Old Mar 24, 2012, 04:31 PM
Navy Fly Guy is offline
Find More Posts by Navy Fly Guy
Navy Fly Guy's Avatar
Lubbock, TX
Joined May 2008
Tuck's Hurricane
Hi PC,
I was able to remaiden my Stock Hurri this morning. What a pleasure to fly. Zero wind, rock solid and landing flaps were very effective. When I returned to base (RTB) the mailman was there with my Tuck graphics from Callie. The above picture of the Pima Hurricane (Tuck's) is what mine will look like.
The underside port wing painted flat balck really a contrasting difference when doing overhead manuvers. It really standsout!
I will remove the JX B codes tonight and add the DT A. Once all the tactmarkings are in place I will start the weathering process. I plan to use artist chalks sealed with Dulcote. I can control the amount on weathering with the chalk better than the airbrush it is just me not the equipment!
I will use the dry brush for the wear and tear of the leading edges and wing walks. Oil drips and smears will be done using drops on toothpicks and a "Dry" airbrush air only for flow patterns on the cowling/airframe.
Chaos I wil post pictures for you as I go along. I love this plane.
NFG
Navy Fly Guy is offline Find More Posts by Navy Fly Guy
Old Mar 24, 2012, 08:14 PM
ryramZ is online now
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Originally Posted by Dave Eichstedt View Post
Please make sure you glue the wing halves together!
i will Dave. just doing a dry fit for the car. Manual says epoxy. What about the gws style contact glue?
ryramZ is online now Find More Posts by ryramZ
Old Mar 24, 2012, 08:15 PM
Plane Chaos is offline
Find More Posts by Plane Chaos
Joined Dec 2009
Originally Posted by Navy Fly Guy View Post
Hi PC,
NFG
Spendid news NFG.
That 'half-black' & 'half-blue' under-wing scheme sure is a classic Hawker Hurricane icon .....
I'm watching with interest the various ideas on weathering
.... by coincidence, only last weekend I asked if I could borrow my duaghters artists set of coloured chalks, with just that same in mind; hopefully she will remember to bring them next time she visits.
Don't know if youy have the PZ Spit MkIX ?
... anyhow, I have just posted some video footage of my PZ Spit, using that same lashed-up hat-camera I did for my Hurri a short while back (Hurri post #1803).
Link to new PZ Spit footage here:-
http://www.rcgroups.com/forums/showp...postcount=5025
Plane Chaos is offline Find More Posts by Plane Chaos
Old Mar 24, 2012, 09:31 PM
Mobyal is offline
Find More Posts by Mobyal
Mobyal
United States, VA, Lexington
Joined Apr 2007
Use epoxy is my advice. Gives you working time to get everything lined up and it's stronger -- or at least as strong -- as anyhting else you'll find....
Just my $.02 worth....
Mobyal is offline Find More Posts by Mobyal
Old Mar 24, 2012, 09:38 PM
Lubbock, TX
Joined May 2008
Very Nice Spitfire
Chaos,
Very nice Spit and great flying. I will keep you posted on my conversion.
NFG
Old Mar 25, 2012, 04:28 AM
GenghizCohen is offline
Find More Posts by GenghizCohen
Cohen the Barbarian
Australia, NSW, Leeton
Joined Jul 2011
Ok - so having been the first to post that I had received my Hurricane, I am finally (about 6 weeks later) got to maiden it - floods, general chaos in life etc.
I like this plane very much - looks great, flies sweet as a nut, great "presence" in the air - attracted admiring looks from the others at the field today. Will drop a wing if provoked, lands fine without flaps (had full aux 2 deployed - flaps was on aux 1, this is my first bird with flaps)
Just a great plane
GenghizCohen is offline Find More Posts by GenghizCohen
Old Mar 25, 2012, 07:23 AM
Ayeager is offline
Find More Posts by Ayeager
North Simcoe Flyers
Canada, ON, Midland
Joined Jan 2012
I was wondering, I have a couple 3s 3200 mah lipo's that are only 20c.. Which is rated for a max of 64amp discharge.. Would these be ok in the hurri? Or do you think it would make them puff??
Ayeager is offline Find More Posts by Ayeager
Old Mar 25, 2012, 07:25 AM
RCflyerCT is offline
Find More Posts by RCflyerCT
RCflyerCT's Avatar
United States, CT, Southbury
Joined Aug 2011
Gents...any comments on ground nose over issues on grass fields (like the PZ spit)?
Wes
RCflyerCT is offline Find More Posts by RCflyerCT
Old Mar 25, 2012, 07:26 AM
RCflyerCT's Avatar
Joined Aug 2011
Wes
Old Mar 25, 2012, 07:31 AM
RCflyerCT's Avatar
Joined Aug 2011
Grass field performance
Gents..any feedback relative to the grass field handling on this bird. Specifically is it prone to nose overs like the PZ spit?
Wes
Old Mar 25, 2012, 07:56 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Battery C Rating
I have been flying electrics for a long time, and I use to purchase and use batteries where the C rating matched the max amp draw. So if the Hurricane pulled a max of 60 amps, I would get a 3S 3200 20C battery (20C x 3200 = 64 max amp).
I don't do this anymore, because I observed that the voltage and power does not hold over the flight time. Using Castle logging, I noticed that the voltage drops and power is 10%-30% less by the end of the flight.
So I started using double the C rating required with good results. I no longer observe a reduction in power during the flight. So I recommend using a 40C-45C when a 20C would normally be required. It just gives you noticeable better performance and is worth the little extra weight and cost IMO.
tclaridge is online now Find More Posts by tclaridge
Old Mar 25, 2012, 08:07 AM
Joined Nov 2005
Ground Handling in Grass
The Hurricane does very well in mowed grass in the stock configuration. I moved my CG to the back of the squares on the wings, and it helps to avoid nose overs on rough field landings. I have not racked the gear forward like I have on other warbirds yet, but it will nose over if I don't land it right.
Keeping throttle at about 1/4 and flying it to the ground seems to be the key. Depending on the field, you can even keep a little throttle going after touch down (and pull the stick back) to blow air over the elevator. Even wheel landings are a challenge (but fun) because if the field is too rough or the grass is too tall, the friction will pull the nose into the dirt.
For take offs, I started to use 1/2 flap, and advance the throttle briskly with the stick back to avoid a nose over as she starts to move forward. A gradual throttle advance like a normal TO will just put the nose in the dirt. Then as the speed picks up, release that stick back pressure and let it fly off. The Hurricane comes off the ground smartly, so don't pull back too much and stall. Let it fly out.
So it just takes practice to get it right. The shorter the grass, the easier it is. I do not bother to taxi on grass either. The good news is that I have had plenty of nose overs and one cart wheel with no damage to the plane. (One firm landing did break a retract trunion, but that was not a grass issue.)
Old Mar 25, 2012, 04:25 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Just a couple of shots of my Hurricane for entertainment.
Mike Lee
mlee8249 is offline Find More Posts by mlee8249
Old Mar 25, 2012, 04:55 PM
Lubbock, TX
Joined May 2008
Code Removal
Question:
In a previous post the pictures showed how easy it was to "Rub" the JB X codes off of the Hurricane. I must be doing something wrong.....I tried using my finger/thumb ...NoJoy. I tried using a pencil eraser to just get it started...again NoJoy. ANY ideas?
I experinmented on the Pcode numbers since the sky fuse band will cover most of the new pnumbers according to the photos of Tuck's bird. The results looks like a patch due to combat damage/field repairs. While this may be "OK" under the stab I am worried what it might look like og the large areas of the fuse where the new codes will be placed.
I figure that my weathering "Wash" that I will airbrush over whe whole model MAY tone down the non-exact green and brown paint match.
NFG
Old Mar 25, 2012, 06:58 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Mike Lee
Real nice looking job on the weathering. Just enough for my taste. Thanks for sharing. I like to use a mix of airbrushing and artist chalk ground into powder. I too when finished seal with dulcoat.
Regards
flmlm is offline Find More Posts by flmlm
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4129 Jul 01, 2016 12:17 AM
Discussion E-flite Carbon-Z Yak 54 shoeler Sport Planes 4 Aug 13, 2013 04:47 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 10:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 10:21 PM
Idea Parkzone's Next Z-Foam Warbird.... and thoughts,feelings, etc. SmoothCruizer Electric Warbirds 3836 Feb 03, 2011 11:17 AM
