Of course anything is possible, but by the time you add all the electronics required to do what you want to do, the price of the charger would be too high for this industry, in my opinion. In the long run, you'd be better off adandoning parallel charging altogether and utilize multiple chargers or have multiple individual outputs in one charger. Our original concept for a parallel adapter was quite different from what we ended up manufacturing ultimately. If you go back in time in the PL8 beta thread, you can read about the Smart Parallel Adapter. This was getting closer to the concept you describe. But we abanadoned it. By the time we had something ready to build, we realized it was vastly over-complicated, far too expensive, and would have made for a less reliable overall system, not more reliable. But then, all the original Smart Parallel Adapter was intended to do was check the individual cells before they are connected in parallel. But here's another issue. Once the packs are paralleled you can not "see" the individual cells. You can't have it both ways. You can't parallel two circuits; while at the same time also see the two circuits individually. Only way is to have 2 separate circuits (2 chargers), or disconnect the cells at intervals to take measurements. To do this you'd need a lot of pretty high powered FETs which then introduces more points of failure, etc, etc. Tim Marks |
Joined Jan 2011
An interesting statement, adding this technology would cost too much, then in the next sentence “buy more chargers”. I have 6 good chargers; isl8, isl6, 2 - TP601's, iMAX Quattro, PL8 and then a bunch of really junk ones. How many should I purchase? Where should I set them all up at?
WRT cost, I paid over $800 for the isl8 alone (if I remember correctly). For a charger that would perform the simple tasks I was searching for, the benefit would be worth the cost. As an aside, I paid around $800 for the current PL8 setup I have today—and am damn glad I did. I will suffer with the negatives until someone thinks out of the box and creates a system which IMHO is a small incremental step past yours. Please do not take any part of this thread from me as a negative comment on your charger. I absolutely love your charger!! I was originally searching for an answer to what is on the display. I only then took the thread to what I was actually searching for, visibility into each cell of each pack. I appreciate all of the information I have been provided and understand the PL8 much more than I did when I purchased it 12/31/10. I stand by for FMA’s next great innovation. |
Joined Jan 2011
Broken Wire
| Thread Tools | |
| Discussion ICharger 208B and 6S JST-XH Balance Cable for Parallel Charging | norstaroption | Batteries and Chargers | 8 | Oct 23, 2011 05:47 PM |
| Sold Hobby King Parallel charging Board for 6 packs 2~6S | Mikemynameis | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Jan 06, 2011 03:56 PM |
| Discussion Max number of 6S charging in parallel | richmills | Batteries and Chargers | 3 | Jan 03, 2011 08:08 PM |
| Discussion New HK 6S parallel charging board | bymannan | Batteries and Chargers | 6 | Nov 23, 2010 07:27 AM |
| Sold parallel charge and balance cables for charging up to 6 lipos at once | ff954 | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Sep 27, 2010 11:09 AM |
