Old Feb 14, 2013, 07:06 AM
off2fly is offline
Find More Posts by off2fly
off2fly
off2fly's Avatar
Danville Va
Joined Feb 2007
Repl airframe
They told me a TP it is foam only 250 smackers +frgt
off2fly is offline Find More Posts by off2fly
Old Feb 14, 2013, 03:57 PM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Shows plane and fans here for $250;
http://www.chiefaircraft.com/seb-mig-01rs.html
Jack
jfetter is offline Find More Posts by jfetter
Old Feb 18, 2013, 04:53 PM
cdmanbg is online now
Find More Posts by cdmanbg
Bulgaria, Sofia-city, Sofia
Joined Aug 2012
Hey guys , a couple of questions here. I have several flights on my Mig29 , so I am still learning , I saw many movies that this mig has more than 1:1 power sa she can lift in any condition , yesterday I tried high alfa and full throtle just barely cept me hovering - no lift at all. I am lflying with WellPower SE V2 4000MAH/22, 2V 45/80C CH8 which is 635 g heavy. Also I did not program my speeds to my throtle range - I guess it is like turnigy - put the throtle stick to max - then connect the battery and then after hearing the beeps you put the stick down - but I did not tried this yet.
My plane is V2 with new ESC which are 65A I think. Stock motors with little fan balansing by me.
So my question is - how can I improve the thrust. I want it to have enough power to get away from troubles - I have to rebuild the whole nose section now btw Everything to the battery is havy damaged from my last crash.
I am thinking for 2x
http://www.horizonhobby.com/products...0kv-EFLM3015DF
and
http://www.horizonhobby.com/products...ed-fan-EFLDF15
This E-flight combo is making about 50A , and thrust about 1.3kg - the stock motor/fan is making 52A and about 1.2kg thrust I think.
Any suggestions here ?
cdmanbg is online now Find More Posts by cdmanbg
Old Feb 18, 2013, 05:39 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
and
Any sugestions here ?
For starters measure the amp draw @ WOT, I am curious to see the results...
Jack
Old Feb 19, 2013, 05:09 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
WellPower SE V2 4000MAH/22, 2V 45/80C CH8[/url] which is 635 g heavy.
That is a 6S battery that you are mentioning. The SebArt is a 4S system. A regular 4S, e.g. the SLS APL 45C 4.000mAh, weighs 462 grams and the SebArt does fly with it and hover with it, very well.
Are you sure you are using the SebArt MiG, not the Lanxiang MiG? If you put the 6S into the SebArt, you would fry the electronics.
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Feb 19, 2013, 10:54 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Futhermore, I think the manual recommends using a 3300ma battery for 3D, and 4000ma for more regular flying.
TheCure is offline Find More Posts by TheCure
Old Feb 20, 2013, 05:29 AM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Of course that's only 2.5 minutes of flying but who's counting ;-)
Jack
Old Feb 20, 2013, 09:31 AM
Joined Aug 2012
Cheers,
Henrik
Ah , my mistake - I am sorry , it is Sebart - but I linked my Eurofighter Battery which is also 4000 mah.
I am using this one for the Mig 29 :
SE V2 4000MAH/14, 8V 45/80C CH8 - it is the 4S version and it is only 425g
I have 4S - 3300mah Hyperion battery with 35C but I had no chance to try it yet - since I crashed pretty badly - I wanted to do High Alpha hoover - when the plane fliped
But anyway - my questions was whats other expirience on stock power system - do I need to upgrade it - or go for lighter battery or something ?
Old Feb 20, 2013, 01:39 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
What is your Amp draw @ WOT?
Old Feb 21, 2013, 03:10 AM
Joined Aug 2012
It is 53A per fan - so 103A total for both at WOT.
Old Feb 21, 2013, 09:04 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
That is not enough. Welcome to the wonderful world of Wellpower batteries, especially the so-called CH8 45C, first series. I have had two. Can you say "balloon"?
The second series is supposed to be okay. I have two of them, too, for the SebArt, and it flies and hovers and accelerates vertically with them. Good enough.
Your amp draw at the beginning should be more like 120A+. That's what I got.
Maybe better connectors? How hot does your battery-ESC connection get at the plugs?
Cheers,
Henrik
Old Feb 21, 2013, 01:31 PM
Joined Aug 2012
I was afraid of batteries yes , my connectors are EC5 and did not feel hot after flight. I have also Hyperion 3300mAh - 35C - so next time I will test with them - and will check Throttle range too.
Old Feb 21, 2013, 06:08 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Mine is 118 Amps WOT with a Thunder Power 4,400 65C pack, that's another 250 Watts. My vertical is pretty decent and the Mig hovers @ 2 clicks past 1/2 power...
Jack
Old Mar 19, 2013, 10:03 PM
supertoyz is offline
Find More Posts by supertoyz
United States, VT, Colchester
Joined May 2011
I use 4000 mah Gens Ace packs and also get about 118 amps / 1750 watts. I also just installed two Eflite 60 amp ESC's I had lying around so I may bump the timing to see how it holds up. Took out the gyro and installed an Eagle Tree Guardian 3 axis gyro as well......works well on the bench but a little reluctant to try it. The stock setup flew great all of last year then one day it decided to snap roll into the ground from a hover, almost like the gyro reversed.
supertoyz is offline Find More Posts by supertoyz
Old Mar 20, 2013, 02:36 AM
hklagges is offline
hklagges's Avatar
Munich
Joined Dec 2008
That sounds very realistic. I measured a tiny bit above 120 amps with SLS APL 4.000 mAh 45C.
If you try that out, please let us know, it would be very interesting to hear!
Henrik
For Sale Phase 3 Squall Hp, thrust vector, plus new airframe redrsv Aircraft - Electric - Jets (FS/W) 10 Dec 28, 2010 09:07 AM
Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF Aero12 Aircraft - Electric - Airplanes (FS/W) 0 Dec 26, 2010 12:11 AM
New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? rjp0325 Electric Ducted Fan Jet Talk 17 Sep 24, 2010 07:12 PM
Sold New Mig-29 Vectored Thrust Complete Kit Harv Aircraft - Electric - Airplanes (FS/W) 5 Feb 29, 2008 09:24 AM
Video Mig-29 with 2-Dimension Thrust-Vector-Control system bryan.chen Electric Plane Talk 0 Jun 25, 2006 08:21 AM
