This thread is privately moderated by SoloProFan, who may elect to delete unwanted replies.
Old Feb 15, 2011, 11:06 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by malden86 View Post
Has anybody had any luck finding someone who has the Bravo III inner shaft in stock? The tabs that go into the blades broke off and are stuck in the blades. Any help would be appreciated.
Or you could use the mCX one, although you will have to replace the blades as well, if I recall it well enough.
If you use the mCX parts, you indeed need the mCX top blades and flybar as well. Or get the Twingo one. Added that to the FAQ btw.
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 15, 2011, 01:36 PM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
Originally Posted by jtravel View Post
Twingo & bravo III use the same inner shaft
http://www.hobbyking.com/hobbyking/s...dProduct=12029
Thanks jtravel, already ordered a couple.
malden86 is offline Find More Posts by malden86
Old Feb 15, 2011, 03:43 PM
bricol45 is offline
Find More Posts by bricol45
Adelaide Hills, South Australia
Joined Feb 2011
Originally Posted by SoloPro View Post
It should keep moving forward. Not lightning fast, but it should not stop on it's own. Do you have excessive play on the servos? Any crashes? How does it fly backwards? Much faster or also slow?
No serious crashes. Servos seem OK. It is faster backwards.
bricol45 is offline Find More Posts by bricol45
Old Feb 15, 2011, 04:07 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Much faster? What is the position of your elevator trim? Centered or a little far from the center?
Old Feb 15, 2011, 09:05 PM
bricol45 is offline
Joined Feb 2011
A bit faster. It still levels out in reverse. It's as if there's not enough travel to maintain attitude. Elevator trim is a couple of clicks forward, i.e. down
Old Feb 16, 2011, 01:45 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Sounds a bit like the blade pivots on the lower shaft might have sheared off. Or swash plate came apart. Can you see the servos move? How far does the elevator servo travel down on full forward?
Old Feb 16, 2011, 11:45 AM
Quagga is offline
Find More Posts by Quagga
Nederland, Noord-Holland, Krommenie
Joined Nov 2010
Does anybody know how to remove the outer shaft? I want to replace my swash plate. Any suggestions welcome!
Quagga is offline Find More Posts by Quagga
Old Feb 16, 2011, 12:06 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Remove the gears. Pull out the inner shaft. Unsnap links between swash and lower blades. Pull the outer shaft up. It may be held securely in place by the ball bearings, just carefully edge it out. Unsnap the control rods from the swash, and there you are. You could leave the inner shaft in place, but it's easily damaged, so I would take the extra time to remove it first.
Old Feb 16, 2011, 12:36 PM
Quagga is offline
Joined Nov 2010
Thanks SoloPro! frieslander just walked me through the same steps. It is scary to apply force if you're unsure...
Old Feb 17, 2011, 05:50 PM
bricol45 is offline
Joined Feb 2011
Pivots are OK, Swash is OK. servo travel ~3mm
Old Feb 18, 2011, 12:05 AM
bricol45 is offline
Joined Feb 2011
I'm going nuts trying to analyse this, but here goes![*]I need forward trim just to hover[*]There's more reverse than forward motion available[*]There's more left than right aileron
It looks a if the servos aren't centred and are biased in one direction over the other. Is this possible? Is it adjustable?
Old Feb 18, 2011, 01:38 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
You should use subtrim to center the servos, and then adjust the pushrods to make it hover with sticks centered.
Old Feb 18, 2011, 04:28 PM
bricol45 is offline
Joined Feb 2011
How do I use "sub trim" mode? You mention elsewhere pressing a little button on the back of the Tx. There are no little buttons on the back of my Bravo III Tx.
Old Feb 18, 2011, 08:01 PM
frieslander is offline
Find More Posts by frieslander
To Soar Like An Eagle!
frieslander's Avatar
Canada, ON, Woodstock
Joined Dec 2007
You have to undo the antenna screws and flip it up to get at it. The switch is under the antenna.
frieslander is offline Find More Posts by frieslander
Old Feb 18, 2011, 09:23 PM
jtravel is offline
Find More Posts by jtravel
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
Turn your TX over.
See the two empty screw holes, Look between them and you will see the round button.
jtravel is offline Find More Posts by jtravel
FAQ Nine Eagles Solo Pro I/II/V1/V2/270/Bravo SX FAQ (FAQ part in the first 3 postings!) SoloProFan Micro Helis 2138 May 11, 2016 01:24 PM
Discussion Revell Proto cx and Nine Eagles Solo Free Spirit EFEX ED Coaxial Helicopters 7 Feb 10, 2013 10:20 AM
New Product Nine Eagles Soar - Replacement for Solo Pro? zadaw Micro Helis 1 Dec 30, 2010 02:15 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted MCX, Nine Eagles Solo, Proto CX RTF k5beason Aircraft - Electric - Helis (FS/W) 0 Apr 18, 2010 08:02 PM
