Jack |
United States, CT, Oxford
Joined Jan 2009
Hi Jack
Yes, that is what I thought, but is not working that way. Radio is a JR X9303. Not sure if something in the TX just isn't set up correctly, but this is the case with all my models using mixes. Only exception is flaperon, or delta wing which are wing type selection in the main menu. If I mix channel 1 and 6 as a programmed mix, only one aileron will move with trim change. Opposite aileron will move if flap trim is used. On this plane, only flight surfaces move with trim. The nozzles, which are plugged into channel 6&7 do not move with aileron or elevator trim....any ideas?? Thanks Mike |
Joined Jan 2009
Jack
Just saw your first post, kinda slamming me there a little bit No, the plane is trimmed out fine, the way it was intended to be trimmed. I believe the nozzle neutral position is intended to push the nose down in hover, to make it easier to hover If you want to fly this plane conventionally, than yes, the setup is all wrong. CG definatally needs to come fwd, nozzles need to come up, elevators down. It's personnel preference really. I wanted to fly 3D sometimes, rip around the field others, and not have harrier it in, or push the nose down for landing anymore. I was just sharing an easy 5 min setup that allows you keep the flight characteristics just the way they are, while being able to land normally, with no throttle, and without having to push the nose down Thanks Mike |
It wasn't intended as a slam at all, sometimes when you read things back you can see it could be taken that way but I assure you it was not meant that way. If you read it monotone, that's what I intended ;-) Jack |
Jack |
Joined Jan 2009
No worries Jack, I must have read it the wrong way
As a side question, I would be interested if anyone knows a way to program radio move a slave channel using the master channels trim? I am thinking it is beyond my radios capablities (JR X9303) Thanks Mike |
Bulgaria, Sofia-city, Sofia
Joined Aug 2012
Hello guys, just finished gluing mine
, I am on radio programing now. Can anyone share files/advice/expirience with Spectrum DX7s - since I have this TX or maybe even DX8 since they are close. I tried to read the whole thread but it is kinda huge
Canada
Joined Jul 2009
Edit .................. Although this has programming for the gyro, I don't think it works or my gyro is a dud. I fly my plane with the gyro by-passed, so don't take for granted that the gyro program in this file is correct. |
| Thread Tools | |
| For Sale Phase 3 Squall Hp, thrust vector, plus new airframe | redrsv | Aircraft - Electric - Jets (FS/W) | 10 | Dec 28, 2010 09:07 AM |
| Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF | Aero12 | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 26, 2010 12:11 AM |
| New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? | rjp0325 | Electric Ducted Fan Jet Talk | 17 | Sep 24, 2010 07:12 PM |
| Sold New Mig-29 Vectored Thrust Complete Kit | Harv | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 29, 2008 09:24 AM |
| Video Mig-29 with 2-Dimension Thrust-Vector-Control system | bryan.chen | Electric Plane Talk | 0 | Jun 25, 2006 08:21 AM |
