Hampshire, UK
Joined Jun 2002
I sat down first thing and assembled some servos laid out representing a 4 wing just to see what I was doing wrong. Works perfectly using the simple mixer that was described originally and that MafRaf included some pictures of.
The only thing I can think of is the surface ordering as MafRaf mentioned. I used a new out the box model setup the ordering of which I did actually post above. This is different from Multiplex who do left, right, left, right from what I remember. |
Just looking at the screens posted by MafRaf I can see how easy the basic mixer is to set up, but there must also be a way of tuning the individual flap servos so they both have the same movement for the same aileron input - e.g. a curve or end point adjustment.
I assume there are separate screens for that? Can the individual servos be reversed there, and would that solve Tom's problem? Dick |
Hampshire, UK
Joined Jun 2002
I thought I would try a set of the Grumania trims. Whilst I haven't got an issue with the stock trims l'll accept that it is often possible to build a better mousetrap :-)
They were very easy to install. I did think they might be a problem in use as at home I felt my thumb caught the stick during some deflections. Had about 10 flights with them fitted yesterday and didn't even realise they were there so catching them not an issue in use. They certainly made trimming even easier although I do I need to be careful. The natural motion of dropping the thumb and pushing the stick puts pressure on at a diagonal. For now they are staying on. |
Norway
Joined Jul 2007
G-Trims
There are 4 "dots" of double sided self adhesive tape per trim. You put one "dot" on each button, and put the g-trim on top. They seem to be a safe fit when on.
I have used mine for some indoor flying, and they shure is easyer to use that the stock trims. The design is the same as on the 3D selector so its not that bad lookin either. /Baard |
![]() I may not have understood all the posts so I've probably missed something? / Ville, Mpx Royal Pro owner |
Hampshire, UK
Joined Jun 2002
I have no idea
![]() Quite different architecture to the Profi 4000. I kept mine just in case I didn't like the Jeti but in the last six months it hasn't been used at all. Haven't found anything I need that has defeated me and the other benefits like great sticks etc make it all worthwhile. I used to have a Royal Evo as did a lot of my club mates. Programming a four servo wing was a big problem for one of them until it was discovered he was ignoring the left, right, left, right rule. I loved my Evo but ditched it when their 2.4ghz solution was very late and very expensive. Was a nice set though. |
It is not my intention to sound like a "besser wisser", but I think that this feature is so widely used by many, that it should be a well described in the manual. I have decided to continue with the Multiplex, but it was not long ago the decision was made. I have during the past summer tested Futaba 8FG, and there was a positive surprise. A Very easy to use and easily programmed transmitter. Would love to test Jetis new transmitters, but unfortunately you can not try every transmitter out, too much of a work, and too expensive.
/Ville
Preston |
Hampshire, UK
Joined Jun 2002
The manual isn't bad but the examples are quite simple. The aileron to flap mix is described but is basic (and has a few copy paste errors).
This forum is mainly English speakers. The US hasn't had this radio long and it isn't popular in the UK. I have found good information on non English speaking forums. A mix like this really is quite basic and is bread and butter stuff. It took me 5 minutes from start to finish but I think the fact I had some spare time and no English manual when I got mine helped. I sat down with a bunch of servos and played. At the end of the day even the most advanced of these model radios is pretty basic with only a finite amount of options
Hampshire, UK
Joined Jun 2002
| Thread Tools | |
| For Sale NEW JETI Advanced 12 plus ESC | Tar-zan | Aircraft - Electric - Power Systems (FS/W) | 0 | Oct 28, 2010 06:18 PM |
| For Sale New JETI 08 Advanced ESC | Tar-zan | Aircraft - Electric - Power Systems (FS/W) | 0 | Oct 28, 2010 06:12 PM |
| Sold Neu 1910H/1Y + JETI SPIN 66 + JETI BOX | xatled99 | Aircraft - Electric - Power Systems (FS/W) | 3 | Oct 16, 2010 08:59 AM |
| For Sale Brand new! AXI 2212-34 and Jeti Advanced 12 ESC | Tar-zan | Aircraft - Electric - Power Systems (FS/W) | 0 | Sep 15, 2010 02:54 AM |
| For Sale REDUCED AGAIN! W/NEW CONNECTORS 40 Amp Jeti Advance Pro ESC W/Switch and Program card | Kevin Greene | Aircraft - Electric - Power Systems (FS/W) | 1 | Sep 09, 2010 10:45 PM |
