This thread is privately moderated by SoloProFan, who may elect to delete unwanted replies.
Old Apr 14, 2011, 11:47 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by Ronzo View Post
My Proto CX exhibited some weird behavior last night. Immediately after spooling up, it lifted off and experienced vibration in the yaw axis. It appeared as though the gyro kept snapping the tail back into position after it yawed a couple of degrees, repeatedly. Any comments or suggestions as to why this occurred, and how to solve the problem?
Might be hairs between the gears, or one of the motors is beginning to slowly fail, and isn't running smoothly anymore.
SoloProFan is offline Find More Posts by SoloProFan
Old Apr 14, 2011, 12:03 PM
Ronzo is offline
Find More Posts by Ronzo
The sparkle in your China
Joined Feb 2011
Hair in the gears is surely a possibility. Thanks. I'll look it over with a magnifying hood tonight.
Ronzo is offline Find More Posts by Ronzo
Old Apr 20, 2011, 02:43 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
What are the thoughts about this?
http://www.aliexpress.com/product-gs...olesalers.html
Old Apr 20, 2011, 04:22 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by erdnuckel2 View Post
Those parts are meant for the Solo Pro, although the swash will probably fit the Solo coax as well. It looks way too heavy though. Xtreme also has a metal swash, but the top section is still plastic, and even then it's considerably heavier than stock. If you want to turn your heli into a nice looking shelf queen, fit a metal main shaft, head, swash guide and full metal swash. If you want to make it fly better, only the Xtreme swash is really offering some increased precision, with a acceptable weight penalty. On helis this light, metal is usually a bad idea...
Old Apr 21, 2011, 12:42 PM
erdnuckel2's Avatar
Joined Mar 2009
ProtoCX and ProtoMax
ok, so this is mainly for the guys located in the US - only half of it is Coax and its only a "rebranded" NE ... but maybe some of you guys are interested in this:
Revell proto CX:
http://www.liquidrc.com/index.php?ma...ducts_id=64818
Revell proto Max (single rotor):
http://www.liquidrc.com/index.php?ma...ducts_id=64844
considering that they both are only 99cent shipping in the US if I understand the site right, they look like really good deals.
E2
Old Apr 21, 2011, 05:48 PM
jtravel is offline
Find More Posts by jtravel
Rather Be flying or Tinkering
jtravel's Avatar
Arizona
Joined Aug 2010
Getting "Sorry product not found message"
Did anyone place a order?
jtravel is offline Find More Posts by jtravel
Old Apr 21, 2011, 07:03 PM
erdnuckel2's Avatar
Joined Mar 2009
http://www.rcgroups.com/forums/showp...postcount=1944
Old Apr 21, 2011, 07:09 PM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
Very limited number.
If I had seen it sooner I would have added another Proto Max to my collection.
Old Apr 22, 2011, 12:29 AM
bricol45 is offline
Find More Posts by bricol45
Adelaide Hills, South Australia
Joined Feb 2011
I need more down elevator. Is EPA possible with Bravo III?
Thanks to this brilliant forum I've got my BIII trimmed out (using sub-trim) with rock steady hover & it's flying well. I broke & replaced the "Under T Shape Holder" - the thing with prongs onto which the lower blades fit - & used the opportunity to level the swash plate. While the heli flies pretty well, it still has more up elevator travel (backwards flight) than down (forward flight). More down elevator servo travel would solve this. I tried the EPA adjustment procedure (enter sub trim - remove LiPo - replace LiPo) but nothing happens. The servo doesn't move. Any suggestions?
bricol45 is offline Find More Posts by bricol45
Old Apr 22, 2011, 01:58 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I think it depends on the receiver version. My Solo, which still has the older type servos, won't do EPA, only subtrim. Maybe the newer RX-01 receiver, which is currently used in both the coaxials and the single rotor birds, provides EPA for the coaxials.
Old Apr 22, 2011, 03:37 AM
bricol45 is offline
Joined Feb 2011
Any ideas on how to get more forward motion then?
Old Apr 22, 2011, 04:51 AM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
Why do you think that the swash should be level?
I reset my TX sub trim to zero (default)
Then I manually adjusted the Trim for stable hover by adjusting the servo arm length. This takes alittle time because you have to check hover,make servo arm adjustment,re-check hover untill you get it perfect.
With perfect hover My swash plate is not level.
Infact I found It requires lots of FWD trim to correct the backward movement when the swash was level.
I'm always confused when I read recommendations to level the swash plate
Old Apr 22, 2011, 04:58 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
On a peefectly balanced heli, the swash should be level. There is however some variation in these little helis, like some batteries are a fraction heavier, or other small differences. These cause a little unbalance, which needs to be corrected. The best way would be with adding or removing weight, but just using trims is much easier, and won't do any real harm. We're talking about a small coax here, not a 3d capable "hotrod" of a heli, where perfection is needed.
On the Solo Pro, the weight is more to the front, which explains why the swash is tilted backwards when the heli is in stable hover. Theory is nice, but not always applicable to these small helis.
Old Apr 22, 2011, 05:19 AM
jtravel is offline
jtravel's Avatar
Arizona
Joined Aug 2010
That makes sense then as I'm using a heavier battery in my B3.
My Two solo pro's have swash plates that are not level as well as my Free spirit SR
I'm just in the habit now of manually adjusting the servo arm length for stable hover instead of using the TX sub-trims.
Main reason is I'm using my TX to fly more than one Heli.
Old Apr 22, 2011, 06:18 AM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
I tend to agree with what SoloPro has said re the swashplate and it being level.
It's crucial on a collective pitch helicopter, especially the larger ones, but as mentioned you need to have a perfectly balanced heli to achieve this.
My V120D01 likes a level(ish) swashplate, but this has a 3 axis gyro and no flybar.
On the smaller fixed pitch/coaxial helis, I think that adjusting the servo links to obtain a stable hover is the best method, regardless of how level or not the swash ends up being. Then use minor trim on the TX where needed, to compensate for different batteries etc.
Frank_fjs is offline Find More Posts by Frank_fjs
FAQ Nine Eagles Solo Pro I/II/V1/V2/270/Bravo SX FAQ (FAQ part in the first 3 postings!) SoloProFan Micro Helis 2138 May 11, 2016 01:24 PM
Discussion Revell Proto cx and Nine Eagles Solo Free Spirit EFEX ED Coaxial Helicopters 7 Feb 10, 2013 10:20 AM
New Product Nine Eagles Soar - Replacement for Solo Pro? zadaw Micro Helis 1 Dec 30, 2010 02:15 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted MCX, Nine Eagles Solo, Proto CX RTF k5beason Aircraft - Electric - Helis (FS/W) 0 Apr 18, 2010 08:02 PM
