Old Feb 07, 2013, 12:27 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Originally Posted by satinet View Post
Hi
Yes and no. It works if you have a few flight phases on one switch, but not if you start to use a few flight phases on different switches.
T
I do not understand. If you can assign a sound to one switch, why not another. I have 3 on my 3 way switch and one on the switch next to it.
Preston
jaizon is offline Find More Posts by jaizon
Old Feb 07, 2013, 01:05 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
say if you have 3 phases on a 3 way switch and another with a higher precedence on another switch it would still sound if you moved the 3 position switch even though you weren't in that flight phase.
If it is like the p4000 I had you could also use logical switches, so you could have the same three position switch doing different flight phases depending on the position of another switch. Don't know if you can do that on the jeti though.
satinet is online now Find More Posts by satinet
Old Feb 07, 2013, 01:45 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
I am not familiar with the "higher precedence" concept regarding the Jeti DC-16.
I know that on my JR12X launch mode would take precedence over any other mode at any time (i.e., if you were in launch mode you could not switch to thermal), but once you came out of launch you could do anything.
As far as the second point goes I'm only guessing that you could do that using logical switches, but have no idea because I have not yet been able to figure out logical switches, even with some help in these forums. If you are successful at doing this please let us know. I have no need for logical switches which is why I have not pursued it further. I am strictly a sailplane only guy and for that this radio has done everything I need and more.
Old Feb 07, 2013, 01:47 PM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Not trying to be nasty, but if the P4000 is so good why not fit a Jeti TU module and a Jeti box, and get some of the Jeti benefits while keeping the programming you love?
neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Feb 07, 2013, 01:48 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Exactly correct in your description there Satinet.
To be clear. There are no sounds associated with any flight phases. Flight phases like rates & mixers are activated by events (switch position changes) which you setup. The playing of sound samples are triggered by events in the same way, but they are not connected. If you use the same switch trigger for both the flight phase change and a sound then you have a flight phase sound.
The problem as you have discovered Satinet is that whilst flight phases can be triggered they may not be actually activated as there is a priority order.
This is not so much a bug as a hole in the logic. What is required is the association of a sound sample to the activation of the flight phase.
This functionality has a whole thread in the features request sub forum of the JetIForum.
Logic switch functionality very sophisticated compared to the 4000 but I've not tried to see if it solves this problem.
wildpalms is offline Find More Posts by wildpalms
Old Feb 07, 2013, 01:50 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
neil.
I did My 4000 barely used now though.
Old Feb 07, 2013, 03:14 PM
jaizon is offline
jaizon's Avatar
USA, NH
Joined Mar 2008
I guess I'm not exactly following this recent conversation, but I've made this. Please excuse the orientation.
DC 16 switches (0 min 31 sec)
Old Feb 08, 2013, 03:26 AM
F3B
satinet's Avatar
Joined Sep 2006
With the jeti, and just about every TX above the basic stuff, you can assign which flight mode has the higher priority. As the jeti has 10 flight modes, all of which can be given a name, you need to decide which is higher in the order.
If it's like the p4000 you could have a 3 position switch that is 3 flight modes and once you flick a switch, it is 3 other flight modes.
Old Feb 08, 2013, 03:29 AM
F3B
satinet's Avatar
Joined Sep 2006
we're still on an early software version. I have hopes for the future.
Old Feb 08, 2013, 07:17 AM
Wetafly is online now
Find More Posts by Wetafly
Joined Feb 2004
I am using logical switches to switch into snap flight modes. So full up elevator + full right rudder switches into positive right snap flight mode and full down elevator + full right rudder switches to negative right snap flight mode etc. So I can tune each snap direction. I still need to work out how to turn the logical switches off for the spins.
Wetafly is online now Find More Posts by Wetafly
Old Feb 08, 2013, 07:32 AM
F3B
satinet's Avatar
Joined Sep 2006
nice. Glad to hear about that functionality.
Old Feb 08, 2013, 08:05 AM
Professional idiot
Hampshire, UK
Joined Jun 2002
I have similar requirements although a different mix. Throttle position may be useful if you always snap above a certain throttle setting. I also use the 2 position switch on the stick but have found the side slider even better lately.
I have an aileron to throttle mix. At almost full deflection I have the mix add a little throttle. I use a logic switch with throttle as an input to make sure the mix is off in vertical downlines. I also use the side slider to turn it off completely in the torque roll (where I have full aileron and half throttle).
Logic switches can be daisy chained as much as needed.
Old Feb 08, 2013, 01:22 PM
Joined Feb 2004
Hmm. I will work on that with a foamy.
Old Feb 13, 2013, 03:17 PM
F3B
satinet's Avatar
Joined Sep 2006
aileron to flap mix
Hi
(sound on event issue resolved btw)
Question:-
how do you make it so that a free mix of aileron to flap makes each flap move up and down a different amount (like aileron differential). Not different to each other, different up/down?
Via the curve?
Cheers
Tom
Old Feb 13, 2013, 03:53 PM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Mix of Aileron to Flap
A curve can work, but you do not need to use a curve if you only want a fixed percentage difference. For that case, I find using the mix itself is sufficient; i.e., you can adjust each of the flaps to be a different percentage value as well as change the sign...
I use the curve when I want the percentage change to be different across the range of control throw; then it fits the bill perfectly.
Michael
Hi
Question:-
Via the curve?
Cheers
Tom
Snowflake6515 is offline Find More Posts by Snowflake6515
For Sale NEW JETI Advanced 12 plus ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:18 PM
For Sale New JETI 08 Advanced ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:12 PM
Sold Neu 1910H/1Y + JETI SPIN 66 + JETI BOX xatled99 Aircraft - Electric - Power Systems (FS/W) 3 Oct 16, 2010 08:59 AM
For Sale Brand new! AXI 2212-34 and Jeti Advanced 12 ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2010 02:54 AM
For Sale REDUCED AGAIN! W/NEW CONNECTORS 40 Amp Jeti Advance Pro ESC W/Switch and Program card Kevin Greene Aircraft - Electric - Power Systems (FS/W) 1 Sep 09, 2010 10:45 PM
