This thread is privately moderated by SoloProFan, who may elect to delete unwanted replies.
Old Feb 27, 2011, 03:52 PM
GuusBots is offline
Find More Posts by GuusBots
Joined Feb 2011
ben je trouwens nederlands?
GuusBots is offline Find More Posts by GuusBots
Old Feb 27, 2011, 04:04 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by GuusBots View Post
SoloPro, you are right, they are both broken, thanks very much for the help. You are the best!
Glad to be able to help, and that you found the cause of your problem. I added one of your pictures to the FAQ, to show how broken blade pivots might look like. I trust you don't mind using that pic, right?
En ik ben inderdaad nederlands.
(translation, GuusBots asked if I was Dutch, and I confirmed that)
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 27, 2011, 04:43 PM
GuusBots is offline
Joined Feb 2011
No problem mate, thanks for the help!
Old Mar 01, 2011, 05:44 AM
rcairplanes is offline
Find More Posts by rcairplanes
Joined Jul 2009
great mini heli, i think this nine eagles model is resemble with the hughes heli
rcairplanes is offline Find More Posts by rcairplanes
Old Mar 01, 2011, 07:03 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
The Bravo III has a Hughes 500 fuselage, if that is what you mean...
Latest blog entry: Pictures of various boats
Old Mar 02, 2011, 12:06 PM
GuusBots is offline
Joined Feb 2011
Hey SoloPro,
As you might remember i had 2 broken blade pivots for the lower blades of my Bravo III. I replaced the thing on the axel which has the pivots on it. Now i have the same problem as before, i can get it to hover steady without much trim but now it hardly goes forward and hardly banks left. Flying backwards goes fine and rotating goes fine and banking to the right goes fine. But flying forward and banking left is problematic. Do you have some tips for me on how to fix this?
Old Mar 02, 2011, 01:55 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Hey SoloPro,
Trims are centered when in steady hover? If not, try to get them to center by using subtrim. Also observe if the servos move an equal amount in both direction and what happens when you give forward elevator or left bank/roll when the heli is on the ground.
Old Mar 02, 2011, 03:13 PM
GuusBots is offline
Joined Feb 2011
Yeah, i trimmed the helicopter in subtrim mode (i find that easier) and made some little adjustments in normal mode. The weird thing is that the servos seem to move an equal amount when the helicopter is idle. I really have no idea why it is behaving so strange..
Old Mar 02, 2011, 03:55 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Sure there is not too much play on the bottom shaft? There is a small plastic collar that holds the shaft in place, but it's very easy to over tighten the screw in that collar, and cause it to split near the screw hole. The collar then can slide a little on the shaft, and the shaft itself as well. Banking left and forward elevator will pull down on the swash plate. When there is too much play on the shaft, in the air the shaft will slide up a little, and when you then apply forward elevator, the first part of the servo travel will be used to slide the shaft down, leaving little travel left to move the blades.
Old Mar 03, 2011, 07:50 AM
GuusBots is offline
Joined Feb 2011
I'm pretty sure that the collar is screwed on in the right way, i checked for play with the inner and outer shaft and i can't find any play on them. I trimmed it again in subtrim mode, holding the helicopter in my hand and applying throttle and looking at the swash plate and trimming until that was horizontal. Then it flew like it should do, until i crashed and now it is back to flying weird..
Old Mar 03, 2011, 10:54 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I'd say, post a couple of pictures again, maybe we can spot what is wrong for the second time.
Old Mar 05, 2011, 03:29 AM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Upgrading 210A with 312A Bravo III motors
Is it possible to upgrade 210A motors with 312A Bravo III motors?
Brosol is offline Find More Posts by Brosol
Old Mar 06, 2011, 01:27 PM
bechtelfriend is offline
Find More Posts by bechtelfriend
Denver, CO
Joined May 2010
I know this is a basic question, but do you have the tx in standard mode or advanced? In standard mode, mine will barely move forward but will go backwards pretty fast, like you said yours is doing. Switching to advanced mode solves that for me.
bechtelfriend is offline Find More Posts by bechtelfriend
Old Mar 06, 2011, 05:54 PM
Brosol is offline
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
210A Elevator servo problem
My 210A will get stuck in forward flight and I can't get it to return back to a hover or fly backwards.
The elevator servo will move for forward input but won't return back to its middle position or move for backward input.
There are no physical jams or binding. I tried sub trim, end of point adj for backward endpoint, mode 2, mode1.
Nothing seems to work. Is there a way to reset the trims and EPA to factory defaults?
Old Mar 08, 2011, 12:37 PM
laarj is offline
Find More Posts by laarj
Joined Dec 2010
Originally Posted by laarj View Post
I've logged 20 flights or so on my Bravo III and have a couple of questions.
After addressing the obvious issues, I checked out the controls and all seemed to work ok. I then ran up the throttle and noticed that the inner shaft gear was out of round by a large margin. On low throttle, there was a very noticeable vibration. Prior to taking the Bravo III apart, I noticed a tail vibration when hovering. This was there from day one so it wasn't from my landing skills. I took the gear and inner shaft out and found that the gear/locking collar assembly was out of round. Has anyone seen this?
Update on gear issue...
Received a replacement inner shaft gear and collar. The original gear was definitely out of round. The collar was fine. The vibration is gone and the Bravo III flys great.
Kudos to ClubHeli for their fast service....
laarj is offline Find More Posts by laarj
FAQ Nine Eagles Solo Pro I/II/V1/V2/270/Bravo SX FAQ (FAQ part in the first 3 postings!) SoloProFan Micro Helis 2127 Today 04:06 AM
Discussion Revell Proto cx and Nine Eagles Solo Free Spirit EFEX ED Coaxial Helicopters 7 Feb 10, 2013 11:20 AM
New Product Nine Eagles Soar - Replacement for Solo Pro? zadaw Micro Helis 1 Dec 30, 2010 03:15 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 01:16 AM
Wanted MCX, Nine Eagles Solo, Proto CX RTF k5beason Aircraft - Electric - Helis (FS/W) 0 Apr 18, 2010 09:02 PM
