Can you post some pics of your conversion ??? You have my attention.
I have found that no matter what size fan I fly, if I am running anything less than a good 35+c pack; it will no doubt swell.
I prefer the 45/90c Turnigey nano's for the price and for their ability to quick charge at 22.2amps. |
Latest blog entry: Burned Retina Shorts
Unfortunately I don't have any good batteries that are light enough but I have some rough specs about the setup with a 20c 4000mah 6s. Peak watts is about 1700, max amperage is 80a, my cg is about 128mm from the leading edge of the wing, and the auw is 1963g. Here's some pics. of the conversion also. It's not pretty but it works ok. I basically just cut foam out and glued some balsa wood blocks in to keep it from moving around.
Pre-heating packs
I've heard you mention a couple of times now about pre-heating the packs. This is a new concept to me. Would you mind elaborating a little bit about this? I'm curious because besides flying this MIG, I am beginning to delve into higher current helicopter set-ups as well. Thank you sir! Best Regards, Dave |
Karlsruhe, Germany
Joined Nov 2009
Dave,
Lipos have their lowest internal resistance at temperatures around 40 deg C. The lower the resistance, the more Amps at the same Voltage level you can pull. The difference to a room temperature pack can be very significant when it comes to high loads (means >100A in case of the Mig) Example: 4000 4s Nanotech in theMig during taksoff ~115A at room temp, close to 135A (>2KW input power!) when heated to 40deg. Another side benefit: a cold battery, due to the higher internal resistance, usually heats up quickly under high Amp load. Due to the lack of airflow, the inner cells of a pack become warmer than the outer cells, eventually resulting in a shortened battery life. Pre heating helps to avoid this effect, and the pack will last longer. Caution: more is not better - if temp crosses the 50 deg Celsius mark you may destroy the battery. Also, this method will not make an old battery better. At lower currents, preheating will not make much of a difference. You find plenty of battery heating equipment at virtually every shop. Best Stephan |
Jack |
I went out of town for 5 days to be in a friends wedding (poor guy) So it has been a while since i flew the Mig (week and a half) When i got back we had nothing but 20mph winds....So after two days of no flying since coming home,i decided to try the Mig in HIGH WINDS ( most i have flown it in was around 12mph) we had 20mph winds with gusts up to 25 today....I was very suprised how well it did,do not get me wrong,it does float around alot,but easy to handle if you keep your head in the game......I took a crappy video,so here it is.... http://www.youtube.com/user/voodoo12667
Karlsruhe, Germany
Joined Nov 2009
http://www.rcgroups.com/forums/showthread.php?t=1459652 Preheating is not *necessary* but provides you with better performance and an extended battery life when it comes to high peak loads. Now back to the Mig
Motor City USA
Joined Mar 2007
As the months get cooler here in Mo Town....we place our packs into a Peltier Heated Cooler (you know the Thermoelectric travel hot / cold coolers that you plug in). I bought a $60 one from Amazon, added banana plugs and hook it up to my RC Charging Spare Car Battery. Inside the cooler I added a small squirrel fan that moves heat off the heatsink and stirs up the warm air inside. After about 20 minutes the packs are maybe 95 - 100 deg F (getting close to 40 deg C). Works like a charm since I do not keep my car running during the 4-6 hour long fall/winter flying sessions.
This is the one I bought. http://www.amazon.com/gp/product/B0001MQ7DG |
| Thread Tools | |
| For Sale Phase 3 Squall Hp, thrust vector, plus new airframe | redrsv | Aircraft - Electric - Jets (FS/W) | 10 | Dec 28, 2010 09:07 AM |
| Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF | Aero12 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 26, 2010 12:11 AM |
| New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? | rjp0325 | Electric Ducted Fan Jet Talk | 17 | Sep 24, 2010 07:12 PM |
| Sold New Mig-29 Vectored Thrust Complete Kit | Harv | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 29, 2008 09:24 AM |
| Video Mig-29 with 2-Dimension Thrust-Vector-Control system | bryan.chen | Electric Plane Talk | 0 | Jun 25, 2006 08:21 AM |
