Old Jan 26, 2011, 08:57 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Ok here it is. A 1280mhz 3 turn (7dbi) RH CP antenna. I used the matching strip since I had the stuff lying around from the reflector. I also sanded the back of the reflector and epoxied a threaded piece of aluminum for a tripod mount. Epoxy holds surprisingly well on metal from my experience on my patch antenna.
This took probably only 1-1.5 hours to make.
Tadah.
BTW, Alex, I got different measurements than you on my 1280. I found that spacing should be 2.128" from your equation (2725/f), so from the starting point, wouldnt the 1st pass of the coil be at 1/2 that measurement (1.064) and the second one at the 1/4 wave (2.128)? Why do we vary?
Derek_S is offline Find More Posts by Derek_S
Old Jan 27, 2011, 12:41 AM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Offtopic:
You should change the sign on your plane from "Experimental UAV" to "Model Airplane". Some people freak out when they see U.. A.. V..
twinturbostang is offline Find More Posts by twinturbostang
Old Jan 27, 2011, 06:27 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
You are probably right on. I will do that.
Or maybe go the other way and put:
Armed drone! Do not touch! call this number immediatly! Do not Ebay! Ebay results in explosion!
Old Jan 27, 2011, 08:23 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
Or maybe add: smile you are on TV.
Ckeers.
Lars.
LKJ is offline Find More Posts by LKJ
Old Jan 27, 2011, 08:51 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Ok guys, did very limited testing this morining. It was too cold for me to do more, and I have a suspicion my Fox700 hates the cold as it goes black intermittently (edited out in this video).
Note I moved the gear to my Stryker. I decided if there was any way to best test CP in non-FPV, aerobatics might be a good way. I did non-fpv LOS/close range and tried to fly in the back/lobes of the helical at some points. I probably did not exceed 1000ft/300m LOS. I didnt notice any difficulty to fly with the S-P Tx ant on the middle of the Stryker just rear of CG.
Gear:
BOB/FOX 700 w stock RX (CH9/1280mhz)
Skew-Planar Vtx and 7.5 dbi Helical Rx antenna (3 turns w matching strip)
GP CX-161 Camera
eBay 12v stepup w/ 470uf caps on Vi/Vo
Futaba 9cap Tx and RP8D1 Rx
RCTimer 2200kv 2212-06 w/ 30A Hobbywing ESC
HS-82MG Servos (x2)
Hopefully this weekend weather will be nicer and I can push out some. I also did not do a head-to-head of CP vs linear due to the cold but I would like to compare to a V+Patch.
TEST 110127 Stryker 1280 CP Edited (2 min 41 sec)
Old Jan 27, 2011, 09:06 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
So, my impression so far is that the SP/Helical combo is AT LEAST as good as my V/Patch. Certainly not worse as far as short range performance. Unfortunatly I do not have any videos of a linear polarized system that it would be fair to compare to.
Old Jan 27, 2011, 11:11 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Derek, you need to compress your coil! That stub should be parallel to the reflector, not tapered. On a rough guess you VSWR is around 3:1. Get that stub closer and parallel and watch what happens.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 27, 2011, 11:16 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I just watched the video. Welcome to the CP club, Derek. You'll never go back to linear
-Alex
Old Jan 27, 2011, 11:59 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
-Alex
Ok, I confused tapered with what I would call sloped. I thought taper meant triangular, or decreasing in width as it goes along the length.
So if it needs to be parallel to the reflector, does only the beginning of the coils make contact with the matching strip? Or do I need to flatten out the 1st 2" or so of the helic(copper) coil?
Or maybe more simply, is the 1st pic I posted above as examples the most accurate? The 2nd one appears to be soldered along the strip, thus following its slope upwards.
Old Jan 27, 2011, 01:19 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Ok, I confused tapered with what I would call sloped. I thought taper meant triangular, or decreasing in width as it goes along the length. - Sloped, tapered, same difference. It needs to be parallel and flat, not sloped.
So if it needs to be parallel to the reflector, does only the beginning of the coils make contact with the matching strip? - Ideally, yes. Or do I need to flatten out the 1st 2" or so of the helic(copper) coil? - You could do that also. Either works.
I will post more pictures soon. Your strip is certainly helping, but it could do better if it were flat along the reflector instead of being sloped.
-Alex
Old Jan 27, 2011, 01:23 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
I think the short copper tubing lenght is the easier way to make the "balun" (right word?)
vulpina is offline Find More Posts by vulpina
Old Jan 27, 2011, 01:26 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Ok easy fix! Sorry for the confuson... I think as an architecture person I have a different set of semantics in my head so I get confused in engineering situations..
Old Jan 27, 2011, 05:59 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It's not really a balun. The system is still unbalanced. It's just an impedance matching stub.
Old Jan 27, 2011, 06:02 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
I think it is fixed:
BTW I just rewatched my video more closely. It is really a great improvement!
Old Jan 31, 2011, 04:12 AM
dadde is offline
Find More Posts by dadde
The one and only
dadde's Avatar
Hjo, Sweden
Joined Apr 2004
Wow Alex, you have great timing I've just started making a Helical antenna when you posted this guide. You've probably save me a couple of hours reading nonsense on other pages.
I'm a big fan of your work and I would like to thank you for putting in the effort and writing these guides.
I'm moving over to CP on my multi-rotor platforms to reduce multi-path interference.
I have a quick question however; I have at my disposal both 12 AWG coated copper wire and 3/16" copper tubing. Which of these two would be the better choice for making a 1280MHz Helical?
dadde is offline Find More Posts by dadde
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
