Old Jun 21, 2012, 02:32 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Originally Posted by johnbone View Post
I thought they were 3600kv. The HET 2W20 is 3350kv and 750 watts and they outdo those with max amps.
I did a search recently and came up with http://www.aero-model.com/Hacker-Bru...ner-Motor.aspx which must be close excluding the edf extension. 750watts but peak amperage is 70 which might explain the extra headroom. I don't think this motor is exactly the one though as it is fairly heavy with the extension.
yes, and that was the motor that was suggested to me to get abit more performance out of the plane from Hacker. However, you'll note it has a 3.17mm shaft, just like the Turnigy motor I'm trying to fit to the Sebart fans. For the life of me, I can't find such a EDF adapter.
TheCure is offline Find More Posts by TheCure
Old Jun 23, 2012, 02:27 AM
johnbone is offline
Find More Posts by johnbone
Australia, WA, Perth
Joined Jun 2009
How about Maxx Prop Adaptor 3.2mm (1/8") shaft, 6mm prop hub from http://www.radicalrc.com/category/Pr...Collet--Etc-36 I am not sure of the length dimension. Maybe someone could machine something but it would be costly.
johnbone is offline Find More Posts by johnbone
Old Jun 30, 2012, 11:57 PM
J-ACE is offline
Find More Posts by J-ACE
J-ACE's Avatar
Adelaide Australia
Joined Apr 2010
Sub'd
J-ACE is offline Find More Posts by J-ACE
Old Jul 10, 2012, 02:27 PM
billd3 is offline
Find More Posts by billd3
billd3's Avatar
United States, VA, Prince George
Joined Nov 2009
Originally Posted by schiwo1 View Post
As promised, the log files and a summary on my experience after 6 flights today.
2. Flight behaviour:
- very easy to fly with 50% gyro support in "normal" gyro mode and the Sebart recommended throws........
- - Gyro mix in normal mode at 50% in start mode and 100% in 3D mode (makes the start really easy)
- Elev, ailerons exaclty straigt
Happy flights!
Stephan
Trying to set up my Mig but I don't fully understand gyros. Can you explain? What do you do to get 50% gyro support? How do you get the ail. straight? If they are straight at the root they are deflected UP at the tip??
Thanks.
billd3 is offline Find More Posts by billd3
Old Jul 10, 2012, 03:41 PM
billd3 is offline
billd3's Avatar
Joined Nov 2009
hardware changes
I also found, like some of you , that the hardware leaves a lot to be desired and I'm going to change mine too. I'm curious about what some of you have used to replace the factory stuff, particularly the clevises...I've never used anything this small and have never seen clevises that seem to use "wood screw"type threads on the pushrods. Are you keeping the stock pushrods or is everything changed to 2-56 stuff. All my stuff is giant scale and I don't want to overkill
Thanks in advance.
Old Jul 20, 2012, 10:19 PM
rogerio is offline
Find More Posts by rogerio
Joined May 2004
Any store in United States with the newer version with 2x65 esc in stock?
rogerio is offline Find More Posts by rogerio
Old Jul 22, 2012, 11:38 AM
malcolmm is offline
Find More Posts by malcolmm
Joined Jan 2005
Thanks.
They are up at the tip of the wing.
Not sure about the gyro setup. Since I have a JR radio I just used the setup as specified in the manual.
malcolmm is offline Find More Posts by malcolmm
Old Jul 22, 2012, 11:49 AM
malcolmm is offline
Joined Jan 2005
I finally finished my Mig-29 and had five flights this weekend.
I'm not sure what I was expecting, but I know I was expecting it to fly better than it does. I'm a fairly good 3D pilot with prop driven planes - I can do rolling harriers, torque rolls, knife edge spins etc. with my Slicks and other 3D prop driven planes.
Flying the Mig makes me very nervous. Whenever I make a mistake, it would go into a spin, and getting out of the spin takes some time. I almost crashed in two or three times because of this. Thinking about it afterwards, I guess I need to keep some power on at all times as the lack of airflow from a prop makes the control surface unresponsive at times. I really admire the flying skills of those pilots who can 3D this plane. For me, flying the Mig is not fun at all so far.
I would also agree with other comments that the quality of the hardware is really poor for such an expensive plane. I've built Hobby King foamies that have better quality hardware. I'm also not impressed to read that they have now upgraded the ESCs to 65A, this should have been done before they released the Mig.
Old Jul 22, 2012, 02:08 PM
schiwo1 is offline
Find More Posts by schiwo1
Joined Nov 2009
Hmm, have a look at voodoochild's vids he posted earlier in this thread to see what you can do with this plane.
I am not a 3D pilot, but I am capable to do hovering, tailspins, knife edges, flatspins etc easily with this plane in the meantime. I have it now for a year or so, w/o any problems, even with the original 45A ESCs
For me, the Seb Mig is the fun fly model to relax in between the flying "real" stuff.
Give it a bit more practice, and you will love this plane!
Best Stephan
schiwo1 is offline Find More Posts by schiwo1
Old Jul 22, 2012, 04:01 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
I see "Area 51" calls theirs "Version 2". They got into the game a bit late so I doubt they ever sold the V1. I don't think this jet is a big seller in N. America. I check the Graves Hobby site from time to time. They are currently at a stock of "1". About the beginning of this year, their stock was at "3". It's taken this long for them to get down to 1. You'll probably see V2 once the current stock is gone, assuming the hobby shops think this jet is worth stocking. Atlanta Hobby doesn't have stock and say it's on "back order", so contact them to see if it will be V2 when they fill an order. The US sellers either won't even ship one to Canada or they use only UPS. UPS makes the cost way too much. I'm looking into what it'll cost for Area 51 to ship one without paying "VAT".
xviper is online now Find More Posts by xviper
Old Jul 24, 2012, 02:01 AM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
That will come, carry on! The fun will come.
And tuning the CG and nozzles (see Schiwo's post, IIRC) to alleviate the pitch-up effect makes it even more fun.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Jul 25, 2012, 10:50 PM
TheCure is offline
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
so i finally got the correct collet adapter to try the turnigy 3300kv motor in the sebart mig.
i also bought 1 of the stock sebart motors for comparison too.
the figures i got seem almost identical between the two. the current on both was close to 70A peak.
the static thrust (in-plane) was 1.15 for the turnigy, and maybe closer to 1.2 for the stock motor.
the sebart motor had an odd smell after running for a few seconds- hope is nothing
Old Jul 30, 2012, 12:43 PM
hackdroot is offline
Find More Posts by hackdroot
hackdroot's Avatar
USA, CA, Oakley
Joined Aug 2008
Selling one of these NIB if anyones interested. Looking to fund another plane.
http://www.rcgroups.com/forums/showt...ghlight=sebart
hackdroot is offline Find More Posts by hackdroot
Old Aug 01, 2012, 03:56 PM
Mike873 is offline
Find More Posts by Mike873
Joined Feb 2012
Has anyone been able to track down spare parts for this plane? I called Hobby Lobby and they checked their website as well as the Sebart and Thunder Power sites. No luck. I would like to replace the bottom half of the foam EDF ducts since they have been beaten up in some landings over the last year. I learned a while back that you have to have some power on during the landing since it pitches up violently when you cut the throttle to zero.
Mike873 is offline Find More Posts by Mike873
Old Aug 03, 2012, 03:13 PM
schiwo1 is offline
Joined Nov 2009
Mike,
I don't think you will get those as replacement parts.
Fix it with Epoxy and you will be fine
Best Stephan
For Sale Phase 3 Squall Hp, thrust vector, plus new airframe redrsv Aircraft - Electric - Jets (FS/W) 10 Dec 28, 2010 09:07 AM
Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF Aero12 Aircraft - Electric - Airplanes (FS/W) 0 Dec 26, 2010 12:11 AM
New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? rjp0325 Electric Ducted Fan Jet Talk 17 Sep 24, 2010 07:12 PM
Sold New Mig-29 Vectored Thrust Complete Kit Harv Aircraft - Electric - Airplanes (FS/W) 5 Feb 29, 2008 09:24 AM
Video Mig-29 with 2-Dimension Thrust-Vector-Control system bryan.chen Electric Plane Talk 0 Jun 25, 2006 08:21 AM
