-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
I've finally did some test.
I'm running on a 1200Mhz using the Fox700 tx My previous setup was a stock rubber antenna for my Rx and a V-antenna for my Tx. The video got blurred during sharp banks and turned into black and white sometimes fading with flashes in an random pattern when i exceed flying beyond 1200ft LOS. Now with the new helical antenna + Clover combo, i got clear images all the way, even beyond 1200ft. There are still flashes but it happens in one short burst (100ms) for every min which is many more times better than my previous combo. Thanks IBCrazy for your wonderful tutorials and guides to making superb antennas. |
It will work fine. No problems.
Joined Oct 2009
Coil spacing
Thanks for these tutorials, I built two antennas SPW and CL, with surprising results!
Now I like to build the helical for my 5.8 ghz kit I read the tutorial but I found a discrepancy in the coil spacing measure in detail: Cross insulated Helix for 5800Mhz: Cross width in inches: 3600/f in MHz (+/- 10% tolerance) 15.7mm Coil spacing in inches = 2900/f in MHz 12.7mm Cross length = number of turns * coils spacing 3x1.27=38.1mm Reflector plate size = 11732/f in MHz 51.4mm later in the tutorial I read this: For my wooden former, I marked the following on one side: 0, 2.1875, 4.375, 6.5625, 8.75, 10.9375” 1280x2.1875= 2800 !!! Coil spacing in inches = 2900/f in MHz or 2800/f in MHz ? maybe I'm doing something wrong... |
I brought a 16 mm wooden dowel 13mm spacing and my reflector was something like 5.something square. It is not hard to make at all. The hardest part is making the hecker transformer. I believe mine is off somehow but I have nothing to test it on. |
-Alex |
My first atempt at making a 2.4G Helical.
Freq = 2510Mhz Number of turns = 6 (10.5 dbi) PVC pipe former outer diameter = 42mm Coil spacing = 28mm Reflector plate size =118mm The IBCrazy microstrip Width = 5.7 The IBCrazy microstrip height = 4.6 Wire, 1.25mm enameled copper. Reflector, Blank Printed circuit board. Wasn't too hard to make and hopefully I haven't messed up any of the calculations. It's quite light so won't be a problem for the tracker. I'll be testing it on Sunday. |
Bill, ReadymadeRC has CP patches that will fit an antenna tracker: http://www.readymaderc.com/store/ind...roducts_id=489
Axial ratio isn't nearly as good as your helical (.75 vs.95), but it does just fine for me. And before anyone asks, no it is not the same as the goof-proof patch. -Alex |
| Thread Tools | |
| Discussion Circular-polarized Patch Antenna for 5,8 GHz | Lonestar78 | Video Piloting (FPV/RPV) | 22 | Oct 15, 2011 04:46 PM |
| Discussion Left/Right circular polarized antenna ? | SpookiePower | Video Piloting (FPV/RPV) | 44 | Jun 04, 2011 06:41 PM |
| For Sale 2.4 gh 8 dbi patch antenna $10 | norberto83 | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Dec 03, 2010 07:44 PM |
| Question 30 dBi Grid Antenna | matyou | Video Piloting (FPV/RPV) | 7 | Nov 14, 2010 10:32 PM |
| Discussion Anyone tried building a helical antenna for FPV? | Bill Sanford | Video Piloting (FPV/RPV) | 20 | Nov 04, 2010 06:48 PM |
