Old Jan 25, 2013, 04:55 AM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by Cheese5 View Post
How does this helical look? Shooting for 5.945ghz hopefully this with the wide bandwidth falls somewhere near it.
Is there a way to keep the copper from rusting? Acrylic paint?
Note, the centre wire from the point where the mesh connects to the helical coil technicalls spoken is now also part of the coil in your design!
You better would have feed the coil from the back by drilling a hole into the reflector at the spot wher it should meet the end of the coil. Then solder the mesh to the reflector and the center wire with only about 0.5mm spacing directly to the coil. You of course also can side feed it (albeit the coax will have some small negative impact) but then you would have to run the ground mesh as close to the coil as you manage!
It probably still will work, but the way you feed the helical will have significant impact on the impedance matching of the antenna. Since this is what you most likely can't measure, you have a little problem here. Note though that it could be "good" or bad - we just don't know. It's more likely to be bad though as that little part of center wire will radiate too.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 25, 2013, 05:31 AM
Aussie, Aussie, Aussie!
nrg2go's Avatar
Melbourne, Australia
Joined Apr 2009
Originally Posted by nrg2go View Post
So my very first Helix
Hopefully she works well.
Attachment 5061424Attachment 5061425Attachment 5061426Attachment 5061429
Edit: I think I mis-interpreted the wave trap positioning? I put the middle of the trap at the 1/4 turn, when the trap should be in the middle of the 1/4 turn. Do you think it will put it way out?
I bottom fed mine, pics back at post 1024, need to make another one as I gave this one to a mate of mine.
nrg2go is offline Find More Posts by nrg2go
Old Jan 25, 2013, 08:04 AM
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
Will painting the reflector have any negative effect on performance?
I was thinking of protecting the copper from corrosion.
PinDuke is offline Find More Posts by PinDuke
Old Jan 25, 2013, 08:16 AM
Registered FPVer :)
Joined Aug 2006
Painting the helical usually lowers the resonant frequency a bit. Do not use any paint that contains carbon or any other conductive material. Painting the reflector allone should not hurt.
HTH
Markus
Old Feb 02, 2013, 08:00 PM
John 3:16
Cheese5's Avatar
United States, CA
Joined Jul 2010
Thanks Marcus, got it working well.
Cheese5 is offline Find More Posts by Cheese5
Old Feb 03, 2013, 06:01 AM
Expert Crasher
Malaysia, Federal Territory of Kuala Lumpur, Kuala Lumpur
Joined Nov 2011
thw formula for pvc former said 3000 - 4600/in Mhz which mean smallest pvc outer diameter i can use is 2.343" for 1280Mhz correct?
skellator is online now Find More Posts by skellator
Old Feb 03, 2013, 10:24 PM
Expert Crasher
Joined Nov 2011
this my 1280Mhz 5 turn helix, not my best but hopefully it work, i used a very thick galvanized steel wire instead of copper, i use rg316 as i do t have rg58 hopefully it do the job for now
Description:
wave trap
Description:
painted and waiting it to dry right now
Description:
Old Feb 04, 2013, 04:36 AM
Registered FPVer :)
Joined Aug 2006
I don't know to what formula you refer, but I usually recommend people to use THIS online calculator to get the propper numbers:
http://jcoppens.com/ant/helix/calc.en.php
It bases on formulas given by the ARRL handbooks (forgot which one exactly) which are profen to be correct.
HTH
Markus
Old Feb 04, 2013, 04:40 AM
Expert Crasher
Joined Nov 2011
HTH
Markus
formula from the first page of course , to late for that now
Old Feb 04, 2013, 08:10 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^You are fine. My calculations are based on the ARRL antenna bok Chapter 19 - Antennas for space communications.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 04, 2013, 08:22 AM
Expert Crasher
Joined Nov 2011
-Alex
great but this thing is hugeeeee i need a new tripod i dont think my small current tripod can survive
Description:
Old Feb 06, 2013, 10:41 PM
United States, CA, Ukiah
Joined Jan 2011
5.8 ghz helical
This is my first 5.8 ghz helical, I used a 11/16" outside diameter plastic tube with 6 turns of copper wire. I get a good signal over a 90 degree arc at 3/4 mile away with a 500mw cloverleaf tx. I can't wait to finish a couple more of these and put them on IB's antenna tracker, I think I could get at least a couple of miles of range with this setup.
devinvagt is offline Find More Posts by devinvagt
Old Feb 07, 2013, 03:41 AM
Registered FPVer :)
Joined Aug 2006
Is the antenna coil wire on top really bent inwards and penetrates through the tube to the inner side? If so, bad idea.
The other thing is that the feed gap is on the very longish side of things. You better use a copper sheet for the reflector and bring the coax in from the back through a hole directly at the spot where the coil ends. You then can solder the mesh directly to the reflector and have a tight connection of the center pin to the start of the coil.
For "several miles" you should eventually increase the number of turns to 8.
HTH
Markus
Old Feb 07, 2013, 12:01 PM
Hitech soaring
Germany, BW, Stuttgart
Joined Jan 2013
IBCrazy Cross Helix please check
Hello IBCrazy, this is my 1280Mhz Helix made with your calculations for the cross Helix. Do you think I am still right in size with this material? We used 3mm Makralon (Plexiglas) and PCB material for the reflector.
I used a Helix diameter of 70,8mm and a 1turn distance of 55,56mm as you calculated for the cardboard version. Do I have to modify the size?
Regards Peter
Pitpilot is offline Find More Posts by Pitpilot
Old Feb 07, 2013, 01:16 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
@Pitpilot - We have a term for that antenna: Perfection. Nice work! Now you just need to hook up your cable to it.
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 Video Piloting (FPV/RPV) 22 Oct 15, 2011 04:46 PM
Discussion Left/Right circular polarized antenna ? SpookiePower Video Piloting (FPV/RPV) 44 Jun 04, 2011 06:41 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV/RPV - Equipment and Vehicles (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou Video Piloting (FPV/RPV) 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford Video Piloting (FPV/RPV) 20 Nov 04, 2010 06:48 PM
