| Thread Tools |
| This thread is privately moderated by Fish99, who may elect to delete unwanted replies. |
Well, I've been busy putting together new 2 cell, Hyperion 180 mah lipo packs. I ordered the following items
2 Cell mini JST Connectors - RC-Connectors Single Cell 180 mah lipo - Allerc x 2 And I followed directions found on Joel's (turboparker) blog Joel's Blog And was able to make up (2) new 180 mah, 2 cell, Hyperion lipos. According to the data Joel has from testing these should give me a 16% performance boost, and from my scale I went from 9.5 grams on the stock 120 mah Eflite lipo to 11.7 grams with the new packs, so only about 2 grams more weight, 50% more battery reserve, and 16% more power! Good deal. Can't wait to try them out. ![]() Build Vid and pictures to follow! Marlin |
Next I placed both batteries on the bench so I could see the + and - signs facing up. I made sure the piece of shrink tubing was on the - sign on one, and + sign on the other and bent the connecting tabs out a bit, away from the side with the + - on it!
I used a piece of the double sided tape and stuck them together with the + - signs facing inward. What you end up is with a + and - pole that is UN-SHIELDED facing each other, and the same with the tubing shields facing each other on the other side. What I did was cut / trimmed the un-shielded tabs to about 1/8 of an inch and solder the white balancing wire from the connector together with the two un-shielded tabs. USE CAUTION not to short these to the other two tabs which are covered by the shrink tubing! Once soldered, I covered it with liquid elec tape and let that dry. I then removed the tubing off the NEGATIVE pole and CAREFULLY trimmed it to about 1/8 inch as well, then soldered the black wire to it. It was also covered in liquid elec tape and let that dry. Next did the same with the last remaining POSITIVE pole and the RED wire. I was VERY CAREFULL not to short the lipo poles! More elec. tape. Once dry, gooped the whole thing with liquid elec tape, then pulled down the shrink tube I had put the three wires through and heated it in place. Finally I put hot glue in the crack/space between the lipos and over each of the three solder joints, then across basically the entire top of the pack, to aid in protecting the wiring from being pulled from the solder joints during use. Another bit of double sided tape to attach the plastic strip under the lipo, and then secured a velcro DOT on the underside, to keep the battery in place in the plane, and the pack was finished!
How I Did It Video
Here is a video of the build from my Youtube site.
Marlin
Short Flight Video
Well, I have rigged up a HAT CAM to take videos and thought I would be using this weekend to get LOADS of good video but the wind is NOT cooperating. 30 km / hr winds today! I just had to try SOMETHING so took the beast out front and flew it from the driveway. BIG MISTAKE, way too windy. I kept it in the air and MOSTLY undercontrol. I kinda CRASH LANDED it the first time, as the gusty winds died off just above touch down.
Of course nothing like getting lucky to make you think you should push it, so up it went again ... again WAY too windy, and I almost hit the light post 2 or 3 times. Again, managed to kinda land / flop it down with not damage and this time decided to leave well enough along. Hope you enjoy the flight. Marlin
Little longer Flight ... dodging poles and cars on the Block!
Here is a little longer flight, on the Stock 120 mah lipo, right off the driveway on a reasonably calmer day. The Beast is a TON of fun, very agile yet controllable. Had a blast dodging light posts and parked cars while doing some stunt flying. Even managed a couple knife edges ON THE BLOCK!
This thing is a LOT of fun to fly. Marlin
Insurance for your beast
Clear box tape, thinner the better. The weight of it will not hurt the plane at all.
This is my 2nd set of wings, due to folding (no tape on em') What I did.. Tape wings / Flaps / All tail / Nose / Whole Body (pics) Carbon rods on wing connectors / Rudder Lowered Battery try inside 1/4" +or- 5043 prop Still Jams and can take a hit w/out FOLDING Making a pair of 180mah HYPO's thanks to "Fish99" for all the info
"RemE" Mods Prob next My beast ![]() Ruben |
Windy Day Flying with the Beast
Here's an old video on my YouTube account of the Beast flying on a very windy day in the winter in front of the house! Loads of fun.
Marlin
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16686 | Yesterday 11:45 PM |
| New Product New bird in the havoc hanger. EG Aircraft Slick 540 50CC. | cryhavoc38 | 3D Flying | 38 | Apr 22, 2011 06:51 AM |
| Wanted eflite UMX Beast | fnlrun | Aircraft - Electric - Micro & Indoor Airplanes | 11 | Dec 12, 2010 04:23 AM |
| Sold eflite UMX BEAST | TERMAGATOR | Aircraft - Electric - Micro & Indoor Airplanes | 8 | Dec 04, 2010 01:16 AM |
| Discussion Ideal profile UMX Beast | Nooflyer | Indoor and Micro Models | 6 | Sep 26, 2010 02:26 AM |
