail inside might be called for...
Any tips and pointers would be much appreciated.
Chocks away Ginger
Redzed9 is online now Find More Posts by Redzed9
Old Oct 16, 2012, 09:00 AM
Redzed9's Avatar
Joined May 2011
Battery Size
I'm thinking of getting some 4000mAh batteries for this one, 30C or above??
Can someone advise what the max size I can go to with the battery tray in this plane, as the choice in battery size is HUGE
Also HH advise a 3200 30C in their blurb, is there any danger in going for a higher rated C rating?? I've seen 35-90C ranges stated in some sites, and am a bit confused. I know the higher C rating gives you a bit more ooomph at WOT.... well that's what I've been told
Any advice appreciated...
Old Oct 16, 2012, 10:42 AM
Joined Oct 2011
Grind down the fat strut with a dremal. I'm having the same issue. If you drill it wrong your retract is toast. If you mess up grinding the strut you will still have the original that came with the retracts. Which you can then put in a vice and bend to get a 90 degree angle.
Pjuran is offline Find More Posts by Pjuran
Old Oct 16, 2012, 11:25 AM
Canada, ON, Toronto
Joined Jun 2010
Good idea, but wouldn't that weaken the strut?
BTW the trunnions can be replaced as well, I actually think I have a couple of metal ones that fit the E-Flite retracts, I also have a couple of ChangeSun retracts that are drop-in replacement for the E-flite 10-15 (the purple ones from HK). Plus some PingZheng retracts as well.
I'm a "retracts aficionado"....
GP73 is offline Find More Posts by GP73
Old Oct 16, 2012, 11:30 AM
Babadush's Avatar
Joined Aug 2012
BTW the trunnions can be replaced as well, I actually think I have a couple of metal ones that fit the E-Flite retracts, I also have a couple of ChangeSun retracts that are drop-in replacement for the E-flite 10-15 (the purple ones from HK). Plus some PZ retracts as well.
Wait. We pay 90 dollars for retracts and they have plastic trunnions?
Old Oct 16, 2012, 11:48 AM
Canada, ON, Toronto
Joined Jun 2010
Isn't that what Plane Chaos said earlier?
I can double check once I get home, but as far as I remember they do have a plastic trunnion.
These are the drop-in replacement with metal trunnion:
http://www.x-flight.com.hk/index.php...&more=&lang=en
You can find a picture of the measurements on this page:
Old Oct 16, 2012, 11:58 AM
Babadush's Avatar
Joined Aug 2012
Thanks I'm doing that and selling the other ones. I didn't know or see someone say they had plastic trunnions until you mentioned it.
Old Oct 16, 2012, 12:19 PM
Joined Dec 2009
In my experience, the plastic trunions in the E-Flite retracts are fine; altogether very relaible units.
... I have 4 E-flite sets deployed across various birds.
Old Oct 16, 2012, 12:22 PM
Joined Oct 2011
I don't think it will weaken them at all. You're not taking off that much material. Plus if you need to replace the pre bents its less than $10. I rather mess up the struts than drill holes and wreck a retract any day. :-)
Old Oct 16, 2012, 12:26 PM
Joined Dec 2009
A higher C-rating will do no harm; the load arising is largely defined by the voltage.
A higer C-rated pack generally behaves with a lower 'internal resistance', thus allows a few percent more amps if all else is the same.
In my view the stock 3200 mAh pack is plenty for this bird.
Old Oct 16, 2012, 12:39 PM
Babadush's Avatar
Joined Aug 2012
Will a 20c battery be okay? I have a couple 30c batteries laying around but also a 5000mah 20c I wouldn't mind using for longer flight times.
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 3511 Today 04:54 AM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 3 Dec 19, 2010 08:39 AM
