Old Nov 23, 2012, 08:51 PM
Geoff_S's Avatar
Brisbane, Australia
Joined Feb 2002
Originally Posted by ibuild View Post
This is how I have solved it.
Nice. Did you make new levers yourself, or modify the existing ones ??
Geoff_S is offline Find More Posts by Geoff_S
Old Nov 23, 2012, 09:31 PM
perfectly imperfect
ibuild's Avatar
Joined Jul 2011
Thanks!
They are molded in epoxy and carbon particles.
The aluminum colored parts is epoxy and aluminum powder.
The handle was part of a modelknife shaft.
Regards
ibuild is offline Find More Posts by ibuild
Old Nov 27, 2012, 06:27 PM
Joined Nov 2012
Sorry if this may sound stupid, I'm looking at buying a Jeti DC-16.
If you have one how do you like it?
Are there any software issues?
With the Transmitter Cross Strap, dose it cause any back pain? And
Is the DC-16 heavy?
Should i wait for the ds-16 or just go with the DC-16?
FPV10 is offline Find More Posts by FPV10
Old Nov 28, 2012, 02:36 AM
Joined Feb 2004
Is the DC-16 heavy?
Over the years using a number of different tray/strap designs this is the style that suits me best. The weight is on the shoulders and I feel relaxed and comfortable.
It is noticeably heavier than my Hitec A9 but worth it for the build quality.
If you fly with a tray go with the DC-16.
Wetafly is offline Find More Posts by Wetafly
Old Nov 28, 2012, 02:49 AM
Joined Nov 2012
Yeah, the one reason why im going for a Jeti DC-16 is because the build quality; it looks a lot like Leica build quality. And looks a lot better than Futaba and Spectrum transmitters, unlike the Futabas and Spectrum it dose not have any cheap plastic constriction... Well i cant wait to order mine Looks a lot like a Leica M9 in particular
Old Nov 28, 2012, 10:01 AM
Joined Oct 2010
Received my DC-16 yesterday, very pleased, but the german manual isn't that much help for those of use speaking english :-)
I've worked out how to set-up a count down timer which is triggered on throttle up, however I'd like to set-up a voice alarm to tell me when it reaches zero… and ideally speak up as each minute passes. "six minute", "five minutes"… "zero"
Could anyone help?
plingboot is offline Find More Posts by plingboot
Old Nov 28, 2012, 11:03 AM
Slovenia
Joined Jan 2009
Could anyone help?
English manual http://www.jetimodel.com/data_downlo...08-2012-6a.pdf
Read "Timers" in manual.
In short:
Go to "Timers/Sensors -> Timers" and edit your existing timer or add new one.
In timer editing screen set "Report type" to "Voice". Be shure that you have set "Sound profile" to "Beep+Voice" in "System->Configuration" menu.
If you like "Machines that goes Piiing",
Monty Python - Hospital Sketch (3 min 32 sec)
like I do, then unzip and copy attached file "TimerV.jsn" to your DC-16 SD card to directory "Config". Upon timer expiration it should say "Piiing"
alfasud is offline Find More Posts by alfasud
Old Nov 28, 2012, 12:44 PM
Joined May 2010
With setting to "Voice" the system counts down last 10 seconds and beeps.
Zb/Esprit Model
Esprit Model is offline Find More Posts by Esprit Model
Site Sponsor
Old Nov 29, 2012, 03:46 AM
FeffeSvl's Avatar
Sweden, Sundsvall
Joined Aug 2011
If you have one how do you like it? Have it (DC16 since 5 months now), love it! Also own Spekky DX7 & 8 since before but the DC16 is a class of its own against all other IMHO
Are there any software issues? The software works fine, and the Jeti team is continuing to add more features for free so no complaints from me
Is the DC-16 heavy? Nope and no, if anything a tray radio/cross strap solution is better for long-term use since it reduces the risk of stress in the neck (as from neck-strap use).
Should i wait for the ds-16 or just go with the DC-16? I only used hand-held transmitters before the DC16 and I don´t regret going tray on the Jeti, if anything it gave me the push to learn pen-grip on the sticks which I find great now. But radio style is a personal choice, if you like tray or can adapt to it go for the DC16, if not then wait
See my comments in the quote!
FeffeSvl is offline Find More Posts by FeffeSvl
Old Nov 30, 2012, 07:58 AM
perfectly imperfect
ibuild's Avatar
Joined Jul 2011
Could anyone help?
Hi,
The obvious and simplest thing to do is ofcourse to use the speach system, if this satisfy your needs.
However, if you want a specific timer/readings, you can make an audio file with exactly the messages you want, and arrange them in time.
You can do this simply on the PC with the Windows Narrator (screen reader), then edit the recorded audio (or use the original audio messages in the transmitter audio folder) and arrange it in time in a free audio editor like Audacity or similar.
Just trigger the sound file at the same time as you trigger a freerunning timer.
Regards
Old Dec 03, 2012, 01:37 PM
Bristol, Great Britain (UK)
Joined Apr 2004
Self centring on both sticks? - Is it possible?
Hi All
I understand from earlier posts that changing a transmitter from mode 1 to mode 2 requires the stick assemblies to the swapped. Is this because the two stick units are mechanically different?
Is it possible to have both of the stick units set up so that they self centre on the vertical axis?
I spend all of my time flying gliders and would like to have the throttle stick set so that it self centres, instead of having a ratchet. Is this possible?
Thanks in advance
Keith
groom_k is offline Find More Posts by groom_k
Old Dec 03, 2012, 03:29 PM
Sverige, Värmlands Län, Filipstad
Joined Jan 2009
Hi,
Just cusrios: Jeti DC-16 is avaliable in mode 5, both sticks self neutralizing.
What may it be used for?
http://www.hacker-motor-shop.com/e-v...&c=6134&p=6134
/Bo
bossee is offline Find More Posts by bossee
Old Dec 03, 2012, 05:14 PM
Joined Apr 2004
Hi
Bo - Thanks for the link, that's great news.
I'm sure there are a number of reasons people want both sticks to be self centring.
Mine is that I use the throttle stick to control the flaps and crow brakes on my aerobatic gliders. The flaps are set so they are in the neutral position when the stick is in the centre.
Cheers
Keith
Old Dec 08, 2012, 12:44 AM
Joined Oct 2009
Dragon Link
Has anybody tried the Jeti TX with Dragon Link long range system?
PistaJ is offline Find More Posts by PistaJ
Old Dec 09, 2012, 03:16 AM
Joined Oct 2010
does anyone know what program/computer voice name jeti have used for their speach files?
i'd like to generate some custom voice commands, but want to match the voice.
had a go with the various voices on the mac, but can't find one which matches.
i also noticed what i think is a glitch on my dc-16 telemetry voice report, when speaking the antenna values the voice seems to cut-off, as though there's a missing word from the voice library.
other than that, and a spelling error in one of the sub menus, i think this is a superb radio, very pleased i made the switch to jeti.
For Sale NEW JETI Advanced 12 plus ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:18 PM
For Sale New JETI 08 Advanced ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Oct 28, 2010 06:12 PM
Sold Neu 1910H/1Y + JETI SPIN 66 + JETI BOX xatled99 Aircraft - Electric - Power Systems (FS/W) 3 Oct 16, 2010 08:59 AM
For Sale Brand new! AXI 2212-34 and Jeti Advanced 12 ESC Tar-zan Aircraft - Electric - Power Systems (FS/W) 0 Sep 15, 2010 02:54 AM
For Sale REDUCED AGAIN! W/NEW CONNECTORS 40 Amp Jeti Advance Pro ESC W/Switch and Program card Kevin Greene Aircraft - Electric - Power Systems (FS/W) 1 Sep 09, 2010 10:45 PM
