Old May 09, 2011, 07:53 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
A 6 turn helical has a pretty narrow beam. It also has a very strange shap to it. However it shouldn't be any narrower than the BiQuad's.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 09, 2011, 07:54 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by LexusFPV View Post
whakahere
hello Whakahere, I've ask a few questions on your other thread.
is it really possible to achieve 8-10km using Foxtech 5.8ghz 200mW VidTx using IBcrazy Clover Leaf antenna,
and now using a 5-6 turn Helical on a 5.8ghz VidRx?
Yes. Not easily, though. I can be done. 4 turns is enough. Use the hecker transformer to match it.
-Alex
Old May 09, 2011, 02:05 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I haven't run any tests as of yet as I want to set up diversity with it just in case. I will be shocked if I reach 8km on it but since I have made 3km just on a spw and a cl I think anything is possible The only way to find out is to try it. I want diversity first as I want to at least have some back up just in case. how narrow is it?
So 6 turns are too many ...umm well I will give it a go and if I find it is too much I will just limit the turns on my next build.
whakahere is offline Find More Posts by whakahere
Old May 09, 2011, 02:14 PM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Nice build Hugo. What wire gauge did you use? 10 and 12AWG work best in my experiments for 2.4GHz.
Also, how are you planning on tununig that beast?
-Alex
I taken my helical to the telecom lab today, the spectrum analyzer gave 1.3:1
The tech there soldered a small piece of metal to my matching strip and by bending it a bit he reached 1.05:1
Hugeone is offline Find More Posts by Hugeone
Old May 09, 2011, 05:13 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Has nobody yet used the gamma matching of a Helical?
(scroll down about half way to the part about the W0OQC mathing method)
http://www.safe-pc.net/helical.html
http://www.safe-pc.net/images/helix2.gif
http://webpages.charter.net/wk4r/2400/ant1a.jpg
Super easy to make and matches well
Go on, you know you want to !
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old May 09, 2011, 08:36 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
I have the Foxtech 5.8ghz 200mW VidTx with Clover Leaf,
and I'm using the Foxtech AOI goggles with built in VidRx, I have the
Skewer Planar Wheel on the AOI goggles.....
(no heavy groundstation to lug around).
I will try and use the Diversity with the 4 turn Helical for longer distances (~8km and up).
I'm hoping to test it out on my SkyWalker, I'm just waiting for my 4s 5000mah
to come from HobbyKing..... I'm all ready to go, minus 4s Flight Lipos'.
I hope IBCrazy and Markus are right, ......
I'm hoping to get 3km (2 miles) and I'm happy
LexusFPV is offline Find More Posts by LexusFPV
Old May 10, 2011, 07:38 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nigel.
I tried a gamma match. I didn't like it. It was simply too difficult to get right and was very fickle. I use the tapered microstrip match. It's simple and it works. It's the most tolerant of error as well.
-Alex
Old May 10, 2011, 12:10 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Now I HAVE to build one for my setup...
karl k is offline Find More Posts by karl k
Old May 14, 2011, 11:14 PM
viper1990 is offline
Find More Posts by viper1990
Scratch-builder
viper1990's Avatar
Singapore
Joined Oct 2007
I've been cracking my head really hard how do i make a rounded reflector for the helical antenna snice i do not have any machines around to cut a nice circle shape.
So i went down to a bakery store and found some 7-1/4 diameter aluminium pie dishes... its going to give me a hard time to snip off the rounded edges of the pie dish because its made of a pretty thick aluminium sheet.
Do anyone have an answer whether the singal be affected in anyways if i leave the rounded edge of the aluminium pie dish on?
viper1990 is offline Find More Posts by viper1990
Old May 14, 2011, 11:43 PM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Should work. Mount it to the bottom (the side your measuring tape is on). It's a reflector, so anything behind that surface will not have an appreciable effect. You just don't want anything sticking out towards the driven element (helix).
sawman is offline Find More Posts by sawman
Old May 15, 2011, 12:20 AM
Scratch-builder
viper1990's Avatar
Singapore
Joined Oct 2007
Thankyou sawman for that super quick reply.
I'm building the helical antenna right now as we speak and i'll post my results as soon as i test it!
Old May 15, 2011, 11:19 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Placing it inside the dish will actually help control side lobe radiation. It might be a benefit if you don't usually fly far out to the sides.
-Alex
Old May 15, 2011, 02:08 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
I was wondering what happens if you use a reflector which is way too big?
I am using a 6 turn 1010mhz helical with my computer case door as the reflector. It has worked really well and I was about to get a piece of galv sheet cut the correct size but did not want to lose any performance. Would the correct size work better for long distance or the oversize one?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old May 15, 2011, 02:13 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Mark
god damn you are such a kiwi!! ... um but one mistake I see is no number 8 wire. I thought you were a cow cocky?
From what I have read the circle shape helps prevent the signal from bleeding out the sides as much. (but I could be way off base here).
Old May 15, 2011, 04:03 PM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
I am actually a refrigeration engineer We moved out of the city onto 4 acres to have a bit of space. We have a total of 3 cows although the freezer is starting to get a bit low so that may be down to 2 soon
Yeah I thought I might cut a round one but I am not sure if I make it smaller like it's meant to be if I will lose some range, I suppose I should experiment a bit aye.
Mark
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 57 Sep 21, 2016 10:28 AM
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
