Old Apr 24, 2012, 06:16 PM
wannabe is offline
Find More Posts by wannabe
At peace with his albatross
wannabe's Avatar
United States, CA, Vacaville
Joined Oct 2003
Has anyone ever tried to encase there 5.8 helix in a sort of "radome" enclosure?
I am going to put mine in a plasic egg and wonder if that would have an effect on the antenna...
wannabe is offline Find More Posts by wannabe
Old Apr 24, 2012, 06:31 PM
Funky Diver is offline
Find More Posts by Funky Diver
Look Sideways at Polarisation
Funky Diver's Avatar
United Kingdom, England, Darlington
Joined Jun 2011
Chucked together an excel spreadsheet to take out the guess work.
Get it here
Funky Diver is offline Find More Posts by Funky Diver
Old Apr 24, 2012, 06:34 PM
Joined Jun 2011
I was looking at using plastic shot test tubes... for the active part
Old Apr 24, 2012, 06:37 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
Get it here
Awesome !! Thanks for that effort!!
However it needs to be de-bugged. I got a support legnth of 3500.0" or 88900mm. Seems a bit long for 5.8.......
Old Apr 24, 2012, 06:59 PM
Joined Jun 2011
Did you put in 5.8 by any chance?
Try changing it to MHz and you should be good
I will change it, but to put a prompt in for the right frequency range lol
edit : amends made
Old Apr 24, 2012, 07:00 PM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
HA, yeah that was it. I did 5800MHZ and got better results. Thanks!
Old Apr 25, 2012, 08:14 AM
Martinba77 is offline
Find More Posts by Martinba77
Always soldering
Joined Dec 2011
Hi guys!
I use a plastic toothpick container wich you can screw the cover to transport and then ones on the field you can unscrew that and use your helix without problems.
Off course my helix is only 3 Turns and very little weight for the connector to support.
Please note this original idea is from Lindsay (Pisces) and credits go to him for this simple and easy to get solution for our antennas.: Thanks Lindsay!
The reflector is directly "hot glued" to the bottom of the container.
Pictures attached...
Regards
Martin
Martinba77 is offline Find More Posts by Martinba77
Old Apr 25, 2012, 09:04 AM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
Yes but why bother removing the container bottom for use? Why not just leave the plastic cover on?
Old Apr 25, 2012, 09:54 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^The cover will attenuate the signal and detune the antenna. If it were 900MHz, it wouldn't be a problem. 5.8GHz is very sensitive to the environment.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 25, 2012, 10:00 AM
wannabe is offline
wannabe's Avatar
Joined Oct 2003
-Alex
Okay thanks. What about paint on the active element?
Old Apr 25, 2012, 01:58 PM
Joined Jun 2011
Apart from the fact that it'd be a dinosaur toothpick container then you'd have to worry about Pterodactyls getting your plane on landing approach
Old Apr 26, 2012, 04:42 AM
MADDIVER is offline
Find More Posts by MADDIVER
Joined Apr 2012
Funky Driver,
Thanks for the spreadsheet. You summed up this thing for us... Every thing is clearer now.
But... Can you please explain what you mean with wood and with plastic in the former section.
Do you mean a plastic tube that you also given a link for example?
And wood also...
I am asking these questions because dimensions are changing when I change the material type... I am a little bit confused...
Is this change is related to the former materials conductivity, etc?
MADDIVER is offline Find More Posts by MADDIVER
Old Apr 26, 2012, 05:17 AM
MADDIVER is offline
Joined Apr 2012
Answer of my silly question is in the first page...
"Why the different calculations? The PVC former is a dielectric and shifts the frequency down 5% or so"
Sorry all!
Old Apr 26, 2012, 06:31 AM
mudlark is online now
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
-Alex
Alex
What would happen if you put a 5.8 CL or SP inside a table tennis ball??
mudlark is online now Find More Posts by mudlark
Old Apr 26, 2012, 08:05 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It will do fine. I actually recommend this to protect the antenna.
-Alex
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
