This thread is privately moderated by SoloProFan, who may elect to delete unwanted replies.
Old Feb 18, 2011, 09:26 PM
Hovering is a way of Life
jtravel's Avatar
Arizona
Joined Aug 2010
Originally Posted by frieslander View Post
You have to undo the antenna screws and flip it up to get at it. The switch is under the antenna.
no need to remove the antenna unless your swapping it to the other position to change between mode 2 & 1
It doesn't matter what mode your using as you always have access to one of the two buttons on the back of the TX
jtravel is offline Find More Posts by jtravel
Old Feb 19, 2011, 06:13 AM
United States, SC, Beaufort
Joined Apr 2006
Just a heads up, I'm a very mechanically inclined adult male. I ordered a couple MCX inner shafts, gyros, and top blades, and based on what I can tell, the inner shaft is approximately 1 cm too short to work in the Bravo III. I stripped the bottom collar out...TWICE...trying to get it to work and stay on, I don't think there's enough sticking out to successfully lock the collar onto. If others are having better luck, I'm all ears. Actively waiting for the extra collars I ordered to reattempt.
mrw3685 is offline Find More Posts by mrw3685
Old Feb 19, 2011, 08:36 AM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Can those that mentioned the mCX inner shaft is a direct replacement chime in on this? I couldn't verify this information personally, so if it is not 100% correct, I would like to know asap...
SoloProFan is offline Find More Posts by SoloProFan
Old Feb 19, 2011, 09:45 AM
To Soar Like An Eagle!
frieslander's Avatar
Canada, ON, Woodstock
Joined Dec 2007
LOL I was asleep on that one, should have remembered, but at my age the memory cells sometimes go asleep.
A frieslander moment!
frieslander is offline Find More Posts by frieslander
Old Feb 19, 2011, 11:19 AM
jtravel's Avatar
Arizona
Joined Aug 2010
I had a MCX2 innershaft that looked like it would fit just fine when I had my my bravo 3 torn down a couple weeks ago.
I didn't fully assemble or fly with it however and will double check that next time I tear it down.
What were you going to do with the gyros you ordered?
Old Feb 19, 2011, 12:14 PM
Joined Apr 2006
Sorry it was a mis-speak, I meant to type flybars. I essentially purchased two MCX sets to try, and one for a back-up. I'm convinced their isn't enough length on the MCX shaft to go all the way through the Helo and they get locked down with the collar at the bottom of the gears. The collar is cheap metal and on one side I had barely tightened it down and it stripped. And of course, about a 1/4 turn on the other side and the frigain screw broke. So, once again, more parts on order. The quality of the parts of this thing are starting to bother me...I think the EFlite stuff is of better quality and am inclined to have boughten one instead.
Old Feb 19, 2011, 05:00 PM
Adelaide Hills, South Australia
Joined Feb 2011
Turn your TX over.
See the two empty screw holes, Look between them and you will see the round button.
So that's what that is! Many thanks
bricol45 is offline Find More Posts by bricol45
Old Feb 20, 2011, 02:57 AM
pittsburgh pa.
Joined Feb 2004
yes, i pulled the inner shaft from my old mcx and it worked perfect in my bravo III but you have to use the flybar assembly too, i flew it that way for about 2 weeks till my stock inner shaft came in
cleanair is offline Find More Posts by cleanair
Old Feb 20, 2011, 10:38 PM
USA, NC, Concord
Joined Dec 2010
FYI: problems holding altitude...
I have 2 Bravo IIIs and have had bigtime problems with them; can't hold altitude in a hover or any other flight regime. Got a Free Spirit with the "real" style TX, bound the Bravos to it, and it's a bunch better than the stock Bravo TX...still touchy, but better.
Did a little investigating on all my transmitters supplied with Bravo IIIs, Bravo SX, Solo Pro, Proto Max, and found that there is some mechanical play in the vertical (throttle) axis of the left stick; ie, the pot wiper doesn't begin to move until the stick has moved thru several degrees of travel. In my estimation, this is a great part of why the Bravo III (and probably the others) are very difficult to control.
Unfortunately, since these stick assemblies are closed units and soldered to the circuit board, I see no way to correct the loose connection between the stick and the throttle pot.
If anyone can come up with a fix for this, it might help a lot of NE fliers.
magna99 is offline Find More Posts by magna99
Old Feb 21, 2011, 12:34 PM
Joined Dec 2010
I received a replacement Bravo III from MRC and so far so good.
I have a question relating to the sub-trim mode. If you are trimming the Bravo III (or solo-pro--in the future) in the sub-trim mode, are the adjustments stored in the RX?
(i.e if I purchase a BNF, would I have to adjust the trim on the TX each time I flew a different heli?)
laarj is offline Find More Posts by laarj
Old Feb 21, 2011, 01:43 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
EPA is stored in the RX, trims in the TX. So if you get that BnF, and want to keep flying both helis, you should consider mechanical trimming on one of the helis, so adjusting the linkages, instead of (sub)trimming. Only tail trim will need changing. You could also consider getting one of those new TXs NE is about to release, which have model memory, so you can store trim settings for each heli.
Old Feb 21, 2011, 05:53 PM
Joined Dec 2010
Thanks for the info....
Old Feb 21, 2011, 09:22 PM
USA, NC, Concord
Joined Dec 2010
In regards to using an MCX inner shaft in the Bravo III, as of today one of mine is flying quite nicely with the MCX shaft, blades, and flybar. The Eflite parts have what looks to me to be a superior design for the blade pivot mechanism, but time will tell. I didn't break it in several mishaps today! (small room with many obstacles) The MCX shaft was exactly the same length as the Nine Eagles part.
Dave
Old Feb 22, 2011, 12:22 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Dave
Contradicting experiences. Can you both measure the length of your mCX shafts? Perhaps there is variation in the length.
Old Feb 22, 2011, 02:00 PM
Joined Mar 2009
Hi guys, I just ordered a Bravo III, and I am looking to order parts and batteries for it. Hobby King has parts and batteries for Solo Pro FP II, but not for the Bravo III. Will the parts for Solo Pro FP II fit a Bravo III? I listed the link below. Thanks.
http://www.hobbyking.com/hobbyking/s...idCategory=359
caunyd is offline Find More Posts by caunyd
FAQ Nine Eagles Solo Pro I/II/V1/V2/270/Bravo SX FAQ (FAQ part in the first 3 postings!) SoloProFan Micro Helis 2012 Jun 16, 2013 09:20 AM
Discussion Revell Proto cx and Nine Eagles Solo Free Spirit EFEX ED Coaxial Helicopters 7 Feb 10, 2013 10:20 AM
New Product Nine Eagles Soar - Replacement for Solo Pro? zadaw Micro Helis 1 Dec 30, 2010 02:15 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted MCX, Nine Eagles Solo, Proto CX RTF k5beason Aircraft - Electric - Helis (FS/W) 0 Apr 18, 2010 08:02 PM
