Old May 23, 2012, 06:32 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Originally Posted by Slaphappysamy View Post
...... CNC using sw/solidcam....
https://vimeo.com/42712761
That's why the rest of us can't have nice things!!
idletime is offline Find More Posts by idletime
Old May 24, 2012, 09:32 PM
Slaphappysamy is offline
Find More Posts by Slaphappysamy
United States, TX
Joined Oct 2010
lol. I snuck out in the shop tonight after dinner and got the acrylic machining and assembly finished. I liked white better than blue so I went with it for the base caps. Should make Sat's work a breeze now.
Slaphappysamy is offline Find More Posts by Slaphappysamy
Old May 25, 2012, 11:55 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by wannabe View Post
Dosent the wave trap have to be paralell with the reflector?
No. That's a microstrip match. I found the wavetrap to be easier and more precise. The wavetrap is just a rectangular piece of metal. The microstrip is curved.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 25, 2012, 03:51 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
-Alex
Golly! I went to great legnths to make thing flat!
wannabe is offline Find More Posts by wannabe
Old May 29, 2012, 05:41 AM
terencechan is offline
Find More Posts by terencechan
Rotary~myPast,Present &Future!
SINGAPORE
Joined May 2006
Originally Posted by ricknoon View Post
Tonight my wife and I tested out my first attempt at a helical antenna. I compared the helical with my cloverleaf antenna (which is proven out to 2km on my plane) by driving our Saturn line of sight and marking where the signal dropped off.
Unfortunately both antennas dropped out at around 1.2km, but that exact spot was under an intersection of two power lines.
I'm excited to see what this helical can do with my plane in the air. Can you see any areas of improvement on this helical?
Have your wife point your helical in the direction of your plane as you are flying in FPV, and you will be amazed with how crisp the video is. It beats the most well-tuned omni CP antenna.
terencechan is offline Find More Posts by terencechan
Old May 30, 2012, 10:32 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Ok I have been pushing my limits, and got 3km out of my bluebeam set today, now I am thinking it is time for a helical! I was looking at RMRC's selection, and I noticed there is a 3 turn (which stated a 75 degree beam I believe), and a 5 turn which did not state the beam width, so my question is what is a 5 turn helicals beam width?
Also what ranges could one expect on 1280 with 700mw vTX using SPW/Cloverleaf (would there be an improvement putting the SPW on the plane over the cloverleaf?) using both a 3 turn and 5 turn helical?
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 31, 2012, 12:19 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Not sure on range but a 5 turn has a beamwidth of about 45*
nogas is offline Find More Posts by nogas
Old May 31, 2012, 12:57 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
About to try my hand at making a helix and i wanted to clarify a few details. I used jcoppens calculator to determine most of the measurements but am unsure on a few (marked with ????)
Most of the details that i have listed seem consistent with others making 5.8Ghz (hard to find details on 5.8 specs)
Design frequency 5800MHz
5 turns
Internal diameter 17.5mm
Wire diameter 1mm
Coil centres 12.9mm
Reflector 32mm diameter minimum (Will make mine 35mm)
Wave Trap size 6.5mmx3.2mm
Wave Trap spacing from feed point 3.2mm ???
Seperation at feed point .4mm ???
I have also seen mention of maintaining the feed point seperation gap for the first quarter turn but this wasn't mentioned in any of Alex's initial posts so just wanting to clarify if it is necessary.
Old May 31, 2012, 02:29 AM
nrg2go is online now
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
5 turns
Wire diameter 1mm
Coil centres 12.9mm
I'm looking at building a 5.8 too but my measurements (derived from the first few posts) are:
The support brace
Cross width = 15.8mm
Coil spacing = 12.7mm
Length will just be a multiple of the spacing, so x5
I was led to believe that bigger is better for the helical wire so I will use 1/8" tubing
Reflector = 51.4mm (11732/5800 x 25.4)
Wave trap worked out the same as yours. 6.4x3.2
I'm assuming the Cross Width difference is because of PVC use but Reflector measurements should be the same?
nrg2go is online now Find More Posts by nrg2go
Old May 31, 2012, 03:27 AM
BKMorpheus is offline
Find More Posts by BKMorpheus
BKMorpheus's Avatar
NRW, Germany
Joined Dec 2010
The support brace
Although i got no clue about building those antennas, i often heard that a thicker wire will not be "better" but more broadband. So you might cover 5600-5900 MHz with that thick wire antenna, but the efficiency will be worse than a fine tuned thin wire antenna which is optimized for ~5800MHz.
More broadband = receive more reflections.
So maybe a thick wire is not really a great idea. Can IBCrazy or Markus confirm that, or am i getting this wrong?
BKMorpheus is offline Find More Posts by BKMorpheus
Old May 31, 2012, 03:44 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
The problem boils down to wether someone does have propper measuring equiepement and know how to fine tune an antenna or not.
If not, the thick wire aproach, alas going wideband is probably right as you then at least somehow cover the frequency you operate on. If you then want to improve things, one should either get equipement and build up the know how to make it right or - much much simpler and cheaper - buy an antenna made by a professional.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old May 31, 2012, 03:52 AM
nrg2go's Avatar
Joined Apr 2009
I got no clue either but post #3 clearly says bigger is better. It even goes so far as to say copper tubing is supreme. Go figure.
Old May 31, 2012, 04:20 AM
nogas is offline
nogas's Avatar
Joined Feb 2011
You may find post 3 is talking about building for 1280mhz. Different kettle of fish.
Hey Markus, can you confirm if my measurements are correct?
Old May 31, 2012, 12:33 PM
slowjett is offline
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
Wave trap question. Does the wave trap have to be placed horizontally, or can it be placed vertically?
The reason I ask is that I am making a helical that breaks down into to parts (ground panel separates from tube) for easy transport in a case. The wave trap is in the way positioned horizontally as it sticks out to the side and is susceptible to damage.
slowjett is offline Find More Posts by slowjett
Old May 31, 2012, 03:52 PM
Registered FPVer :)
Joined Aug 2006
Choose the hecker transformer aproach then. That should do for your application.
Markus
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
