Old Feb 27, 2012, 02:32 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Guys.
Can you make a helical TX antenna for ground link of say half a mile. from a barn to a farm house?
My fiance runs a farm in Washington and wants me to fit a "Lamb Cam" for the lambing season. Looking to be using a 900mhz TX RX set 800mw.
Will probably work with standard antennas but would prefer to beef it up.
mudlark is offline Find More Posts by mudlark
Old Feb 27, 2012, 04:45 PM
Carlos230023 is offline
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Sure thing mudders,I've ground tested my 5.8ghz gear for 1km (cloverleaf to helical) though a built up area, had a quality signal. I suspect helical to helical would be good for your needs, tbh 900 MHz @ 800 mw may well be massive overkill, I reckon you'd get about 3 miles at ground level no sweat (after that you'd have to lift them off the deck to account for the earths curvature or any topography that's in the way).
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old Feb 28, 2012, 07:14 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Cheers CJ
Just looking at over kill.
As I will only be there for two weeks I will not have time to order stuff in time. Will need to to bring every thing I need with me so just making sure.
I think I will just use the standard antennas and cross my fingers.
Old Feb 28, 2012, 08:04 AM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Originally Posted by TurboCinqy View Post
It's probably calculated with GPS.
It's the value above the Home Arrow.
http://youtu.be/NpX7pQNxb2Q
"You (home location) are the center of this circle"
Thanks for the reply. So if I understand correctly, your OSD is simply showing the planes' heading? And since you are, for example, flying out on a heading of 90 degrees, your return home would be on a heading of 270 (theoretically, anyway), correct?
Bob
Chairwolf is offline Find More Posts by Chairwolf
Old Feb 28, 2012, 08:33 AM
TurboCinqy is offline
Find More Posts by TurboCinqy
TurboCinqy's Avatar
Tiel, The Netherlands
Joined Apr 2007
No,
After we noticed we thought the same thing.
As i said your home location is the center of the circle around you.
So 90 degrees in front of you is always 90. untill you fly over your home location.
At that point it will turn into 270 degrees.
So your 90 degrees flightline wil maintain the same value if you will fly home.
In this vid We fly on the same path most of the time.
FPV Wing with 5.8Ghz Helical. (6 min 18 sec)
TurboCinqy is offline Find More Posts by TurboCinqy
Old Feb 28, 2012, 09:10 AM
Chairwolf's Avatar
Joined Jan 2007
No,
http://www.youtube.com/watch?v=ipRfbqwudgo
Ok, the light just came on! It's the plane's POSITION relative to you, regardless of it's direction. I understand. So 90 is 90 relative to me, no matter which way the plane is travelling. Got it.
Last question, and sorry for going off topic, but can you tell me the setting in the Remzibi software that puts this on-screen? Is it actually called "Flightline angle from home?" As I said, I'm new to the Remzibi.
Thanks so much for your patience! I appreciate it.
Bob
Old Feb 28, 2012, 11:17 AM
TurboCinqy's Avatar
Joined Apr 2007
AZIMUTH - Angle from Base Station
Old Feb 28, 2012, 02:05 PM
Chairwolf's Avatar
Joined Jan 2007
Perfect! I understand now, and can see what it's doing in your video. And I see it in the software too.
Thank you!
Bob
Old Mar 04, 2012, 04:17 AM
WhiteNite1971 is offline
Find More Posts by WhiteNite1971
Joined Sep 2011
RHCP Helical Antenna
Hey Guys
I've been busy over the weekend. I'd be interested in your thoughts. I have not used a match.
Cheers
WN
WhiteNite1971 is offline Find More Posts by WhiteNite1971
Old Mar 04, 2012, 07:31 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by WhiteNite1971 View Post
Hey Guys
Cheers
WN
There's not much we can say really. Unfortunately it's very very hard to predict the resonance of a helical built like this. What made me wonder is the ground plate which makes the impression like it's splitted into four quarters? Or is this just the colour of some stick you used to find the center?
At 5.8Ghz helicals are fairly difficult to tune, even when useing the wave trap aproach. Assuming you have no way to measure the resonance, all that you can try is to add a wave trap to the first quarter and try. You used pretty thick wire which makes it wideband, so chances are it will work a bit. Considder adding the wave trap, that's a little copper piece, 1/8 times 1/16 the wavelenght, so for 5.8Ghz, aproximately 3.2 x 6.5mm in size.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 04, 2012, 01:36 PM
Joined Sep 2011
Hi Markus
The reflector is made from a printed circuit board 50mm x 50mm. I marked it using a pencil to find the centre for the cross. The wire is 1/16th inch copper tubing which was the closest match I could get to 14 AWG. I will add the wave trap in the next couple of days. Thanks for the feedback.
Regards
WN
Old Mar 05, 2012, 06:39 AM
Registered FPVer :)
Joined Aug 2006
Hi Markus
Regards
WN
Considering that you can't measure, having thicker wire is better. A more wideband antenna means better if you don't hit the frequency you operate your tx and rx on. It also means less efficiency and your rx will get stuffed by other nearby hf sources, but this is all a compromise obviousely. The wavetrap at least will raise the possibility that your antenna is at least in the area of where you want it.
Markus
Old Mar 05, 2012, 01:21 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Hey Guys
Cheers
WN
Make sure your feedpoint is VERY close to the reflector. Then move the first 1/4 close to the reflector to make a conductor match. Generally speaking this works well for a helical antenna at 5.8GHz even without measuring equipment.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 05, 2012, 03:19 PM
Gustavovon is offline
Find More Posts by Gustavovon
Brasil, RJ, Rio de Janeiro
Joined Aug 2011
Hi guys, i bought from alex some time ago the helical 7,5 dbi and the closerleaf for my 1,2Ghz system. The image quality over the land was perfect, my friends became shock !! But when try to fly over the water, i have some lines on horizontal, even on short range ( 500 meters) that i dont have with my patch. This some problem with circular polarization and water?
Ps: i rx/tx are lawmate
Gustavovon is offline Find More Posts by Gustavovon
Old Mar 06, 2012, 02:06 AM
aspranger is offline
Find More Posts by aspranger
Joined Mar 2012
Newbie question regarding 5.8 GHz and wavelength
Hi there,
I am currently using the CL SPW combo of IBCrazy and I am loving it. Thank you so much Alex for everything you've done to FPV in the past years. You rock man!!
Now I am about to build a Helical Antenna as a match on my diversity receiver.
I am using the 5.8 GHz band and made myself an excel sheet to do the calculations, when I stumbled over the wave length everyone is using when building a 5.8 GHz antenna. Everyone is using 0.21 which seems correct for 2.4 GHz but (might be a silly question) isn't
Lamda = 300 / f in MHz
That would leave me with a wave length of 0.05 for a 5800 MHz wave.
That again would lead to a coil spacing of 2.5 mm... using a 1 mm wire this would lead to a 0.5 mm gab betwean the wires.
Also this seams to raise the gain of the antenna and thus narrow the beam, but according to http://jcoppens.com/ant/helix/calc.en.php
e.g. a 6 turn helical would be
95 degree beam at 0.05 wavelength
instead of 55 degree at 0.21 wavelenght
could someone lead me into the right direction?
Am I totally wrong here or am I overthinking this due to the tolerance of the 5800 MHz helical?
Thank you in advance
A.
aspranger is offline Find More Posts by aspranger
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
