Old Dec 09, 2012, 04:54 AM
alfasud is offline
Find More Posts by alfasud
Slovenia
Joined Jan 2009
Voices and audio samples are generated using online Text-To-Speech engines.
All files are free for general use; distribution and modifications are allowed.
If you are going to use these samples in your own application or want to create
other additional sound files, please refer to the websites and terms of use of
these generators.
Language: CZ
Generator: http://www.acapela-box.com
Voice: Eliska
Language: EN
Generator: http://www.ivona.com/en/recordings
Voice: Jennifer
Language: DE
Voice: Marlene
Language: FR
Voice: Celine
Read file on you DC-16 sd card \Voice\Voices.txt
alfasud is offline Find More Posts by alfasud
Old Dec 09, 2012, 07:05 PM
Esprit Model is offline
Find More Posts by Esprit Model
espritmodel.com
United States, FL, Melbourne
Joined May 2010
Thank you, this is excellent I will post your information all around the web.
Zb/Esprit Model
Esprit Model is offline Find More Posts by Esprit Model
Site Sponsor
Old Dec 10, 2012, 04:55 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Here is a pot in stick mod I done for camera gimbal control.
The dc do not have the option for assigning potentiometer to the stick only switch, 2 and 3 position. So now my pots can only function as a 2 or 3 position switch.
I ask jeti via email if they can add pot selection to sticks
if others are interested in having pots in stick for the dc16 they should send jeti an email. The more interest the faster they will add it to up coming firmware.
My pots are from graupner mc32 pot sticks.
Very easy mod just need to rim out the stop from inside a jeti switch stick and cut the stem off the graupner pot.
Description: Name: ImageUploadedByTapatalk1355136715.881088.jpg
Description: Name: ImageUploadedByTapatalk1355136754.056748.jpg
Description: Name: ImageUploadedByTapatalk1355136806.773121.jpg
Description:
hexa is offline Find More Posts by hexa
Old Dec 11, 2012, 02:10 PM
plingboot is offline
Find More Posts by plingboot
Joined Oct 2010
can anyone help with setting up the failsafe?
plingboot is offline Find More Posts by plingboot
Old Dec 12, 2012, 03:12 AM
GordonTarling is online now
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
What do you want to know? It's done via the transmitter's virtual Jetibox just like in days of old. I've been told that this issue is being addressed and will probably be changed in the next firmware update or two.
GordonTarling is online now Find More Posts by GordonTarling
Old Dec 12, 2012, 03:16 AM
Joined Oct 2010
@gordon, thanks for the reply. I've just switched to jeti from other makes, so don't have any previous experience to fall back on.
Basically on both an E9 and E18 i want a failsafe state where the throttle is at 50% and a flightmode (rth) switch is in a certain position.
Don't suppose you have any advice on allocating channels between two receivers in 'dual mode' too?
Old Dec 12, 2012, 03:20 AM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
do you still have to set each channel rather than a sane system like pressing a button while you have the controls in the position you want?
satinet is online now Find More Posts by satinet
Old Dec 12, 2012, 04:36 AM
alfasud is offline
Slovenia
Joined Jan 2009
Yes ! And this is very good thing.
All servo output have default FailSafe setting to keep current position. Via JetiBox emulation in DC/DS -16 you can set FailSafe position for just those servos you want to go to some preset position. Others should keep current positions. Consider this situation:
Big scale glider of some 20 kg of weight sitting on undercarriage. Power in the plane is on, as well as TX. You are on the break and waiting for your turn for tug.
Now, what will happen when you turn off first TX and then Rx. FailSafe will kick on. If you set undercarriage servo to keep current position, all will be good. But if you set this servo to upper FailSafe position, you will have problem. Imagine same scenario with big scale Mustang.
So, if your only option is to set ALL servos FailSafe to preset position, like some other brands, this is bad. Jeti has much better solution.
You can set "Signal Fault Delay" too. This is time between signal loss and FailSafe action, default is 1,5 sec.
Correction: Individual output in Jeti Rx can be set to three (3) settings:
1 - Keep current position (default)
2 - Go to preset position
3 - Output is switched off
Every Jeti rx has manual included, or you can download it here http://www.jetimodel.com/data_downlo...1-07-en-de.zip
Old Dec 14, 2012, 04:22 AM
Joined Oct 2010
Kinda figured out the failsafe set-up procedure now.
Without malice - it does seem to standout from the rest of the DC-16 interface as being a bit odd.
I like the like the fact you can tune each channel's reaction for the failsafe condition, but it would be good to rework the interface (for such an important function) into something a little more clear and intuitive for those of us who are new to jeti products.
Finally for now, still not worked out how to allocate channels in dual receiver mode… anyone have any thoughts?
I'm wanting to have two receivers on my multirotor setup - one for the MC and the other for the gimbal control unit - i need to separate the two for transportation hence the requirement.
Old Dec 14, 2012, 05:43 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Simply bind 2 receivers to the transmitter. One receiver as a master and one as a clone. Clones don't talk back.
In the receiver programming you can set an input channel for each if the output channels.
A handy way of having multiple servos connected to a single input channel IE dual elevator servos. A handy way of getting more outputs from low channel count receivers (2 6's make a 12). A handy way of distributing systems around a physically large system.
wildpalms is offline Find More Posts by wildpalms
Old Dec 14, 2012, 05:53 AM
Joined Mar 2001
pling - the failsafe interface will be upgraded at some point, but for now, it's easy enough once you've done it a couple of times. Wildpalms is right about setting one Rx as clone, just remember that once it's in clone mode, you can't change anything and that you'll need to connect an 'old style' Jetibox to it in order to switch it back to normal mode for changes.
Old Dec 14, 2012, 07:01 AM
flymustangs is offline
Find More Posts by flymustangs
USN (retired)
flymustangs's Avatar
Idaho
Joined Jul 2007
Why is the 'old style' Jetibox needed to switch it back?
flymustangs is offline Find More Posts by flymustangs
Old Dec 14, 2012, 07:52 AM
steve1814 is offline
Find More Posts by steve1814
One cell short of a Pack
steve1814's Avatar
Good ole Smithsburg, MD
Joined Mar 2007
Does the Transmitter come with the button and toggle switch installed on the sticks? I couldn't find anything that confirms nor denies this.....
Cheers,
Steve
steve1814 is offline Find More Posts by steve1814
Old Dec 14, 2012, 07:57 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Negative, it comes blank I believe and if you want to buy the buttons/switches you can purchase them here.
http://www.espritmodel.com/transmitt...ries-jeti.aspx
Sid3ways is offline Find More Posts by Sid3ways
Old Dec 14, 2012, 10:45 AM
hexa is offline
hexa's Avatar
Joined Nov 2010
Would be nice to have a multirotor icon other than plane and heli.
For Sale NEW JETI Advanced 12 plus ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:18 PM
For Sale New JETI 08 Advanced ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:12 PM
Sold Neu 1910H/1Y + JETI SPIN 66 + JETI BOX xatled99 Aircraft - Electric - Power Systems (FS/W) 3 Oct 16, 2010 08:59 AM
For Sale Brand new! AXI 2212-34 and Jeti Advanced 12 ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2010 02:54 AM
For Sale REDUCED AGAIN! W/NEW CONNECTORS 40 Amp Jeti Advance Pro ESC W/Switch and Program card Kevin Greene Aircraft - Electric - Power Systems (FS/W) 1 Sep 09, 2010 10:45 PM
