Old Mar 10, 2011, 11:30 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not really. There is a bit of confusion when it comes to the 3db drop. I will try to explain:
A CP omni antenna eqivalent to a 1.9 dbi Vee has a gain of about .5 db
A Vee has a gain of 1.9.
Thus if you use the Vee on your plane your realized drop is more like 1.5 db, not 3. The reason is that a circular must polarized in all therr dimensions where the Vee only ploarizes in one.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 12, 2011, 01:56 PM
Wingnut13 is offline
Find More Posts by Wingnut13
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
I'm gathering parts for my 1280MHz antenna build. The question is for my application would 3/8" copper tubing work? (it's what I have layin' around) or is 1/4" the top end of the spec.
Thanks guys, and Alex! ~Wingnut13
Wingnut13 is offline Find More Posts by Wingnut13
Old Mar 12, 2011, 08:06 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
3/8" would work very well if you can bend it. That's about the biggest that I would go for 1280MHz. I personally like 10 AWG wire because it is easy to bend
-Alex
Old Mar 13, 2011, 08:24 AM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Pack the tubing with sand before bending, it should make it bend a lot nicer.
PS: Any updates on the quadrafilar helix testing Alex?
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Mar 13, 2011, 09:38 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I like that sand idea! What a great way to keep it from kinking up!
I have not done anything more with the quadrafiliar helix, and I probably won't. It is extremely difficult to build and doesn't seem to have any advantage over any other type of antenna. It is a cool looking design, but the radiation pattern is suited for high altitude and that's about all.
Old Man Mike discovered that if you flip two skew-planar wheels and spaced them 1/2 wave apart, 180 degrees out of phase, you get a great moderate gain omni directional antenna. Granted it's complex, but it's easier than the Quad helix.
-Alex
Old Mar 13, 2011, 10:19 AM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes packing with sand work very well. Also, if you can heat the pipe to a red glow and let it cool, you'll see it'll be much easier to bend.
Alex,
I tried your "current draw method" with my 2.4ghz 500mw lawmate tx and found the stock omni pulled the most, followed by my 11dbi patch, my helix came third and lowest is my CL.
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Mar 14, 2011, 03:58 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Here's my sentinel rail-gun
Old Mar 15, 2011, 11:43 AM
Wingnut13's Avatar
Joined Jan 2011
Here is what I did this morning before work. I used a 20" section of PVC conduit as alex spec'd in his build. I made all the markings and drilled a hole at the starting end for the copper to be held by. The chucked it up in my lathe and started turning coils. This is what I had laying around for copper so that's what I used. 1/4" and 3/8" tubing. There were no kinks but where the copper was held in the PVC, no sand had to be used, copper is very forgiving. It's a good trick for bending exhaust tubing though! Also it looks like I could make one longer if I had to.
Alex I'll send one of these out if you would like to check it out as a antenna. I just received my TX yesterday and this is all new to me......
~wingnut13
Old Mar 15, 2011, 01:04 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Go ahead and send one my way. If you want, I will match it for you, give you the SWR, and give you the frequency response data. With the thick tubing, the matching is less critical, but still a good idea. If you feed it very close to the reflector, you might not even need to match it at all with the 3/8" tubing.
-Alex
Old Mar 15, 2011, 05:52 PM
Joined Mar 2010
For some reason I can't stop thinking about moonshine...
Old Mar 15, 2011, 06:24 PM
empeabee is online now
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Or revenuerz...
empeabee is online now Find More Posts by empeabee
Old Mar 23, 2011, 08:49 AM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Does anyone have a helical model for NEC2?
Old Mar 23, 2011, 11:02 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
NEC file
Ask and you shall receive.
-Alex
Old Mar 24, 2011, 03:21 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Thx Alex,
I made a model based on my construction above, however in 4NEC2 it resonate close to 3ghz instead of 2.5
Old Mar 24, 2011, 04:25 PM
Papat is offline
Find More Posts by Papat
Pat K
The Netherlands
Joined Dec 2010
Hi Alex,
thanks for the wonderful job you've done on FPV and for sharing your experience with us. What wire size would you recommend for a 5,8GHz antenna? Sorry if this has already been said but I could not find it.
Pat
Papat is offline Find More Posts by Papat
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
