Old Jan 26, 2013, 10:58 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Very out of trim sounds like a god use of auto trim. I'm not a fan but then usually only adding one kick or so. I did seem to work well when I did try it.
wildpalms is offline Find More Posts by wildpalms
Old Jan 26, 2013, 11:01 AM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Propo Control As Trim
I like to have separate nosewheel steering (NWS) that is proportional to the rudder, but with separate trim (air trim for rudder, ground trim for NWS.
When I setup the added function of NWS, I specify a side lever for trim, with 50% maximum. I also add a Free Mix of Throttle to NWS so that the throw amount is inversely proportional to the throttle position (reduced NWS sensitivity as throttle is advanced.) All controlled by gear in retracted position, of course.
The ability to trivially assign a separate trim control makes life so much easier. The more I learn, I find I go back and greatly simplify my programming. Not sure if this is praising the Jeti approach or admitting that I am a slow learner. :-) I do know that R1.07 greatly simplified my programming.
Michael
Originally Posted by wildpalms View Post
Back on the subject of trims I wonder how much attention has been paid to the fact you can assign additional proportional controls as trim adjusters.
This doesn't solve the general dislike of the trim layout for some (MC32 more conventional and functionally very similar to the Jeti).
If however you are interested in constantly retrimming one control several times during flight then it is a useful option.
A control such as one of the the side levers can be assigned as an additional trim control. You can select how much trim full travel produces. The conventional trims still work as programmed.
I don't fly F3B/F but could see this being quite handy back when I did fly 100S for fun.
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Jan 26, 2013, 09:50 PM
le fou is offline
Find More Posts by le fou
United States, OH, Cuyahoga Falls
Joined Apr 2006
Can you please explain how you have done this set up? I have the same kind of setup and I would like to reproduce what you have done
Le fou
le fou is offline Find More Posts by le fou
Old Jan 27, 2013, 12:08 AM
Professional idiot
Hampshire, UK
Joined Jun 2002
http://www.rcgroups.com/forums/showp...&postcount=289
Old Feb 02, 2013, 06:00 AM
plingboot is offline
Find More Posts by plingboot
Joined Oct 2010
I've just tried to upload some additional .wav files to my voices directory, but when i try to test them using the audio player i'm getting an error "invalid RIFF ID"
Anyone know what this is and how to correct it?
plingboot is offline Find More Posts by plingboot
Old Feb 02, 2013, 06:29 AM
pdugue is offline
Find More Posts by pdugue
pdugue's Avatar
France, IdF, Sucy-en-Brie
Joined Apr 2006
Hi,
try this:
- open audio file with Audacity (http://audacity.sourceforge.net/)
- menu => file => export => select type: WAV (Microsoft) signed 16bits PCM and change file name and/or directory => Save button => dialog box 'Edit metadata' => clear all values (if exist) => OK button
Hope this helps.
pdugue is offline Find More Posts by pdugue
Old Feb 03, 2013, 02:22 AM
Joined Oct 2010
Thanks for the reply, will give it a go later today.
Old Feb 05, 2013, 08:22 AM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Voice on event
Hi
How do you make the TX make a sound when you flick a switch.
I went to the relevant screen and selected a sound for a switch movement. It worked once on one switch but will not work again.
It will make sounds on startup etc, but not for "events".
Tom
satinet is online now Find More Posts by satinet
Old Feb 05, 2013, 08:49 AM
mosfetman is offline
Find More Posts by mosfetman
United States, TX, Allen
Joined Jun 2008
RIFF Problem: I had this problem as well and Jeti resolved it. You are actually pointing to a tag file that some operating systems (My iMac) produces. Search the forum for RIFF and you will find the write-up.
Jerry Prado
mosfetman is offline Find More Posts by mosfetman
Old Feb 05, 2013, 10:06 AM
F3B
satinet's Avatar
Joined Sep 2006
Jerry Prado
The sounds play if you press the play button when you are selecting them, so I am not sure it is related to a problem will file tags.
It should just work - it seems quite simple? I don't quite see why it would work when you press play or other events such as startup, but not if you want a switch to make a noise. The TX doesn't have any custom sounds produced on another device. Only the sounds that are with it.
Sound on event doesn't work. Well it worked once, but not any more. It has version 1.07.1 on it. Sounds on timers didn't work either last time i checked.
Also pity you can't assign a noise to a flight phase.
Old Feb 05, 2013, 11:46 AM
Professional idiot
Hampshire, UK
Joined Jun 2002
'Sounds on Event' works fine for me. I use quite a few of them all the time. In fact I rely on them a lot now.
The sound is for a switch trigger not just the switch E.G. I have it say 'armed' when a 3 pos goes from 1 to 2 but not when going from 2 to 3, 3 to 2 & 2 to 1
They are also model dependant whereas system sounds are global.
Can't associate sound with flight mode but then a flight mode is triggered by a switch so you can.
Old Feb 06, 2013, 08:16 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
You can absolutely assign a sound (Cruise, Thermal, etc.) to a flight phase (mode). I have a 3 position switch for Thermal, Cruise and Speed, another for Landing. Announcement are made for each change.
jaizon is offline Find More Posts by jaizon
Old Feb 06, 2013, 09:03 PM
Joined Jun 2008
All above is correct...However, there is a chance that the designers implemented a bit too much flexibility in terms of event driven voice while not providing alternate handling if a voice has just been assigned to a switch?. If you point a voice trigger to a switch...well...where does it live?? What if the voice you want is intended to be triggered only by a flight phase...by the same switch?
I know that this radio will do anything we need...we just have to learn the thinking behind the monster...kinda like communicating with the wife...
I love my DC-16!!
Jerry Prado
Old Feb 07, 2013, 03:20 AM
Trevorh is offline
Find More Posts by Trevorh
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
[QUOTE=mosfetman;24057376...we just have to learn the thinking behind the monster...[/QUOTE]
Exactly! One of the joys of the MPX 3030/4000 is that the mental model behind the programming is so simple. I get the feeling that for this Jeti beast, some form of functional block diagram would be really helpful.
The manual seems pretty good but, like most nowadays, is really just a guided tour of the user menu structure so gives no real insight into how the transmitter actually operates.
This would be a really useful thing for the guys at Jeti to do while we thumb flyers are waiting for our DS-16s
Trevorh is offline Find More Posts by Trevorh
Old Feb 07, 2013, 12:15 PM
F3B
satinet's Avatar
Joined Sep 2006
Hi
Yes and no. It works if you have a few flight phases on one switch, but not if you start to use a few flight phases on different switches.
T
For Sale NEW JETI Advanced 12 plus ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:18 PM
For Sale New JETI 08 Advanced ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:12 PM
Sold Neu 1910H/1Y + JETI SPIN 66 + JETI BOX xatled99 Aircraft - Electric - Power Systems (FS/W) 3 Oct 16, 2010 08:59 AM
For Sale Brand new! AXI 2212-34 and Jeti Advanced 12 ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2010 02:54 AM
For Sale REDUCED AGAIN! W/NEW CONNECTORS 40 Amp Jeti Advance Pro ESC W/Switch and Program card Kevin Greene Aircraft - Electric - Power Systems (FS/W) 1 Sep 09, 2010 10:45 PM
