Old Nov 13, 2012, 05:06 AM
Copey19 is offline
Find More Posts by Copey19
Joined Jul 2011
Alrighty then,
So you do sell the Blanik?
Copey19 is offline Find More Posts by Copey19
Old Nov 18, 2012, 04:40 AM
salisbug is offline
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Melbourne, Australia
Joined Jun 2002
The Dremel and my Perma-Grit cut-off wheel got a workout this evening:
salisbug is offline Find More Posts by salisbug
Old Nov 18, 2012, 08:47 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Nice linkages......good to see someone who believes that 2/56 hardware is for park flyers!
SZD16 is offline Find More Posts by SZD16
Old Nov 22, 2012, 02:20 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Did some surfacing of the wings today.
Easy work, bugger all material (or skill) needed:
  • painters tape (for the sharp edge)
  • Squadron green putty
  • sandpaper
  • primer
How I went about it:
  1. Determine where the major panel joints are. For the Blanik L-13 there are only a few that are obvious. Refer to photos of the prototype and a good 3-view. Scale up the locations and mark them on the wing.
  2. Place the tape beside the markings taking care to which side of the line you place the tape. e.g. on the L-13 wings, the inboard skins overlap the outer skins, so the tape goes on the outer side. But for the tip, the fairing fits over the wing, so the tape goes inboard. Press the tape firmly in place to try and prevent the filler 'bleeding' under
  3. Apply the putty on the correct side of the line - it doesn't take much. I applied it approximately 6mm - 10mm wide using a plastic card. On Dave Platt's advice, (and my bad experience), it's best to not directly apply the filler from the tube. The tube dries up easily. I applied the filler onto the card and then 'squeegied' it in place . It is also best not to over work the material - its forms a skin very quickly. I try to only swipe it on once or twice.
  4. Wait an hour or so for the filler to dry - again, it doesn't take long as it's not too thick
  5. Remove the tape carefully. I had a couple of spots where the putty bled and cleaned up the edge using a sharp scraper
  6. Carefully sand the 'freehand' i.e. the side that wasn't taped, flush with the surrounding surface
  7. Prime. I also applied primer to the area where ribs and the spar are on the prototype to provide some extra thickness for when I machine in my rivets.
Note that the flaps and ailerons weren't done - they will get the fabric covered structure treatment just like the rudder as previously demonstrated.
After that I will still need to add access panels etc
Old Nov 24, 2012, 06:13 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
More surfacing work....
Old Nov 25, 2012, 12:08 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Another backwards step........
Sometimes I hate my high standards.
I was not happy with the rudder finish after my 1st goof-off
http://www.rcgroups.com/forums/showp...&postcount=308
Scraping away the paint caused gouges, that no matter how much I sanded and re-primed could still be seen. After 3 or 4 goes I decided there was only one way to overcome it. Stripper.
No, not that sort...........
This sort.
You dirty people......
Ditto with my stab/elevator. I applied a coat of primer and got orange peel. Sanded it all smooth, tried again and got the same result.
Let's start on them again....
Old Nov 25, 2012, 02:10 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Bugger! You know the worst thing will be if you topcoat the model and all the detail dissapears. Great work Glen it's looking really good.
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Nov 25, 2012, 02:44 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Surfacing begins on the upper surfaces
Old Dec 01, 2012, 05:29 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
After a week away from the Blanik, I finally got a chance to do a little work on her.
The flap and ailerons rib simulation is drying now ready for a sand in the morning.
I've come to the realisation that I won't have her finished to the standard I want in the 35 days prior to Campers, so I'll more than likely forego the rivets. You see I've been tossing up whether to actually cover the model in aluminium, and during the week spent a load of $$$ on Flite-Metal, so I'm committed to going with a natural ali finish. So she'll still get panel overlaps, but the rivetting method for a natural metal finish is different than for a painted finish, so it'll be a quick paintjob for Camperdown, and on the assumption that the model survives , I'll strip it and refinish it next year...
Old Nov 09, 2013, 05:02 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Left wing almost done. Added hatches from aluminium tape burnished in place, hatch hinges from small sections of styrene rod and a wing tie-downpiont from plastic rod & tube.
Just waiting for my rx to arrive so I can set servo centres and throws and glue them in.
Now for the right wing.....
Old Nov 10, 2013, 02:36 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Right wing servos and loom done - picking up the pace now......
Old Nov 11, 2013, 02:06 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Riveted the lower surface of the port wing tonight.
The head mounted light lets you see a tad better. It all helps when each rivet head is only a smidge over 2mm in diameter.
You don't have to be mad to be a scale modeler, but it sure helps!
Old Nov 11, 2013, 03:58 AM
solitairyman is offline
Find More Posts by solitairyman
solitairyman's Avatar
Antwerp, Belgium
Joined Oct 2007
Details
This is a great job ...
Have me thinking again starting to build the 37% scaled Blanik/Vivat.
See scale soaring under motor gliders.
NoŽl
solitairyman is offline Find More Posts by solitairyman
Old Nov 20, 2013, 04:09 AM
salisbug is offline
salisbug's Avatar
Joined Jun 2002
Slowly getting there....
L/H flap & aileron servo's glued in.
Right wing catch-up next
Help! Blanik L-13 Plan fly_kc Scale Sailplanes 17 Nov 22, 2015 11:08 AM
Question Blanik L-13 Mopar92 Scale Sailplanes 48 Oct 16, 2014 07:30 PM
Discussion Blanik L-13 eschlitzkus Scale Sailplanes 28 Apr 26, 2013 10:01 AM
Discussion Blanik L-13 Cockpit Detail Miraj Scale Sailplanes 3 Jan 17, 2008 09:31 PM
120" L-13 Blanik maiden Mickey Slope 6 Sep 12, 2007 05:47 PM
