Old Mar 02, 2011, 10:34 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
You want the whole antenna or just wood? Pm me or email me your address. I sent you a message and some drawings.
Derek_S is offline Find More Posts by Derek_S
Old Mar 02, 2011, 10:55 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Derek, If you are going to make these, you need a repeatable match. I will come up with a match that works with this perfectly so there is no guess work. We'll go with a tapered match to make it easy to replicate. It will also scale better.
I got your drawings and updated them a bit. If you can cut me a sample or two for 5 turns, I will design a tapered match for you, build up one antenna and send it back to you ready to go with perfect SWR. I will also send you some tapered matching stub samples to build more of your own.
In addition, send me a couple of the antennas you have already made, I'll let you know how close you came to the mark, tune it for perfect SWR and send it back to you
-Alex
KJ4RIV
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 02, 2011, 02:16 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
I would like to contribute to this. I can build a 2414 MHz antenna (I will build 2) if we can settle on the correct dimensions for the various parts including the tapered match. I can then send them to Alex for testing. I would like to make both 5 and 7-8 turn versions, perhaps 2 of each. I think I can use scraps of pcb board for the ground planes, or we have lots of aluminum or sheet metal lying around our shop at work.
It might help me get started if someone could share their source for the cables and connectors as well so I can get an order placed.
I also have a spare IntelligentRC 2.4 500mW tx that we can use for testing if necessary, given that my TS2 did a dirt dive last weekend. I don't know how much 2.4 GHz gear Alex has. I also have a spare RX.
-Tom
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Mar 02, 2011, 02:27 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I will send you cables if you need them. Everyone takes forever to ship other than a select few. I can have them to you in 3 days - free.
Do you have a drawing for your design? if so, send it to me at gadgetinventor <at> yahoo and I will take a look at it and verify the dimensions. You can use the equations on the first page.
Also, use galvanized steel for the ground plane. Aluminum won't solder.
@Derek - I made another correction to your drawing and sent it back to you.
-Alex
Old Mar 06, 2011, 07:32 PM
KC9TPL- Get Legit
Joined Aug 2007
Hi Alex,
I've got spring break coming up in a week and some time to work on antennas. I have enough stubs to make the cloverleaf and skew planer antennas, but I want to make several dipoles and helix antennas for you to test. If I shoot you some money for shipping via paypal could I take you up on your offer to send me some cables?
Tom
Old Mar 07, 2011, 06:24 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes. I just need your address. The helix is a fickle beast. You need to be VERY precise with the match. This is why I recommend using the conductor match or the Hecker transformer.
I put a piece of 1/8" balsa under a 1/4 wave section of 1/4" tubing and it gets the SWR near perfect every time. The hecker transformer works like magic and can be way off, but it attenuates the signal a bit.
I personally use the tapered stub match, but that's because I have the testing equipment to make it perfect. The tapered match usually gets very close on a blind try. The trick is the feedpoint. You need to make the base of the tapered stub as wide as the coaxial cable (or just a bit less) and make the coaxil cable feed in perfectly flat and secured against the ground plane. This is where the matching is most critical. Get it correct and the antenna becomes the best antenna you'll ever use (until I develop the CP BiQuad ).
-Alex
Old Mar 07, 2011, 08:02 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
My 2.5ghz 12 turn helix:
I decided to use the tapered strip match., coax feed is from the bottom.
Note that I still need to cut the helix to make it exactly 12 turns.
Hugeone is offline Find More Posts by Hugeone
Old Mar 07, 2011, 11:29 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nice build Hugo. What wire gauge did you use? 10 and 12AWG work best in my experiments for 2.4GHz.
Also, how are you planning on tununig that beast?
-Alex
Old Mar 07, 2011, 11:37 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Thx Alex!
It is copper tubing about the size of 12awg, but much lighter.
I'm thinking of buying a meter like yours. If not, I'll go for a diversity match against a 11db patch and see what can make it better than the patch.
-Hugo
Old Mar 07, 2011, 11:44 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you were careful with your measurments you will be below 1.5 SWR. I have yet to make one with higher SWR on the first try. Like I said, that feedpoint is very fickle. That's why I recommend not tapering the match to a point as I was doing before.
In any case, prepare to be amazed at what that antenna will do with a skew-planar wheel or Cloverleaf on the TX.
-Alex
Old Mar 07, 2011, 12:07 PM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I did not made it sharp, it's a bit wider that it's height above the ground plane, rest is as acurate as my caliper.
I have both CL and SPW ready, just need some snow to melt and this FPV season's gonna rock.
What difference make a 1.5 SWR to a 1.1SWR?
-Hugo
Old Mar 07, 2011, 12:49 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
-Hugo
Very little on the RX side. TX side you get about 70% power out. On the RX side you get about 90% efficiency out. Not bad. RX impedance isn't well specified like TX impedance is.
-Alex
Old Mar 07, 2011, 12:51 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Is that 90% efficiency of the estimated efficiency of the helix (you stated the 12 turn is about 60% efficient)
Old Mar 07, 2011, 01:06 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes. Efficiencies are multiplied. High gain antennas typically have low efficiency. The helical is a decent antenna for the most part. It beats grid antannas which are usually 50% or less.
-Alex
Old Mar 10, 2011, 10:00 AM
Blue Chip is offline
Find More Posts by Blue Chip
Honey Badger
Blue Chip's Avatar
United States, FL
Joined Oct 2005
So is it safe to say that a 12 turn would drop to about 9.5dbi when used with the V antenna?
Even though the tx side is lineal - and the rx side is circular - does it really make that much of an improvement - even if the antennas aren't matched?
Also - anyone seeing any kind of distances (3+ miles) out of a mismatched setup yet?
Blue Chip is offline Find More Posts by Blue Chip
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
