Old May 15, 2012, 02:58 AM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
That's a great link, thanks Markus. I've searched the thread and I can't find an answer. I'd appreciate it if someone could advise what the "separation of the adapter section" should be.
Sub
subsonic is online now Find More Posts by subsonic
Old May 15, 2012, 03:04 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Sub
Hmm, I don't know either what that should be. Just build your helical acroding to the calculator and you will suceed. Place the coax feed below the spot wher the helix starts. Make sure the helix starts "a" above the reflector, and as such the center conductor of the coax obviousely must extend up to that point. Usually that's not that much unless you want to build a helical for the lower frequency bands. Add the wave trap as mentioned in Alex first posts as this is truly the easiest way to make one, and in general follow the instructions giving in this tutorial.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old May 15, 2012, 10:21 PM
slowjett is online now
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
what is my loss on 1240 with antennas tunes to 1280?
slowjett is online now Find More Posts by slowjett
Old May 16, 2012, 03:33 AM
Registered FPVer :)
Joined Aug 2006
There is no way to tell as it depends on how "sharp" the antennas resonance is. It will be in the area of 10 to 20dB though.
Markus
Old May 16, 2012, 09:55 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
My testing has shown 85% efficency for your scenario. Not bad. That's less than 1 db
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 16, 2012, 07:36 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
I am building a 5.8ghz helical and I am trying to figure the right length pigtail out the back of the reflector that will work with my tiny pan and tilt unit and not bind or tangle.
I know I will loose dB with more coax, but how much loss per inch?
-Todd
wannabe is offline Find More Posts by wannabe
Old May 16, 2012, 07:55 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
-Todd
Rg316 is about .7-1db loss per foot.
gundamnitpete is offline Find More Posts by gundamnitpete
Old May 16, 2012, 08:11 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
Thanks. I should have mentioned I am using RG58.
I just found this about RG58 in case anyone else wants to know: Loss = 0.14dB at 100MHz, 0.27dB at 900Mhz, 0.50dB at 2.4GHz (400mm length).
My crappy math skills tell me this means that for 5.8ghz, it is 1.5dB loss over 400mm. I think....
Old May 16, 2012, 08:19 PM
-NEFPV-
Joined Jun 2008
made a helical today. I didnt have ANY multi pathing at all. I did have two dropouts though. Just for a second when the tricopter duct behind the house.
I had all sorts of trouble soldering the sma connector. It kep shorting on me. I did TWO of them and they both shorted. Managed to get one to work without shorting. Any tips for attaching those? I do not have a crimp tool.
Old May 16, 2012, 10:47 PM
Team White Llama!
1 foot on rg58 is .4 DB loss at 5.8ghz.
Old May 16, 2012, 11:52 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
A fairly sloppy first attempt. Next time solder will be cleaner. Also I stoopidly wound a left hand coil at first. I did not have enough extra wire to make a proper right hand coil so I had to try and smooth out the wire to re-make it into a right hand coil. It's got a few slight bumps in it.....
I basically tried to follow Mictronics design for a 5.8GHz with slight variation.
Antenna dimensions:
Design frequency 5800MHz
7 turns
Wavelength ??
Internal diameter 17.5mm ish
Wire diameter 1.5mm 14THHN
Coil spacing 11.8mm
Reflector 40mmx40mm
Wave Trap size 6.5mmx3.2mm
Wave Trap spacing from feed point 2mm
Feed point height 2.5mm (wire center), maintained over 1/4 turn (sort of).
Initial testing in front of my house at about 60 feet indicates it is definitely uni-directional . How far do you think I can go with this using antenna tracking?
Old May 17, 2012, 03:14 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Is ot a big difference if you use a square reflector as opposed to a round one?
msev is offline Find More Posts by msev
Old May 17, 2012, 01:06 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not really.
-Alex
Old May 17, 2012, 01:07 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Antenna dimensions:
7 turns
Wavelength ??
Coil spacing 11.8mm
Reflector 40mmx40mm
Too bad you don't live near me or I'd tune it in for you. I'd like to see that with my own eyes. It really is a nice piece of work.
_Alex
Old May 17, 2012, 01:10 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
-Todd
This depends on the quality of coaxial cable you use. It is preferable to use a coaxial cable with a full braid and/or foil inside. These are lower loss and better quality cable.
Typically loss begins to increas significantly after 3GHz and thus for 5.8GHz I recommend keeping your runs less than 4 wavelengths. You are right on the edge of the measurement, but if I had to guess (and assume you are using a good cable) your loss is around .8db or so.
-Alex
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
