Bulgaria, Sofia-city, Sofia
Joined Aug 2012
I will make some tests this week - since My current Gyro was unplugged from plane
. But new Radio has some more menus about Gyro usage , also I got another Gyro from HobbyKing for 10$, I will try/test both to see if it works and I will reports here
Hampshire, United Kingdom
Joined Jun 2005
collect the following: plaster of paris play sand pint glass jug of water light glass and epoxy white spray paint coffee stirring sticks (2 off) original foam nose cling film 1) put a few mm of sand in the bottom of the glass 2) wrap original cone in cling film to protect it from the sane. stand the original cone point down in a pint glass. steady it centrally, with a gap all around it; 3) fill the glass with sand and wet is as you go along, so it holds together 4) pull out the nose cone and, if you are any good at sand castles, you will have a perfect impression of it in the sand. 5) VERY carefully spoon in a plaster of paris mixture - if you pour or drop it in, it will deform your sand "cast"; place a couple of coffee stirrers or popsicle sticks in the top to act as a handle when set - secure in place with a peg or similar to stop them dropping right down. Allow to set. 6) extract plug and spend some time cleaning off the sand which will have stuck to the outside. You then have a re-usable plug to make as many glass cones as you want. 7) wrap plug in cling film tightly (or purchase an expensive release agent or similar). then wrap in glass cloth and apply epoxy. allow to set and remove glass copy. 8) paint/sand as appropriate. sounds a pain, but very therapeutic. |
Canada
Joined Jul 2009
That's the way mine was when it was balanced according to the manual. This tendency helps to set up for hovering. I'm not even close to hovering so I didn't like this. I moved the battery as far forward as I could and it flew more "normal" but still acting like it's tail heavy - not nearly as bad as before. As I get more used to this plane, I'll move the weight aft little by little.
Canada
Joined Jul 2009
I keep the vectoring on all the time. It makes for some very impressive tight maneuvers. I also have one switch setting for very low rates and high expo, so it's not so twitchy even with the vectoring left on. I've been taking off from a folding table, propped up on one end. I'm trying to build up enough courage to just let it take off out of my hand on its own power.
Joined Aug 2012
Evalith8, can you give some more details about programming
mine are ok , but it is good to have this info just in case.Today I had another problem on my Mig - just on 25 second of the flight - one of the FANs broke . I don't know how and why - but the sound you will hear from movie speaks for itself Any idea where to order replacement on these, I live in Europe ? Here is the movie we took and some pictures of the after action review ![]()
| Thread Tools | |
| For Sale Phase 3 Squall Hp, thrust vector, plus new airframe | redrsv | Aircraft - Electric - Jets (FS/W) | 10 | Dec 28, 2010 09:07 AM |
| Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF | Aero12 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 26, 2010 12:11 AM |
| New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? | rjp0325 | Electric Ducted Fan Jet Talk | 17 | Sep 24, 2010 07:12 PM |
| Sold New Mig-29 Vectored Thrust Complete Kit | Harv | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 29, 2008 09:24 AM |
| Video Mig-29 with 2-Dimension Thrust-Vector-Control system | bryan.chen | Electric Plane Talk | 0 | Jun 25, 2006 08:21 AM |
