Old May 27, 2011, 03:54 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I use a 12t helical (2.4ghz) and an open biquad on the RMRC tracker work amazing.
I put an elastic band on the tilt to counter the weight of the helical.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old May 29, 2011, 09:15 AM
imagebuff is offline
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
Well I took the advice of cutting away the dead weight and cut away most of the PVC on the helical as well as removing the wooden base. Really lightened it up without sacrificing structural strength. May even be light enough for the tracker now. I think it looks kind of cool too .
imagebuff is offline Find More Posts by imagebuff
Old May 29, 2011, 09:10 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by imagebuff View Post
Why shouldn't I use a 5 turn helical on a tracker? Are you saying this based on the weight?
I already have the EagleEyes diversity and was planning on using the helical on the tracker, and another cloverleaf (need to order) on stationary RX #2. Cloverleaf on the TX/plane.
Chris
Yes. The weight is the limiting factor. Helicals are large antennas. They are great for diversity, but not good for trackers.
In the near future I will be making 5.8GHz helicals that are high gain and tracker friendly
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 29, 2011, 10:49 PM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Alex, any idea what range to expect with a helical and clover leaf setup. . . .as compared to vertically polarized yagi and Vee on 1.28ghz?
sawman is offline Find More Posts by sawman
Old May 30, 2011, 07:03 PM
LexusFPV is online now
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
sawman
If you are using the same Freq. (1.2ghz) and flying in the same location.
(CP) VidTx- CloverLeaf and VidRx- Helical versus
(LP) VidTx- Vee and VidRx- Yagi....
the 2nd setup will go a lot further, but keep in mind that the beam is a lot narrower,
you have to fly almost in a straight line, but you will go a lot, I mean a lot further!
LexusFPV is online now Find More Posts by LexusFPV
Old May 30, 2011, 07:18 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
I would have to say it really depends on the gain of the helical and the gain of the yagi. Between an 8dBi yagi vs a 13 dBi helical the helical should "win" rangewise on the same frequency for example.
Mikey-flies is offline Find More Posts by Mikey-flies
Old May 30, 2011, 11:54 PM
sawman is offline
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Thanks guys. I feel a hi-gain yagi is easier to make, as Alex said the efficiency of the helical starts to diminish after 5 turns or so.
Beam width shouldn't be much of a problem seeing how it's a long-range set up anyway. Even if it were only a 11 degree beam (assuming 3db lobes), that's 1.2 miles at 6 miles out, 1/2 mile wide at 3 miles, and anything closer can get by with a bi-quad or omni.
Old May 31, 2011, 02:02 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
You may misundrestood this a bit. It's just that you need to make overproportionally more turns to get more gain the longer it gets. But high gain helicals are a reality and used in i.e. satelite comunication.
You can go for a yagi, but it will not be circular polarized. You can build what's called a cross yagi though but you have to be very carefull with the feed of the 90 degree crossed elements to end up with a truly cirular polarized one. I'm lacking experience but thougth to try this out one day but my gut feeling tells me that a helical is better due to the better adaption of the reciveing elements to the circular nature of the waves. I'm eventually really wrong here.
Markus
markus123456 is offline Find More Posts by markus123456
Old May 31, 2011, 02:17 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by LexusFPV View Post
sawman
This statement is plain and simply not true. You can make a high gain helical, and the gain of a vee is not really (significantly) higher than the gain of a cloverleaf (not even one dB). There are reasons why helical antennas are so widespread used in satelite comunications.
You may loose a little by going cicular polarized in a pure dB kind of comparison, but in reality you gain, cause the link is of better quality. The way the tx and rx antennas are lined up against each other does not matter by the nature of cirular polarisation.
One should compare apples to apples meaning if you look at what i.e. Trappy used on his record flights, I'm absolutely positive he would have been able to do the very same if he were to use circular polarized antennas with the same (or even slightly less) gain than the setup he was using.
These days it becomes aparent that the video link and rc link alone are no longer the limitting factor when it comes to range. Flight batteries (and patience of the pilote) are where the limits are.
The biggest advantage of CP antennas over LP antennas is that you never have trouble with banking etc. You also have much better chances to fly behind trees and still have a good signal than by doing so using LP antennas. Apropriate tests were made already many years ago as CP waves etc is not something that was invented for FPV but exists for long. Penetrating a forest using CP antennas usually means loosing 3dB. Doing the same with LP (upright) antennas means loosing 42dB. Doing the same with LP (horizontaly alligned) means loosing 12dB. You can look this up in the "Rothammel" antenna book if you like.
Markus
Old May 31, 2011, 03:36 AM
aSa2 is offline
Find More Posts by aSa2
Joined May 2010
Alex,
what cable would you suggest to use?
RG174/RG58/RG316??
Which is the best for CL/SPW/Helical
aSa2 is offline Find More Posts by aSa2
Old May 31, 2011, 06:53 AM
Joined Feb 2011
Markus,
thats for the explaination....
I'm trying to go out far this time around in a couple weeks.
I have 2.8m powered Glider, and I'm using 1.2ghz LawMate VidTx and VidRx.
My VidTx has a "V" and my VidRx (diversity-2x BiQuad).....
all Linear Polarization..... we will see how far I can glide out....
I want to keep it simple and I just want to go out in a straight Line,
(boring :-) )
but we will see and I will let you know.... Im not going through trees' or hills,
so I don't need Circular Polarization....I'm very high up in the air and I'm going
in a straight line out ..... no banking, just turning around to come back.
I hope to get 15-25 miles out ! :-)
I will let you know in a couple weeks when I do it for fun :-)
Old May 31, 2011, 07:43 AM
Registered FPVer :)
Joined Aug 2006
Markus,
(boring :-) )
There is nothing wrong with linear polarisation. Especially not on the somewhat lower frequencies bands like the one you use. CP is just safer, more stable. It does not mean that you could not fly this way. Last not least we all flew this way up until not so long ago.
I wish you good luck for your long range attempt!
Markus
Old May 31, 2011, 10:43 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by aSa2 View Post
Alex,
RG174/RG58/RG316??
I use rg316 for cloverleafs and Skew-wheels. I use RG58/U for helicals.
-Alex
Old May 31, 2011, 11:07 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Alex,
Where do you get the stiff thin wire you use for all of your antennas? i would like to get some on Ebay since i wasnt able to find it locally.
i3dm is offline Find More Posts by i3dm
Old May 31, 2011, 12:46 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I use Mig welding wire from thae hardware store. It's cheap and it works.
-Alex
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
