For a 5.8 antenna are there any thoughts on using 1mm stainless wire for the coil? Soldering to it is not a problem, I am wondering if it has to be copper or what I have to change to get equivalent performance. I have the stainless, 316, and it will hold it's shape so I thought it could take more "abuse".
Thanks for the response. Yes winding step is what i was refering to. ![]() I used .25 as the quarter wavelength instead of .23 so thats what gave me 12.9mm step rather than 11.8mm. What will the difference be at .25 (12.9mm) and why is it .23 rather than .25 (quarter wavelength?) Should i change it to 11.8mm (.23)? I have access to a SWR meter so will 'attempt' tuning with that. With that in mind i would like to start with the right (or 'best' if there is no right) build measurements so that i can tune it with the wave trap. I dont expect it to ever be 'perfect' but would like to go into this giving my self the best shot at getting close. ![]() I am using 1.5mm copper coated PCB for the reflector, would it be possible to just reverse the pcb and lay the first quarter of a turn and the wave trap flat on the fiberglass backing, achieving an exact seperation of 1.5mm?? or does it need to be .4mm as per jcoppens calculator, or just as close as possible with out touching? Thanks for any help. |
Joined Jun 2012
hi all first post here i just built my first 5.8ghz 5 turn helical antenna and tested it yesterday and was only able to get a max range of 1.2km. Attached are the photos anyone recomend adjustments i can make to push it out a little further on 5 turns ive read through and seen people getting up to 3km with them.
Also attached a photo of my cl anyone able to tell me if its right hand polarized or left? i made my helical right hand polarized so if i got the wrong might explain why my range isnt that great. Thanks every one in advance |
Regarding the reversed reflector, you don't want that as the velocitiyfactor of the PCB material would come into play. Make the reflector bigger than the minimum size. I recommend around 5cm diameter, maybe a little more. The feed gap distance will be part of the tuning, so just adjust the wavetrap acordingly if like you say have acess to an SWR meter. Markus |
Bump
Markus |
Mckinney,TX
Joined Oct 2010
Anyway would the Cl and helical (10 turn) be a good choice to get a well rounded diversity w/ tracker setup? I'm running the ezosd so I want to use it tracker feature. Thanks |
United States, MA, Sturbridge
Joined Jun 2008
Yesterday I was sitting in my living room on the front side of my house. Had the helical (4.5 turn) pointing out the front window. Video hooked to my 32" tv was flyign around in front of the antenna with the tri, then decided to see how far I could go in the back yard (back side of the antenna. Wow I was surprised I had nearly perfect video through several double layer plaster walls (sheetrock over plaster) and the back wall of my house is 3 layers of sideing, vinyl over, concrete board, over wood. and I was able to fly a 150 ft away even at 8 o clock (if the helical was pointing at 12) with no real loss of video. I turned around and flew into the garden fence and broke a prop. But that was my fault.
Today I flew my CL with 5 lobe FAN on the rx in the living room. was pretty good, but not as good as the helical not even as good as the backside of the helical. Its pretty fun to fly like that though. I can do laps around my house. Now I jsut want to see if I can fly directly over the roof (3 stories up) with the fan antenna. The shingles might proof too much through two floors. I clipped my power lines with the tri and it landed right on the CL breaking off the wires. Man these thigns are harder to fix than to make, all the lobes fell off when I tried to repair it!
| Thread Tools | |
| Discussion Circular-polarized Patch Antenna for 5,8 GHz | Lonestar78 | Video Piloting (FPV/RPV) | 22 | Oct 15, 2011 04:46 PM |
| Discussion Left/Right circular polarized antenna ? | SpookiePower | Video Piloting (FPV/RPV) | 44 | Jun 04, 2011 06:41 PM |
| For Sale 2.4 gh 8 dbi patch antenna $10 | norberto83 | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Dec 03, 2010 07:44 PM |
| Question 30 dBi Grid Antenna | matyou | Video Piloting (FPV/RPV) | 7 | Nov 14, 2010 10:32 PM |
| Discussion Anyone tried building a helical antenna for FPV? | Bill Sanford | Video Piloting (FPV/RPV) | 20 | Nov 04, 2010 06:48 PM |
