Old Jan 26, 2011, 05:04 AM
RC toy is offline
Find More Posts by RC toy
Sorry for my English...
Lithuania
Joined Aug 2008
Question
For Turnigy High Density R/C LED Flexible Strip owners
Hi. Could some one check if these leds work on 1S lipo? Thanx
RC toy is offline Find More Posts by RC toy
Old Jan 26, 2011, 12:35 PM
Shredman is offline
Find More Posts by Shredman
Build,Fly,Crash,Repeat
Roseville, CA
Joined Sep 2006
Yes, these can be run on 1S lipo, but will be very dim. I have them running on a 2S lipo for my RC cars with great success, but if you are flying you will want the brightest illumination possible which would be 3S lipo, or a 12V niMh, NiCad set up.
Additionally, I have one RC car with the LED's hooked up to a 9V rechargeable battery that works great and shows the colors for some distance.
Hope this helps!
Shredman
Shredman is offline Find More Posts by Shredman
Old Jan 26, 2011, 02:09 PM
T0RN4D0 is offline
Find More Posts by T0RN4D0
Fail Warrior
T0RN4D0's Avatar
Slovenia
Joined Mar 2010
Turnigy strips barely work on 2S. I did find some LED strips on e-bay that work nicely on 2S.
T0RN4D0 is offline Find More Posts by T0RN4D0
Old Feb 07, 2011, 02:51 PM
vashon10 is online now
Find More Posts by vashon10
Renton, WA
Joined Nov 2006
would you have a link to those that worked please ?
vashon10 is online now Find More Posts by vashon10
Old Feb 17, 2011, 08:44 AM
Brooklynstar23 is offline
Find More Posts by Brooklynstar23
NEVER GIVE UP!
Brooklynstar23's Avatar
Brooklyn, NY
Joined Nov 2010
I just got two sets of these white and blue...what is the best way to set them up to an electric rc airplane? Should i solder them to the red and black cables on the ESC, what is the route that most people go with them?
thanks
Brooklynstar23 is offline Find More Posts by Brooklynstar23
Old Feb 18, 2011, 02:35 PM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
I've not been able to get even a small (3 LED section) to light up while using a 1S battery. They light up fine with 2S and are really bright on 3S. I've tried the Yellow, Red, Blue, Green and White. White and Blue are definately the brightest. Haven't found the electrical specs for these but I am guessing the forward voltage needs to be around 5v DC.
Brooklynstar23 I use some of the little 1S connector extentions from HK, cut them in half one side goes to the lights, the other is soldered to the ESC red and black. When I want to run the lights I just have to plug the connectors together.
Eagle34 is offline Find More Posts by Eagle34
Old Feb 21, 2011, 05:08 PM
iflyrc1012 is offline
Find More Posts by iflyrc1012
no more glow models for me!!!!
iflyrc1012's Avatar
bklyn n.y.
Eagle34,
that's an excellent idea for led hookups,you should make a vid of your idea and post it o n you-tube! or enter it in model aviation magazine hints and tips!
iflyrc1012 is offline Find More Posts by iflyrc1012
Old Feb 24, 2011, 11:20 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
It's not really all that, I just was looking for a way to connect the lights on the wing to the lights on the rest of the fuse (with a removeable wing) and I thought of the extentions and they worked well. Then I thought of using the extentions to either have lights or not. These are small and light plus they seem to handle the power requirements of the lights just fine. A full 1 meter strip (60 leds) only draws around 400mA, I don't have nearly that many lights on my plane.
One other thing I was checking the forward voltage required to light the LEDs. Using a bench top regulated DC power supply I found that the white and blue LEDs need around 6.3VDC to light up, didn't test any other colors. I think the other colors need less voltage. These LEDs can be used as a makeshift voltage dector (when using a 2S battery) to let you know when you are getting near LVC as the white and blue LEDs will dim first when getting near the 6.3VDC which is actually a little lower than I like to discharge my batteries to.
Old Mar 06, 2011, 12:55 PM
grumman5277 is offline
Find More Posts by grumman5277
grumman5277's Avatar
Troy ,OH
Joined Jan 2004
I run mine by removing one led and a jumper for 2s.Just as bright as 3s.Every 3 led section one has to be removed.Mine is for small applications.Let run for a few hrs and was fine.
grumman5277 is offline Find More Posts by grumman5277
Old Mar 19, 2011, 02:42 PM
FPVORDIE is offline
Find More Posts by FPVORDIE
Now which way was home.....
Joined Feb 2011
thanks
You can also hook them up to a brushed ESC and that way you can use a spare channel to turn the light off and on. If you have a knob on your radio (or disable the centering spring on the rudder channel) you can use that to make the brightness fully adjustable. From barely on to blinding.
FPVORDIE is offline Find More Posts by FPVORDIE
Old Mar 22, 2011, 02:17 AM
EmmDee is offline
Find More Posts by EmmDee
Seattle, WA
Joined Oct 2005
Has anyone tried de-soldering a single LED from the strip and running it on a 1S setup without a resistor? I tried hooking up a little 130mah 1 cell to a single LED on the strip, and it was really bright. I don't know how long it might last before it cooked.
I bought a pack of each color, so I have more than I need - I want to make some night blades.
EmmDee is offline Find More Posts by EmmDee
Old Mar 31, 2011, 12:00 PM
phil007 is offline
Find More Posts by phil007
Night Flyer
phil007's Avatar
United States, TX, Round Rock
Joined May 2005
Try using this AnyVolt Micro Universal DC-DC Converter. It will step up the voltage but is limited to 0.5A. That should be enough for any aircraft using a 1c battery.
Phil
phil007 is offline Find More Posts by phil007
Old Apr 02, 2011, 12:52 AM
Steam28 is offline
Find More Posts by Steam28
Steam28's Avatar
United States, OH, Strongsville
Joined Feb 2009
[QUOTE=Eagle34;17446448.
Brooklynstar23 I use some of the little 1S connector extentions from HK, cut them in half one side goes to the lights, the other is soldered to the ESC red and black. When I want to run the lights I just have to plug the connectors together.[/QUOTE]
Eagle34,
What is the part number for the 1S connector extentions?
Thanks.
Steam28 is offline Find More Posts by Steam28
Old Apr 28, 2011, 08:08 AM
Honza C is offline
Find More Posts by Honza C
Crashing? Hunting the mole!
Honza C's Avatar
Česká republika, Jihomoravský, Brno
Joined Jan 2011
Hi, I have also ordered these strips...
1. Has anyone tried to hook it on a standard servo output of the RX (I have Spektrum AR6xxx) ? I would love to have it radio-controlled, but not sure if the voltage is enough. I don't want to install any additional switch. Also hope that the RX won't cook ...
2. Is anyone using the service/balancing connector of the battery ? I ordered the female connectors, want to try this.
Honza C is offline Find More Posts by Honza C
Old Apr 28, 2011, 10:27 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Originally Posted by Steam28 View Post
Eagle34,
Thanks.
Here is the link
Honza that is a good way to connect to the battery, probabally the easiest. I haven't tried connecting to the RX output, best (safest) way would be to use a RX controlled switch.
Sold Turnigy Flexible Sticky LED Strips.. Tram Aircraft - General - Miscellaneous (FS/W) 23 Mar 10, 2011 12:06 PM
For Sale High quality R/C boats products & accessories kenzenrc Boats (FS/W) 27 Mar 05, 2011 07:55 PM
Sold Turnigy TGY 52cc gasoline engine for R/C model airplanes Comet1 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Sep 27, 2010 10:55 AM
