Old Sep 25, 2012, 07:57 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Agreed with the others, the rudder and nozzle side-to-side servo are on a y-cord, there is no mix to make them move together as rudder and nozzles ALWAYS move together, no matter what flight mode selected...
Jack
jfetter is offline Find More Posts by jfetter
Old Sep 25, 2012, 10:12 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
Originally Posted by Impailer View Post
Finally - are you certain your RX/Servos are getting enough power? (i.e. good battery)
This might have something to do with it. I've pulled the red wire out of the throttle plug and I'm using an external 5amp BEC that's powered by a 7.4, 2s battery. Everything works except the rudder vector servo on the nozzles. I know it works as I've tested it by plugging the "rudder" plug on a servo tester. Then both the main rudders and nozzles work in unison.
I may just eliminate the gyro altogether if I can't figure it out. There's the last mix to do with GEAR>GEAR that I can't figure out on the DX8. Not sure if this has anything to do with it. It's not actually a mix but it may be assigning gyro function of a particular switch.
xviper is offline Find More Posts by xviper
Old Sep 25, 2012, 11:29 AM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
The gyro is assigned to the gear switch and only active when the flight mode is "2", the gear-to-gear mix is for the gyro sensitivity...
Jack
Old Sep 25, 2012, 12:15 PM
xviper is offline
Canada
Joined Jul 2009
Jack
I have no cases, regardless of switch position, when the rudder vector servo is energized. Even adjusting the rudder sub-trim does nothing for that servo, only the main rudder surfaces.
Old Sep 25, 2012, 03:45 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Sounds like a bad servo or y-splitter...
Jack
Old Sep 25, 2012, 04:18 PM
xviper is offline
Canada
Joined Jul 2009
Jack
The servo works in conjunction with the main rudders when connected to a servo tester directly.
Old Sep 25, 2012, 04:32 PM
Impailer is offline
Find More Posts by Impailer
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
I thought u said it needed a lot of servoteste input to work properly, or did I misread your post? It could suggest bad servo.
Can u upload a vid for us all to see, do we can help some more?
Impailer is offline Find More Posts by Impailer
Old Sep 25, 2012, 06:08 PM
xviper is offline
Canada
Joined Jul 2009
Yes, I did say that. The vector servo reacts, but slowly and in a delayed manner. That's when it's still going through a non-powered gyro. I'm going to try the suggestion made earlier about taking the gyro out of the equation and see how the servo acts when not going through the gyro at all.
If this is a bust, I'll make a video.
Old Sep 25, 2012, 07:14 PM
xviper is offline
Canada
Joined Jul 2009
I just removed the gyro from the equation by pulling the plug from the gear channel. Hooked up the main rudders and the vector rudder to a "Y" and plugged into the rudder channel. Vector now works perfectly in unison with main rudders, no delay and at proper speed.
It's got to be the gyro, gyro settings or my inability to program it correctly in the TX. I'm going to fly it like this for the time being and just not do anything daring at low altitude till I get the hang of it or till I find a solution to the gyro situation.
Old Sep 26, 2012, 03:04 AM
Impailer is offline
Joined Jun 2005
Good to hear you sorted it! I use a $10 gyro in mine, so you dont need to spend mega-bucks to put a new one in.
that said, mine flies well with out the gyro enabled!
good luck - keep us posted.
EDIT: although somewhat weird that the Rudder and Vector were not both affected by the Gyro (as they should have both been on a Y-lead through it) I wonder if there is merit in the suggestion you had a dodgy y-lead?
Old Sep 26, 2012, 10:07 AM
xviper is offline
Canada
Joined Jul 2009
Although the main rudders and the vector servo (via the gyro) are "Y'd" together, the main rudder servos don't go through the gyro. However, you just may have found the problem. When I removed the gyro from the equation, I also removed the stock Y from the equation. I unplugged the vector servo from the gyro and the main rudders from the old Y and used my own. After I maiden it, I'll try another Y and see what happens.
Thanks for everyone's help.
Old Sep 26, 2012, 01:24 PM
TheCure is offline
Find More Posts by TheCure
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Since the discussion has shifted to rudders and servos and such, I thought I'd resurface and ask my question again I never did find an answer for... it's what is preventing me from maidening:
I bought the mig29 kit form. The servo that controls the rudder TV nozzles looks to require a fairly long arm. I have yet to find a arm long enough to engage full throws. I have T-pro MG90s installed all around. I haven't yet found an arm long enough that fits on the servo gear.
I am open to purchasing another 9G servo that has this illusive arm I'm looking for.
Any suggestions please?
TheCure is offline Find More Posts by TheCure
Old Sep 26, 2012, 03:21 PM
xviper is offline
Canada
Joined Jul 2009
Go to SNHobbies in New Westminster and see if these will fit your servo:
http://www.snhobbies.com/product_inf...aaf8245ad2eaaf
Old Sep 26, 2012, 04:34 PM
Impailer is offline
Joined Jun 2005
Right, that explains my confusion. My rudder and vector to via the gyro!
Old Sep 26, 2012, 10:16 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I'm confused! The Rudder channel is both the rudders AND nozzles, so no matter gyro or not, they will BOTH move together, always. If you said the rudders are moving but the gyro is affecting the nozzle movement, something still seems odd, they should react together...
Jack
For Sale Phase 3 Squall Hp, thrust vector, plus new airframe redrsv Aircraft - Electric - Jets (FS/W) 10 Dec 28, 2010 10:07 AM
Wanted Seb-Art Miss Wind 110 E NIB, or Used RTF Aero12 Aircraft - Electric - Airplanes (FS/W) 0 Dec 26, 2010 01:11 AM
New Product NEW! MONSTER THRUST VECTOR EDF F22 buy the RTF get ARF kit free? rjp0325 Electric Ducted Fan Jet Talk 17 Sep 24, 2010 08:12 PM
Sold New Mig-29 Vectored Thrust Complete Kit Harv Aircraft - Electric - Airplanes (FS/W) 5 Feb 29, 2008 10:24 AM
Video Mig-29 with 2-Dimension Thrust-Vector-Control system bryan.chen Electric Plane Talk 0 Jun 25, 2006 09:21 AM
